silverbullet132 Posted April 27, 2015 Share Posted April 27, 2015 What would you guys say are the best and must have mods for a 5th gen? Link to comment Share on other sites More sharing options...
Member Contributer gig Posted April 27, 2015 Member Contributer Share Posted April 27, 2015 * I feel are my must haves. F4I Front wheel, wheels powder coated -75 *Two Bros silp on, w/ headers, *repacked, ceramic coated and TI wrapped rear downpipes removed heat-shield -12.5 Hell SS lines *DMr fork kit, raised 8mm Pazzo levers *Zero gravity DB screen *2002 mirrors Painted grey dash panels Back CBR1000 Coil On Plugs -1.25 *Pair valve removed -1.5 *Air-box mod w/ Pipercross Samco hoses Barnett clutch springs, rebuilt slave Valve clearances adjusted Pro Factory Star Shifter CBR1000 Alloy Kickstand and kill-switch -1.0 *Removed center stand -4.0 *CBR600 pegs .25 Haris CF huger & moded *520 sprockets -1 front, and chain -2.5 *Shori battery -7.5 *Penske rear shock, raised -2.5 *PC3, with custom map Galfer rear roter -2.0 Cush drive bushings replaced TI bits -2.0 *Chopped rear fender *LED brake lights Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted April 27, 2015 Member Contributer Share Posted April 27, 2015 First and foremost is a voltmeter. Then Sargent seat and EBC HH brake pads. After that it's just personal preference. I've got the Harris hugger, Ohlins rear shock, Yoshimura SS2R slip-on, Galfer SS brake lines, powdercoated wheels, GPS mount and wiring, 45 tooth rear sprocket, bicycle computer to use because the speedometer is waaaay off due to the previous mod, HawkeOiler chain oiler, bright LED rear brake lights, Mercedes horn, Blue Sea fuse box, VFRness, PAIR block off plates, K&N air filter, Chinese knock-off shorty brake and clutch levers, Power Commander 3 USB, Helibars, Vibranators, black rear wheel lug nuts, rear wheel hole cover, 2001 VFR non-condom mirrors. And I think that's about it. For now anyway. Link to comment Share on other sites More sharing options...
Member Contributer DFerrell Posted April 27, 2015 Member Contributer Share Posted April 27, 2015 Corbin seat Heli bars Lowering blocks for the pegs Throttlemeister Heated grips Luggage VFRness and voltmeter Link to comment Share on other sites More sharing options...
Member Contributer deltaboxii Posted April 27, 2015 Member Contributer Share Posted April 27, 2015 First and foremost- reliability: VFRness and Voltmeter Updated voltage regulator and a quality battery if your seeing a trend here...the electrics are the achiles heel of the VFRs including the 5th gen From there... Upgrade the suspension- you don't need to spend alot. Get a DMR fork kit and CBR929 shock Install good tires- Michelin Pilot Power family/ Pirelli Angel GTs are good choices EBC HH brake pads and stainless steel brake lines Comfort... Taller screen Heli bars Throttle lock of some kind (there are $20 Throttle locks out there now that work as good as my $200 Throttlemeister) Sargent Seat (not a fan of Corbin myself) Performance... Quality slip on exhaust- check the classifieds on here and flea-bay Some folks like to change their gearing for more low end and some go for more mileage PAIR valve removal (DIY) Power Commander 3 (the 5 is not a plug in play according to most) Its really not worth trying to get more performance out of the engine Personal faves... LED CREE headlight kit TechSpec tank pads Factory shift kit GI Pro Digital gear indicator 8 spoke rear wheel off a 3rd gen Givi tank lock tank bag Rear hugger (don't buy a Red Fox they are crap...mine cracked after a year and 5,000 miles) That should about cover the basics of the "must have" 5th gen VFR mods... have fun shopping! Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted April 27, 2015 Member Contributer Share Posted April 27, 2015 ^^^ Well said! Link to comment Share on other sites More sharing options...
TNRabbit Posted April 27, 2015 Share Posted April 27, 2015 The only "must have" for me is PAIR mod, volt meter & DMr shock/fork upgrades. I'm fairly happy with the stock seat, foot pegs & handlebars. As long as everything else is in good repair, ride the hell outta it! Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted April 27, 2015 Member Contributer Share Posted April 27, 2015 Corbin seat Heli bars Lowering blocks for the pegs Throttlemeister Heated grips Luggage VFRness and voltmeter Corbin seat Heli bars Lowering blocks for the pegs Throttlemeister Heated grips Luggage VFRness and voltmeter +1 ... minus lowering ..... And a Power Commander 5 with gear indicator . Link to comment Share on other sites More sharing options...
number9 Posted April 27, 2015 Share Posted April 27, 2015 Who makes the lowering blocks for the footpegs? I can't remember :( EBC HH brake pads and stainless steel brake lines Comfort... Taller screen Throttle lock of some kind (there are $20 Throttle locks out there now that work as good as my $200 Throttlemeister) Any brand recommendations for those 3 things please? Brake lines, screen & cheap throttle lock? Link to comment Share on other sites More sharing options...
Member Contributer deltaboxii Posted April 27, 2015 Member Contributer Share Posted April 27, 2015 Brake lines- HEL, Galfer, Goodridge and Spiegler are all good quality brake lines. Screens- Givi, MRA, Zero Gravity- all good screens in various designs/heights Cheap throttle lock- Inexpensive options Go Cruise Crampbuster Expensive- Throttlemeister (includes bar ends, optional designs and sizes) You can't beat the Go Cruise for $20. You can even move it from bike to bike. So incredibly simple its amazing no one thought of it sooner. They also have the Go Cruise 2 which is adjustable. Which is a plus if you want to move it from a bike with a 7/8" bar to a 1" bar. Link to comment Share on other sites More sharing options...
Member Contributer SCguy Posted April 27, 2015 Member Contributer Share Posted April 27, 2015 BusyLittleShop makes the lowering blocks. I can't help you on the brake lines, but for the screen, Zero Gravity, Givi, or MRA are your options, I believe. For the throttle lock, the cheap option is the Vista Cruise. The original looks better, but requires modification to not hit the tank at full lock, while the NEP is cheaper, and requires no modification. I just installed a NEP, and while it's not much for looks, it works and is a LOT cheaper than Throttlemeister. Link to comment Share on other sites More sharing options...
Member Contributer DFerrell Posted April 27, 2015 Member Contributer Share Posted April 27, 2015 I love my Givi screen, nice clean air behind it. Link to comment Share on other sites More sharing options...
MarantzManiac Posted April 28, 2015 Share Posted April 28, 2015 dont forget the Honda OEM St1100 tank pad to protect her beautiful finish! Link to comment Share on other sites More sharing options...
Member Contributer SCguy Posted April 28, 2015 Member Contributer Share Posted April 28, 2015 In case you need a picture, here's a ST1300 tank pad with Tech Spec C3 tank grips on my 99. Link to comment Share on other sites More sharing options...
RazorWing Posted April 28, 2015 Share Posted April 28, 2015 In case you need a picture, here's a ST1300 tank pad with Tech Spec C3 tank grips on my 99. That looks really good! You don't happen to have a part number on that do you? Link to comment Share on other sites More sharing options...
Member Contributer SCguy Posted April 28, 2015 Member Contributer Share Posted April 28, 2015 The cheapest I've found it is at David Silver Spares. https://www.davidsilverspares.com/NT650V3-DEAUVILLE-2003/part_90833/ Link to comment Share on other sites More sharing options...
Member Contributer zupatun Posted April 28, 2015 Member Contributer Share Posted April 28, 2015 What is your type of riding you mostly do? Sport Tour? Cross Country? Commute? Occasional trackday? I sport-tour, and commute: Minimum mods are: Spare RR, if possible VFRness upgrade (especially if you are on a second or third RR) Volt Meter (datel or other doesn't matter if you are lower than 12.5V in traffic at least you will know). 12V accessory plug or the like for heated gear Front Springs for your weight and riding style (I have 0.95's up front (Ohlins)) New rear spring for your stock shock--don't want to get unbalanced. Bags: Either a top box, soft bags or some type of side bags...good for a briefcase/computer bag. I strap a gym bag on the seat. Battery Tender outlet to hook up battery when not riding (keep battery happy - is like your wife--happy battery, happy life). Brake Flasher - for commuting...the Back Off brand is easy to install. I have a diffent custom setup. Extras for comfort: Sergeant seat (or a Sergeant cover on the stock seat), Bar Risers (Heli-bars) - if you commute the extra reach of the stock bars will eventually make your wrists ache in traffic. Ram Mount X-grip center mount Performance mods: Ohlins or Penske Rear Shock with proper spring Front Fork valving - Non Stock: Ohlins, Racetech or DMR Valves - better yet go drop in a set of Traxxion Dyamics AK-20's with comp and rebound adjustment ss brake lines. (front is minimum). two-brothers headers and exhaust can EFI (Bazzaz, or Power Commander) controller Hour and a half of dyno time at a reputable tuner. I also have F4I front forks on mine with 6th gen triples. I did the valving myself. I use the stock air filter - works great. Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted April 28, 2015 Member Contributer Share Posted April 28, 2015 Fifth gens have two three weaknesses: - electrical (VFRness and r/r to fix, voltage meter to monitor) - suspension (Jamie Daugherty fork internals and rebuilt Honda 929 shock) and set-up for your weight and riding style - headlights (Cree LED headlights HighPerformanceBulbs dot com) - to better avoid deer encounters The rest is gravy. Link to comment Share on other sites More sharing options...
Member Contributer Mohawk Posted April 28, 2015 Member Contributer Share Posted April 28, 2015 What no carbon wheels, disappointed ;) Link to comment Share on other sites More sharing options...
silverbullet132 Posted April 28, 2015 Author Share Posted April 28, 2015 Well I have quite a few mods already but some here were not on my list until now, here is what is currently on the bike + a picture suspension built for 200lb rider by daugherty motorsports (929 shock rebuilt/revalved, front springs + gold racetech valves) custom superbike bars (renthal medium) sargent seat givi top and side case racks zero gravity touring windshield oxford heated grips oberon bar ends power distributor box square projector retrofit (morimoto xb35 bulbs) led brake light bulbs led signal light bulbs (all 4) usb power outlet on front fork blue led gauges power commander 3 FH020AA mosfet r/r pilot road 4 tires 8 spoke rear rim yoshimura r77 carbon slip on pazzo replica levers Next up are: CBR1000 Coil On Plugs Spiegler SS lines Samco hoses Factory pro shift star kit Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted April 28, 2015 Member Contributer Share Posted April 28, 2015 Wow. Looks to me like you've already got it all. YOU could make recommendations to US. She's a beauty. Link to comment Share on other sites More sharing options...
Member Contributer gig Posted April 28, 2015 Member Contributer Share Posted April 28, 2015 Well I have quite a few mods already but some here were not on my list until now, here is what is currently on the bike + a picture suspension built for 200lb rider by daugherty motorsports (929 shock rebuilt/revalved, front springs + gold racetech valves) custom superbike bars (renthal medium) sargent seat givi top and side case racks zero gravity touring windshield oxford heated grips oberon bar ends power distributor box square projector retrofit (morimoto xb35 bulbs) led brake light bulbs led signal light bulbs (all 4) usb power outlet on front fork blue led gauges power commander 3 FH020AA mosfet r/r pilot road 4 tires 8 spoke rear rim yoshimura r77 carbon slip on pazzo replica levers Next up are: CBR1000 Coil On Plugs Spiegler SS lines Samco hoses Factory pro shift star kit Yea, that is a good list already! What is you goal with the bike, better touring, sport ect? Link to comment Share on other sites More sharing options...
Member Contributer adeyren Posted April 28, 2015 Member Contributer Share Posted April 28, 2015 What no carbon wheels, disappointed ;) No 1 on my list when i win the Lottery! Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted April 29, 2015 Member Contributer Share Posted April 29, 2015 I have some 50+ mods to my redslut. The absolute best though is sitting right behind me! Link to comment Share on other sites More sharing options...
RazorWing Posted April 29, 2015 Share Posted April 29, 2015 I have some 50+ mods to my redslut. The absolute best though is sitting right behind me! IMG_9186.jpg Hard luggage? Link to comment Share on other sites More sharing options...
