mcrwt644 Posted August 6, 2014 Share Posted August 6, 2014 Wanted to let you guys/gals know that 'The Works' toilet bowl cleaner DOES work for cleaning out tanks, rusted, grimey, etc. I've done three tanks (and so have some other forum members) now and was skeptical at best. This stuff does what it says. Costs under $2. You can google the method, but in a nutshell, remove tank empty tank remove petcock remove fuel sending unit tape or plug up those holes empty 50% of 'the works' into tank fill remainder with water allow to sit for 15-20 mins shake and twirl to coat inside of tank add more 'the works' if needed allow to sit drain rinse with water coat with acetone, gas, or a water absorbing liquid allow to air dry for 24 hours put gas in go ride Link to comment Share on other sites More sharing options...
Member Contributer TheJay Posted August 7, 2014 Member Contributer Share Posted August 7, 2014 Vinegar works great too. Cleaned many tanks with it. Link to comment Share on other sites More sharing options...
