Member Contributer CornerCarver Posted August 29, 2013 Member Contributer Share Posted August 29, 2013 Searched and now can't find the two old threads for the COP swap (4th gen and 5th gen IIRC). Our question is this, does anyone know of a 3 wire COP that is shorter than the 6th gen COP and therefore more likely to have a better fit in the 5th gen head? We are really far along in our 5th gen engine in a 6th gen frame and have tried to utilize the 5th gen coils to no avail. We will need a 3 wire Coil on Plug that fits better into the 5th gen heads. thanks in advance, Keith Quote Link to comment Share on other sites More sharing options...
timmythecop Posted August 29, 2013 Share Posted August 29, 2013 That is all I'm worth? One decade-old motorbike engine? Quote Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted August 29, 2013 Member Contributer Share Posted August 29, 2013 I'd recommend Timmy as THE cop. Quote Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted August 29, 2013 Member Contributer Share Posted August 29, 2013 I think it was one of the suzuki COPS that was the shorter one. I think I asked in one of those threads, so not much help. http://www.vfrdiscussion.com/forum/index.php/topic/70686-4th-gen-coil-on-plug-mod-split-thread/ Quote Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted August 29, 2013 Author Member Contributer Share Posted August 29, 2013 I will be selling a low miles 6th gen engine soon for the cost of a stator cover...that may result in Timmy the COP have access to free adult beverage, perhaps a red solo cup full of Sangria Quote Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted August 29, 2013 Member Contributer Share Posted August 29, 2013 http://www.vfrdiscussion.com/forum/index.php/topic/67684-5th-gen-coil-on-plug-setup/ Maybe the 2000's GSXR cops. Quote Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted August 29, 2013 Author Member Contributer Share Posted August 29, 2013 ah, there it is, thanks Yoshi... Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 29, 2013 Member Contributer Share Posted August 29, 2013 The 2008 CBR1000 COPs fit perfect in my 5th gen, but that is a 2 wire set-up. If I may ask, why are you going with the 6th gen ECU and the 3 wire ignition output on a 5th gen engine? Quote Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted August 29, 2013 Author Member Contributer Share Posted August 29, 2013 We are using the 6th G wiring harness because with the 5th G engine in the 6th G frame there is not much room to fit the 5th G reg/rec and when mounting the 6th G reg/rec that leaves no real room for the 5th G coils...kind of one thing lead to another once we mounted the 6th G injection system and frame to the 5th G engine. You don't recall about how long the CBR 1000 COPs are do you? I think we would be really close if we could find a suitable 3 wire shorter COP. Quote Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted August 29, 2013 Member Contributer Share Posted August 29, 2013 Can't you fit a different R/r on there? Not like the OEM honda units are the greatest to begin with. Quote Link to comment Share on other sites More sharing options...
Member Contributer Mohawk Posted August 29, 2013 Member Contributer Share Posted August 29, 2013 check out my 5th gen 10 year refresh thread, shows CoP but only 2 wire the pics shw the clearance to the head. Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 29, 2013 Member Contributer Share Posted August 29, 2013 I never measured it on a ruler... here is a comparison to my Y2K plug boot... The rubber boot on the COP fit perfect in the valve cover and sealed it just below the lip. What I started with from a 2008 CBR1000... Here they are installed... Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 29, 2013 Member Contributer Share Posted August 29, 2013 Making the wiring connector from the CBR harness. Waterproof crimp male spade connectors, white lithium grease to seal out moisture, and liquid tape sucked into the back of the connector to provide the final seal. I matched the wire colors from the CBR harness and connectors to the install on the stock VFR wiring... I know, a little anal, but while I was making it I figured what the hell... ... attached to the stock wiring so it is completely reversible... Installed and wired... 1 Quote Link to comment Share on other sites More sharing options...
Auspanglish Posted August 29, 2013 Share Posted August 29, 2013 So... wouldn't 6th gen ECU mean VTEC mapping for an engine with no VTEC hardware...??? Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 29, 2013 Member Contributer Share Posted August 29, 2013 So... wouldn't 6th gen ECU mean VTEC mapping for an engine with no VTEC hardware...??? Yup... that could be an issue Quote Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted August 30, 2013 Author Member Contributer Share Posted August 30, 2013 Actually the only thing the ECU does specifically for Vtec is open and close a solenoid on the oil circuit deep in the V. Of course, any changes to the fuel map can be made with one of the myriad aftermarket controllers. With the large difference in injectors between 5th G and 6th G it seems (without any objective test data) to be a coin toss as to which ECU will better control the fuel map in base form. Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 30, 2013 Member Contributer Share Posted August 30, 2013 ...With the large difference in injectors between 5th G and 6th G it seems (without any objective test data) to be a coin toss as to which ECU will better control the fuel map in base form. From the sounds of this... and please correct me if I'm reading incorrectly between the lines, are you going to be using 6th gen injectors on the 5th gen engine? I've often wondered about this with the 6th gen multi-orificed injectors getting better atomization if a swap is worth it... Quote Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted August 30, 2013 Member Contributer Share Posted August 30, 2013 We are really far along in our 5th gen engine in a 6th gen frame ... Keith Is there a photo build thread? Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted August 30, 2013 Share Posted August 30, 2013 ...With the large difference in injectors between 5th G and 6th G it seems (without any objective test data) to be a coin toss as to which ECU will better control the fuel map in base form.From the sounds of this... and please correct me if I'm reading incorrectly between the lines, are you going to be using 6th gen injectors on the 5th gen engine? I've often wondered about this with the 6th gen multi-orificed injectors getting better atomization if a swap is worth it... You need to swap the entire throttle body assembly then. The 6th gen fuel injectors won't fit in the 5th gen fuel rack. Way different size/length. Rangerscott69 has done this. It works fine. You can use the 5th gen ECU. Quote Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted August 30, 2013 Author Member Contributer Share Posted August 30, 2013 Everything on the bike with the exception of the engine is 6th G. I pressed MiniCarver on switching back to the 5th G harness and ECM (this would end our search for 3 wire coils that are shorter than 6 G) and he doesn't want to go back to the 5th G instruments or lights either... ...With the large difference in injectors between 5th G and 6th G it seems (without any objective test data) to be a coin toss as to which ECU will better control the fuel map in base form.From the sounds of this... and please correct me if I'm reading incorrectly between the lines, are you going to be using 6th gen injectors on the 5th gen engine? I've often wondered about this with the 6th gen multi-orificed injectors getting better atomization if a swap is worth it... You need to swap the entire throttle body assembly then. The 6th gen fuel injectors won't fit in the 5th gen fuel rack. Way different size/length.Rangerscott69 has done this. It works fine. You can use the 5th gen ECU. Have the entire 6G throttle bodies mounted and fueling (no spark or we would be running right now)...was not aware that we could fire the 6G TB's with the %g ECM though, that is good news. Perhaps we will switch back to the 5G harness and try to re-wire the front harness to accept the 6G instrumentation, lights etc... Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 30, 2013 Member Contributer Share Posted August 30, 2013 ...With the large difference in injectors between 5th G and 6th G it seems (without any objective test data) to be a coin toss as to which ECU will better control the fuel map in base form.From the sounds of this... and please correct me if I'm reading incorrectly between the lines, are you going to be using 6th gen injectors on the 5th gen engine? I've often wondered about this with the 6th gen multi-orificed injectors getting better atomization if a swap is worth it... You need to swap the entire throttle body assembly then. The 6th gen fuel injectors won't fit in the 5th gen fuel rack. Way different size/length. Rangerscott69 has done this. It works fine. You can use the 5th gen ECU. Does the 5th gen air box fit on the 6th gen throttle bodies or do you need to use the 6th gen air box? If Rangerscott69 is listening... how did this mod turn out? Performance, ride-ability, mileage, power... any comments? Worth the swap or just neat to do? ...ooops, sorry for the threadjacking Quote Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted August 30, 2013 Author Member Contributer Share Posted August 30, 2013 The airbox (and filters) interchange but there are small profile differences in the airbox lower that made us select that unit. IIRC there is something different in the rear where the 5G coil mounts and something on the right side front where the vacuum lines connect. Quote Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted August 30, 2013 Member Contributer Share Posted August 30, 2013 (edited) From the peanut gallery: sounds like another can of worms. (We REALLY need an emoticon for that. ed) You doods should be out riding! Which I will be as soon as I sign off. Edited August 30, 2013 by MaxSwell Quote Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted August 31, 2013 Author Member Contributer Share Posted August 31, 2013 Anybody know if this can control the ignition as well as the fuel? http://www.useasydocs.com/index.html This is specifically what I am trying to understand... http://microsquirt.info/indexright.htm Bullet points 1 and 2 in the bottom link above. Quote Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted September 3, 2013 Member Contributer Share Posted September 3, 2013 It does ignition and fuel. Here's a blog on someone converting is CBR250RR to FI using the microsquirt. http://projectcbr250rri.blogspot.com/search?updated-max=2012-04-30T20:16:00%2B01:00&max-results=7 Quote Link to comment Share on other sites More sharing options...
