04asphalt Posted September 14, 2012 Share Posted September 14, 2012 as titled, need to know which map to use for my specs PLEASE. Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted September 14, 2012 Member Contributer Share Posted September 14, 2012 Go here http://tinyurl.com/9kswtfk and download the 126-004 map or the 126-all file, otherwise you can go to the download section of the VFRD forum and see what others have posted up. There are quite a few custom maps to choose from. You'll have to read the descriptions to see what their setup is. Link to comment Share on other sites More sharing options...
04asphalt Posted September 15, 2012 Author Share Posted September 15, 2012 thanks, loaded the map. anyone refined it yet? Link to comment Share on other sites More sharing options...
Member Contributer coderighter Posted September 15, 2012 Member Contributer Share Posted September 15, 2012 Check in the downloads under coderighter, I've got a map up there that should work for you. Link to comment Share on other sites More sharing options...
04asphalt Posted September 15, 2012 Author Share Posted September 15, 2012 loaded 06 PCV Autotune generated map Rev 15 . my pair still active more ridable in low gear /low RPM vtec transition not as seamless as dynojet map at times but much smoother than stock 5k flat gone pulls very well above vtec temp rises alarming 20F-30F in minutes when riding hard(lean?) smelled very hot after a hard 20 minute Link to comment Share on other sites More sharing options...
