A little Z bracket with two holes drilled for the tank bolts to pass through. Connected it to the switched ignition wire group. soldered and taped and forgotten. Monitoring is smart!
Share this post
What is a Z bracket?
Share this post
On the SP I (re)use the Signal Dynamics LED voltmeter from redslut
On the VF, old skool VDO :-)
Share this post
Mt VFR has a laughable 70's LCD gauge.
But my 1000SP came with one from the factory in the 70's.
Share this post
My VFR1100ST, with a gauge that looks like it is meant to be there (but its not...): Honda marine gauge, fitted in the headlight adjuster receptacle.
Share this post
Mine is reverse LCD, it looks white on black in full sun, and red on black at night.
Share this post
Here's mine.
Cheapo eBay meter and I bent a wire hanger to secure it to one of the tank bolts.
Share this post
^^^^^^Necessity is the mother of invention..:beer:
Share this post
Haha...  Yeah.
All the discussion on R/R failing made the R1 piece and this meter the first mods I did.  But I didn't want to spend too much money on my first attempt putting a meter on.  So this was the result.  Working well so far.
Share this post
Just sunk her in the other day. Muck better than the cheapo I tired first. This one was still cheap though $8 on eBay. Also installed a fuse block.
Share this post
I was too afraid to cut holes in my lovely new (to me) VFR800, so I decided to go 'old school' and fit an LED voltmeter to the mounting bracket for my heated grips. The end result may look a bit 'Radio Shack', but I think that the two units match each other very well and that the LEDs don't really look out of place next to the heated grip control. YMMV :wink: , of course.
2017_07_18._P1000794__DMC-LX100_with__le
2017_07_18._P1000795__DMC-LX100_with__le
Thanks a lot Photobucket :mad: !
Edited by Snapper
Photos disappeared due to corporate greed.
Share this post
Just bought one of these
https://www.aliexpress.com/item/12-V-Motorcycle-Motocicleta-Volt-Meter-Gauge-Car-LED-Digital-Display-Voltmeter-Waterproof-Voltage-Volt-Meter/32810414939.html?spm=a2g0s.9042311.0.0.yUVruO
Now just need some advice on what wire I need to attached to it.
I've got a choice of buying 3, 5, 8, 17, 27 amp.
So which should I use?
Share this post
If it's just a voltmeter you are buying it won't have a current rating, as it doesn't draw any current (for the purposes of this discussion).
Based on this, you probably mean you need to specify a voltage rating which will determine the measurement range of the gauge.  In which case, the nearest best choice is 17v, as your 12v car/bike battery will have ~14v as measured when it's running (charging from your alternator/stator).
Share this post
Excellent cheers for that. Makes it a bit easier to pick up the wire now.
Share this post
My first attempt at fitting a voltmeter involved using this rather 'Radio Shack' looking, multi-LED device, which I mounted on the bracket for the heated grips controller :unsure: ...
w5QTz_owj7Vk6IFxZ7dGK0ky-rhFv8X0Fx6QmCQ1
However, it was hard to read and so I finally decided to take the plunge and have a hole cut in the right hand side fairing, so that my brother could kindly fit this one for me :cool: ...
2018_04_14._P1010117__(DMC-LX100_with__lens_at_75_mm,_¹⁄₂₀₀_sec_at_ƒ_-_2.8_at_ISO_200)-2.jpg
It is easy to read and very conveniently covers over a spot where I spilled some brake fluid on the paintwork :blush: .
Share this post
Old thread, but just saw this.  The meter reads 5-15v, which is a bit low, considering that "in-spec" goes all the way up to 14.8v on this model of VFR.  Anyway, the wire gauge required for a voltmeter is not large at all.  Use the smallest wire that is sturdy enough to survive the motorcycle environment.
Ciao,
Share this post
DATEL  8V-50V meter wired into the R/R side of the Roadstercycle relay, so even if fuses start popping or before the breaker trips, I can see how much voltage is coming out of the R/R. This is very important to diagnose what went wrong. I used a relay, triggered by the license plate light, used Velcro for the mounting, and drilled a small hole for the wire.
Share this post
Still a great thread :beer:
Share this post
I totally agree.  The creativity is amazing.
Share this post
Purchased a small 3 wire voltmeter from fleeBay. The beauty of a 3 wire device (positive and negative sense wires and a power source wire) is it can be connected directly and permanently to the battery which is what I want, the third wire is then connected to any switched positive to power the voltmeter, the voltmeter only powers up with Ignition to ON. No relay/switch required. Had this on for the last 12 months, works great. Just for info the 8gen has a very stable 14.5v output under all conditions, says a lot for the fancy new R/R.
Cheers. :beer:
Share this post
I admit a blue meter would fit better woth the theme... No holes needed. Its Just held on with double sided tape. The little green LED is the cruise control status indicator.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
