Anyone Ever Rebored/overbored A 5/6Th Gen
Mohawk
I did get the info from Brian, posted in another thread. No rocket science involved. They bored out the MMC & inserted a 2mm steel liner & fitted 76mm JE pistons for a nominal 870cc, more torque everywhere but the HP figures we're let down by lack of other tuning to increase the breathing at speed & the fact that the JE pistons were heavier than stock, so could not benefit from high revs.
  • Replies 586
I contacted TTS in the UK re the big bore kits that they used to offer and this is what I got backup.
Hi, we can still supply the VFR800 bore kit, these are made for us by JE & take the capacity out to 837cc with a comp ratio of 13:1, cost for the pistons £500, the cylinder will need to be bored & re-plated cost for this process £600, plus shipping back to NZ ?? cost for the shipping £100, we have aproxx a 4 week turn round on these kits & plating.
regards
Paul
Paul Bembridge
TTS Performance
Unit 3 West End Farm
Silverstone
Northamptonshire
NN12 8UY
ENGLAND
TEL: +44 (0)1327 858212
FAX: +44 (0)1327 858099
www.TTS-Performance.co.uk
www.RotrexSuperchargers.co.uk
Was a bit pricey for me as 1200 UK pound is close to $2400 NZD
Hence why I'm going with the CBR929 and a local borer.
Phil
I spoke to them too. They send the top case to the USA, to be bored & nikasil plated. No way they have a 4 week turn around, be lucky to get it in 4 months !
The crankcase is currently being bored and I should have it back by the end of the week.
Had to supply the machine shop with the crankcase main bearing bolts so as they could fit the case to their jig, These bolts are M9 thread, yep that is right M9
In all my years I've never seen a M9 bolt.
I'll update the thread once I've got the cases back.
Yes, pics please... and are you having the bore plated with Nikasil? If not, what kind of a finish are they putting on the MMC?
My understanding is that there is no need to plate the MMC as once honed it works just like cast iron liners.
Hence why they offer 0.25 and 0.5mm oversize pistons as spares.
I'll post pics once ive got all the bits back.
That is my understanding too... I asked because others had posted about the Nikasil plating.
Does the MMC liner need a cross-hatched finish for the rings to seat like a steel bore does?
Yep, the bore needs to be honed to the required size and finish just like a cast iron liner.
The standard bores had a good 45 deg cross hatching and were in really good shape.
I felt quite bad about boring them out. LOL
The only time I think you need to Nikasil plate the bores is if you go the whole hog and bore the complete MMC liner out as what happened with the big big bore kits.
Looks like we got another Burt Munro here............ :goofy:
Not in either of those gents league and I'm an Ozzie living in NZ.
I've had some experience with V4's in the past building a 880cc Superbike back in the '80's. See below.
You 'Da Man!!!!
Nicely done HighSide!
Now I know who to call ;)
Cool story about Burt.
Glad to see he is still in the head lines.
Just been talking to the machine shop that is doing the bore and hone.
Bore all completed and no issues but they have just checked with the honing equipment suppliers and it seems that the MMC used by Honda is different to what Porsche/BMW etc. use and that is what the shop thought it would be.
There may be a different process to hone the sleeves for our stuff as the liners are not the normal aluminium/silica so they probably cannot use the standard lapping process that removes the aluminium and exposes the silica.
Being sintered, it might be a diamond hone.
Should know tomorrow what the progress/process is.
Very sweet project, were you the rider or mechanic ? And did it ultimately produce any success ? First I've heard of that bike.
Are you boring the MMC to 74mm for the 929 pistons ? Looks like I got beat to it ;) Good man.
No, I'm the mechanic.
Ran 2 strokes before this with TZ350's, TZ500's and RG500's.
Success was an issue. Ran out of money, no sponsors, and then had a cam gear failure that destroyed one head.
That pretty much put paid to it as we couldn't afford to repair it.
Yep boring the MMC to 74mm
Using the 929 pistons same as you were looking at doing.
I need to say that this thread is becoming fucking awesome.
My Vfr has about 160,000 ks on it, when it goes, hopefully I'll be able to ride your coat tails and go big bore.
Guys
I've finished the balancing of my rods and pistons and they are soooo close it doesn't matter.
See shots below:
I've also included a couple of shots outlining the difference in mass of the original 800 piston and what I've been able to get the 929 ones down to without too much issue. I'm still about 0.5g heavier but that is well within the realms of balance factor on the crank and with forged pistons, can't see they are going to break any time soon, when compared to the cast VFR pistons.
One thing I did find interesting was the 929 rods that came with the pistons were majorly different in balance than the VFR stuff. I find this amusing seeing the 929 revs higher than the VFR and was designed as a "sports" bike.
These are the piston shots
Stock VFR piston
Modified 929 piston
Bored crankcases
I'll keep you posted on progress.
Just doing the head gasket mods at present and going to check valve reliefs in the pistons.
Cheers
Phil
Shortened the skirts to the same length as the VFR ones and then took weight out under the crowns, above the gudgeon bosses and the gudgeon webs across to the skirts.
I'll see if I can get a photo or two of the pistons and post.
