Braking By Nick Ienatsch
OutlawsJustice
Nick has written a lot of great stuff and I have talked with him and shared info in other forums. He posted this some time ago, and with his permission I have shared it on other forums.
Braking by Nick Ienatsch
Nick is a member of another forum I am on and I thought this would be good to share with everyone as it can benefit everyone.
"If you have to stop in a corner, one of two things will happen. One, you will stand the bike up and ride it off the shoulder and into whatever is over there. Or two, you will lay the bike down and slide off the shoulder of the road. Braking is done before, or after a corner. The best thing to do before taking a corner is to grind the thought "I'm going to turn this corner" into your mind."
Hiya FZ1 lovers.
I’ve stewed for two days about the above quote taken from another FZ1OA thread...and finally decided to launch this thread. In past years I would have just rolled my eyes and muttered, “Whatever”…but not anymore. I want to tell you that there are measureable, explainable, repeatable, do-able reasons that make great riders great. And brake usage is at the very tippity-top of these reasons. It’ll save your life, it’ll make you a champion. It will save and grow our sport.
I’ll ask this one favor: Would you open your mind to what I’m about to write, then go out and mess around with it?
To begin: Realize that great motorcycle riding is more subtle in its inputs than most of us imagine. I bet you are moving your hand too quickly with initial throttle and brakes. Moving your right foot too quickly with initial rear brake. The difference between a lap record and a highside is minute, almost-immeasureable differences in throttle and lean angle. The difference between hitting the Camaro in your lane and missing it by a foot is the little things a rider can do with speed control at lean angle. Brakes at lean angle. Brakes in a corner.
Yes, a rider can brake in a corner. Yes. For sure. Guaranteed. I promise. Happens all the time. I do it on every ride, track or street. Yes, a rider can stop in a corner. In fact, any student who rides with the Yamaha Champions Riding School will tell you it’s possible. Complete stop, mid-corner…no drama. Newbies and experts alike.
There are some interesting processes to this sport, mostly revolving around racing. But as I thought about this thread, putting numbers on each thought made more sense because explaining these concepts relies on busting some myths and refining your inputs. Some things must be ingrained…like #1 below.
1)You never, ever, never stab at the brakes. Understand a tire’s grip this way: Front grip is divided between lean angle points and brake points, rear grip is lean angle points and acceleration points, lean angle points and brake points. Realize that the tire will take a great load, but it won’t take a sudden load…and so you practice this smooth loading at every moment in/on every vehicle. If you stab the brakes (um...or throttle...) in your pickup, you berate yourself because you know that the stab, at lean angle on your motorcycle (and bicycle, btw), will be a crash.
2)Let’s examine tire grip. If you’re leaned over at 95% (95 points in my book Sport Riding Techniques and fastersafer.com) of the tires’ available grip, you still have 5% of that grip available for braking (or accelerating). But maybe you only have 3%!!! You find out because you always add braking “points” in a smooth, linear manner. As the front tire reaches its limit, it will squirm and warn you…if that limit is reached in a linear manner.
It’s the grabbing of 30 points that hurts anyone leaned over more than 70 points. If you ride slowly with no lean angle, you will begin to believe that aggressiveness and grabbing the front brake lever is okay…and it is…until you carry more lean angle (or it’s raining, or you’re on a dirt road or your tire’s cold…pick your excuse). Do you have a new rider in your life? Get them thinking of never, ever, never grabbing the brakes. Throttle too…
3)If you STAB the front brake at lean angle, one of two things will happen. If the grip is good, the fork will collapse and the bike will stand up and run wide. If the grip is not-so-good, the front tire will lock and slide. The italicized advice at the beginning was written by a rider who aggressively goes after the front brake lever. His bike always stands up or lowsides. He’s inputting brake force too aggressively, too quickly...he isn't smoothly loading the fork springs or loading the tire. He may not believe this, but the tire will handle the load he wants, but the load must be fed-in more smoothly…and his experience leads to written advice that will hurt/kill other riders. “Never touch the brakes at lean angle?” Wrong. “Never grab the brakes at lean angle?” Right!
But what about the racers on TV who lose the front in the braking zone? Pay attention to when they lose grip. If it’s immediately, it’s because they stabbed the brake at lean angle. If it’s late in the braking zone, it’s because they finally exceeded 100 points of grip deep in the braking zone…if you’re adding lean angle, you’ve got to be “trailing off” the brakes as the tire nears its limit.
4) Radius equals MPH. Realize that speed affects the bike’s radius at a given lean angle. If the corner is tighter than expected, continue to bring your speed down. What’s the best way to bring your speed down? Roll off the throttle and hope you slow down? Or roll off the throttle and squeeze on a little brake? Please don’t answer off the top of your head…answer after you’ve experimented in the real world.
Do this: Ride in a circle in a parking lot at a given lean angle. That’s your radius. Run a circle or two and then slowly sneak on more throttle at the same lean angle and watch what your radius does. Now ride in the circle again, and roll off the throttle…at the same lean angle. You are learning Radius equals MPH. You are learning what throttle and off-throttle does to your radius through steering geometry changes and speed changes. You are learning something on your own, rather than asking for advice on subjects that affect your health and life. (You will also learn why I get so upset when new riders are told to push on the inside bar and pick up the throttle if they get in the corner too fast. Exactly the opposite of what the best riders do. But don’t believe me…try it.)
Let me rant for a moment: Almost every bit of riding advice works when the pace is low and the grip is high. It’s when the corner tightens or the sleet falls or the lap record is within reach…then everything counts.
“Get all your braking done before the turn,” is good riding advice. But what if you don’t? What if the corner goes the other way and is tighter and there’s gravel? It’s then that you don’t need advice, you need riding technique. Theory goes out the window and if you don’t perform the exact action, you will be lying in the dirt, or worse. Know that these techniques are not only understandable, but do-able by you. Yes you! I’m motivated to motivate you due to what I’ve seen working at Freddie’s school and now the Champ school…
I’m telling you this: If you can smoothly, gently pick-up your front brake lever and load the tire, you can brake at any lean angle on and FZ1. Why? Because our footpegs drag before our tires lose grip when things are warm and dry. It might be only 3 points, but missing the bus bumper by a foot is still missing the bumper! If it’s raining, you simply take these same actions and reduce them…you can still mix lean angle and brake pressure, but with considerably less of each. Rainy and cold? Lower still, but still combine-able.
5)So you’re into a right-hand corner and you must stop your bike for whatever reason. You close the throttle and sneak on the brakes lightly, balancing lean angle points against brake points. As you slow down, your radius continues to tighten. You don’t want to run off the inside of the corner, so you take away lean angle. What can you do with the brakes when you take away lean angle? Yes! Squeeze more. Stay with it and you will stop your bike mid-corner completely upright. No drama. But don’t just believe me…go prove it to yourself.
6)Let’s examine the final sentence in the italicized quote. The best thing to do before taking a corner is to grind the thought "I'm going to turn this corner" into your mind.
No, that’s not the best thing. It’s not the worst thing and I’m all for positive thinking, but we all need to see the difference between riding advice and riding techniques. This advice works until you enter a corner truly beyond your mental, physical or mechanical limits. I would change this to: The best thing to do before taking a corner is to scan with your eyes, use your brakes until you’re happy with your speed and direction, sneak open your throttle to maintain your chosen speed and radius, don’t accelerate until you can see your exit and can take away lean angle.
7)Do you think I’m being over-dramatic by claiming this will save our sport? Are we crashing because we’re going too slowly in the corners or too fast? Yes, too fast. What component reduces speed? Brakes. What component calms your brain? Brakes. What component, when massaged skillfully, helps the bike turn? Brakes. If riders are being told that they can’t use the brakes at lean angle, you begin to see the reason for my drama level. When I have a new rider in my life, my third priority is to have them, “Turn into the corner with the brake-light on.”
I’ve said it before: This is the only bike forum I’m a member of. I like it, I like the peeps, I like the info, I love the bike. Could we begin to change the information we pass along regarding brakes and lean angle? Could we control our sport by actually controlling our motorcycles? If we don’t control our sport, someone else will try. Closed throttle, no brakes is “out of the controls”. Get out there and master the brakes.
Thanks, I feel better.
Nick Ienatsch
Fastersafer.com
I get this and I have practiced it even more effectively after your class David.
I am glad that Nick has given his OK to post this on other forums because I have had a bit of an internal struggle when teaching my sons to ride these past several years with reconciling Nick's article on street riding (THE PACE) with trail braking techniques.
So it is good to read the paragraph where he states "Yes a rider can brake in a corner....I do it on every ride, track or street." Just as he mentioned regarding the FZ1, our VFRs will drag hard parts before the tires lose grip in a turn as well so knowing how to smoothly make these inputs can help prevent so many of the falls we witness or hear about. And then I wouldn't have to hear about someone's cousins brother in law who crashed and burned and was scarred for life by motorcycles and how I should really reconsider my choice to ride and especially not open my sons to the option of riding.
Thanks for posting and thanks for joining our forum, I hope you stick around as we try to bust some of these myths. I'll see you soon for a refresher on level 2.
Over the years, I see people take "The Pace" as the only thing, and Nick did not mean it that way. As you know from Total Control we have been teaching for years what Nick talks about here and He also had a very detailed thread about body position on another forum where he and I shared a great deal. When he wrote this I thought it was great (I am no writer myself) so I asked him about sharing it and he was very welcoming to that idea so I have. I hope it helps a lot more riders and helps them to realize there is so much more out there to learn.
P.S. I know you! You just want to ride the T.C. Solo some more! Anytime I am doing a class, if there is an empty seat, past students are more than welcome to sit in and get some additional practice time on the riding drills!
I would much rather take this class than go to a "track day" class. I don't have to travel far. My bike does'nt have to pass special requirements to "get in" and I don't have to put unecesaary abuse or wear and tear on my bike to better my abilities.
Fabulous. As I've gradually absorbed this information I can say this has saved my bacon many times.
Thanks for posting OJ.
Lots of good information on his website too, fastersafer.com. The price is a little steep for six months of access and the content updates have been a little slow lately (they're moving YCRS to a different track), but there's a few years of video content and articles built up that are more than worth it. I would say a good half of it deals with just trail braking and the smoothness of inputs on your controls. Lots on body position for both street and track too.
Love Nick's riding/writing style and technique. Practicing his techniques has saved my cookies and increased my skill and enjoyment
Sent from my SCH-I200 using Tapatalk
Nick has some amazing insight and advice for street riding. In my opinion braking while cornering is one of the most misunderstood skills in the biking world, yet probably one of the biggest factors in either avoiding an obstacle or crashing trying to avoid it. I will definitely be reading this article again and continually practicing the techniques required to become a safer street rider.
Ok, bacon out of the way,
now work on the venison..... :cool:
  • 1 month later...
A new article written by Nick he calls "The Brake Light Initiative"
I found I was sort of doing this with the many blind corners around here. Also not forgetting there might be gravel kicked up from the shoulder, with a cage running wide coming the other way.
http://www.cycleworld.com/2014/05/28/the-brake-light-initiative-treatise-on-motorcycle-control-using-your-braking-skills/?cmpid=enews052914&spPodID=020&spMailingID=20890912&spUserID=NzM4NjMwOTI0MDQS1&spJobID=321612328&spReportId=MzIxNjEyMzI4S0
  • 1 year later...
Something missing from the instructional paragraphs provided by "Nick"...... and its a key to riding any corner with speed and confidence. This simple technique is often overlooked, but it is as basic as it gets...simply "you steer (to) where you look". In practice, on the twisties and slabs ..either way, the farther you look ahead, the more concentrated you focus your vision on the maximum available visible point of road ahead of you (the vanishing point) the better you can ride up to and through that point...all the while remembering to adjust focus as far ahead as possible ...to the vanishing point. It takes concentration...the human mind wants to see whats happening immediately in front of your speeding machine, thats okay, just let it be the peripheral vision that picks up the area directly in front.
Nick has covered "looking where you want to go" in other writings... books on riding technique, articles, etc. If I'm not mistaken he is a co-author of "The PACE" too, which is a philosophy we encourage on group rides.
