VFROr Posted October 18, 2015 Share Posted October 18, 2015 Very cool mod, looks great on all of the bikes but that blue one is really a killer! Link to comment Share on other sites More sharing options...
VifferCrab Posted October 18, 2015 Author Share Posted October 18, 2015 That's effing gorgeous. Wow. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer RC51Nick Posted October 19, 2015 Member Contributer Share Posted October 19, 2015 Seb did a fantastic job job on mine and suggested using Duplicolor Metalcast paint. I also found that VHT black metallic high heat engine paint is about 99.99 percent of a match to the factory Honda engine case paint. I think it turned out pretty good. The red on the pressure plate looks a little darker in these photos but outside it is a perfect match for the red striping on the bike. Link to comment Share on other sites More sharing options...
Roebling3 Posted October 19, 2015 Share Posted October 19, 2015 Seb's Clutch cover window is indeed very cool. However: Never use glue, caulk, paste, et. al. in an engine where there is even the slightest chance of it joining the engine, final drive and/or transmission oil stream. I've seen the results in an automatic transmission and found the particulate in OHV valve cavities and drain oil. On the same subject: Molybdenum additive will build up, over time in transmissions and final drives. More is not always better. The advantage of Moly is it's yclept plating or cling-ability. When Moly is used there is always some left in any gear box after draining. It clings to bearing cages, porting and the interstices of all close tolerance spaces. Do not stop using Moly, where specified. The amount as an additive in gear oil is enough. R3~ Link to comment Share on other sites More sharing options...
VifferCrab Posted October 19, 2015 Author Share Posted October 19, 2015 Those RWB bikes are the tits, guys! Wow.... I like it better than my custom scheme, to be honest. here is some pics of wire placement Thanks for sharing... I'll probably make this a winter project. Right now, I just want everything back, so I can ride it. I miss riding.... :( Link to comment Share on other sites More sharing options...
SEBSPEED Posted October 19, 2015 Share Posted October 19, 2015 Thank you for all the kudos guys. I am sincerely humbled and proud to have made so many folks happy with this mod! Link to comment Share on other sites More sharing options...
VifferCrab Posted October 30, 2015 Author Share Posted October 30, 2015 Got word that the cover and pressure plate should be in the powder booth in the next day or two. In the meantime, I went ahead and ordered these washers from ProBolt, and Seb was nice enough to send along the bolts I'd need. *tips cap* I've brought this color down into the chain and sprocket bolts as well, so this should tie in nicely with the pressure plate color... Excited to get it all buttoned back up. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer dgordon Posted October 30, 2015 Member Contributer Share Posted October 30, 2015 What detonates the 07 RWB colour scheme are white wheels, and Sebs cover. Frankly. Atomic. And also not necessarily in the order I stated. They all add up to magnificence. :-) My .02c Dave Link to comment Share on other sites More sharing options...
duccmann Posted October 30, 2015 Share Posted October 30, 2015 Yup, deffinatley one skilled dude. Have a cover an awesome member gave me, so while I'm waiting on my inserts from Jamie, I just have to drool over the pictures. .. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted October 31, 2015 Member Contributer Share Posted October 31, 2015 Link to comment Share on other sites More sharing options...
duccmann Posted November 1, 2015 Share Posted November 1, 2015 VERY SWEEEEET. Not to privy on clutches, that outer plate, is it easily removable? and no doubt its powder coated correct? Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted November 1, 2015 Share Posted November 1, 2015 Those few bolts you see on the outside are all you have to remove to take the pressure plate off. You don't have to remove the frictions or steels if you don't want to. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted November 1, 2015 Member Contributer Share Posted November 1, 2015 My pressure plate is rattled canned primer, red and clear coat. alls 3 cans together <$10... Link to comment Share on other sites More sharing options...
SEBSPEED Posted November 1, 2015 Share Posted November 1, 2015 My pressure plate is rattled canned primer, red and clear coat. alls 3 cans together <$10... Mine is just Duplicator MetalCast red over bare scuffed plate. <$4. Same for the blue on Mario's plate. Gives a nice anodized look Link to comment Share on other sites More sharing options...
Member Contributer Rectaltronics Posted November 2, 2015 Member Contributer Share Posted November 2, 2015 Someone didn't locate the tab between the mid cowl and the upper.... ;-) Link to comment Share on other sites More sharing options...
VifferCrab Posted November 3, 2015 Author Share Posted November 3, 2015 Supposed to be arriving Wednesday! Will update... BOOM! Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted November 3, 2015 Member Contributer Share Posted November 3, 2015 You won't be taking the finished bike outside, will you Clayton? You do realise that you'll get it dirty??? Link to comment Share on other sites More sharing options...
duccmann Posted November 3, 2015 Share Posted November 3, 2015 DUTCHY, were did you get that front wheel decal????? I want!!! Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted November 3, 2015 Member Contributer Share Posted November 3, 2015 blue rim tape with these http://www.ebay.co.uk/itm/VFR-Wheel-Rim-Decals-Stickers-400-750-800-vtec-v-tec-nc-nc21-nc30-1200-/130584029559?hash=item1e676a2977:m:mQEe-4Kvfyo-imIuEg170KQ on top Link to comment Share on other sites More sharing options...
WGREGT Posted November 3, 2015 Share Posted November 3, 2015 My VTEC was disassembled back in 2011 WTF? How'd that happen? Link to comment Share on other sites More sharing options...
VifferCrab Posted November 3, 2015 Author Share Posted November 3, 2015 You won't be taking the finished bike outside, will you Clayton? You do realise that you'll get it dirty??? I know, right? Why the hell would I ever want to actually ride this thing? I can't be held responsible for washing it too. Pffft... Up for sale, F this thing... :) Link to comment Share on other sites More sharing options...
VifferCrab Posted November 5, 2015 Author Share Posted November 5, 2015 Got it mocked up, with full install coming this weekend. I'll probably rattle can the one machined part with the bolt head (don't know the name of this piece) but I think it looks a little off with that part not black. Easy fix. And I wanted to thank member here, tomk1960. He's the one that did the powder coat on the cover, bezel, and pressure plate. It's perfect. You need yours powdered? Send it to him, and don't think twice. That good. Okay, I did a little post processing on these pics because of the severe lack of light in my garage, but the pressure plate matches my fairing bolts, and other aftermarket red accents nearly perfect. As you see, I went with Pro-Bolt silver bolts and Pro-Bolt anodized gold washers, to bring some gold on that side of the bike, to go along with the rear sprocket bolts and chain links. Anyway, here's some quick mocked up iphone pics, with much better pics coming after this weekend. Link to comment Share on other sites More sharing options...
VifferCrab Posted November 8, 2015 Author Share Posted November 8, 2015 Well, got it mostly put back together. I'm waiting for the RTV to setup overnight on the cover , before I put the fairing back together fully. Couldn't resist slapping two bolts in there to see how she looks. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
VifferCrab Posted November 8, 2015 Author Share Posted November 8, 2015 https://vimeo.com/145054314 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted November 8, 2015 Member Contributer Share Posted November 8, 2015 I never got no decals with my cover.... But Crab, that is is one fine looking RWBlack looking motor! Link to comment Share on other sites More sharing options...
