Convertibar Installation
AnikMankar
Installation of the converibar was not easy though it seemed straight forward. Noticed couple of things ...
  • the length of the handlebars longer than stock.
  • Cutting them to size and ensuring holes aligned needed to be perfect
  • Have throttlemeister - the OD of this is larger than the ID of the handlebar.
  • to get full height - needed longer clutch and front brake lines
  • left side switch wire loom needed to be re-routed.
  • MRA extender - the air was routing straight at me due to upright riding position
cut the the bars to size
IMG 20141222 193804   Convertibar   Lengths
IMG 20141222 193816   Convertibar   longer
IMG 20141222 193848   Converibar   Lengths 2
IMG 20141224 201220   ConvertiBar   Holes match right
IMG 20141224 201301   Convertibar   Holes Match   Right
machined down the OD of the Throttlemeister
IMG 20141226 122611   Convertibar  ID
IMG 20141226 122315   Convertibar   throttlemeister OD
IMG 20141227 203334   Convertibar   throttlemeister after rework
Positioned the Convertibar at the 6 notches high
IMG 20141231 200728   Converitbar Handle Right
IMG 20141231 200737   Converitbar front
IMG 20141231 200742   Converitbar Front 2
the Right master cylinder touches the handles to the angle of the handle had to be adjusted accordingly
MRA extended
using local acrylic managed to cut and create a new visor flap. Not perfect but does the work
IMG 20150101 205038   Convertibar   Extended Visor Front 1
IMG 20150101 205043   Convertibar   Extended Visor 2
IMG 20150101 205051   Convertibar   Extended Visor rear
Results
City riding : this seems very comfy, more upright,
Highway riding : TEST RIDE PENDING
I moved from helibars. Helibars were good but this being fully adjustable I am able to get it to the angle I needed.
Thanks that's what I thought as well as being able to lower them for a spirited ride in the twisties. I plan on putting ss brake and clutch lines on my bike so I can get them to make them 3" longer at that time
I like the idea of extending the visor BUT I think if I was you i would run some ribs down the primary windshield mounts so as to give more support.
What do you mean by ribs. The mounts are on the default clamps.
Low speed probably ok but I would bolt a extension that runs down the windshield . You added a lot of length which will increase load on the stock brackets. My laminar lip is not that long and it come loose .
