JES_VFR Posted September 27, 2011 Share Posted September 27, 2011 While I have the Meters out of the bike, I'm going to change the bulbs for LED's I found the printed copy of KPerham's led list, which seems to have been lost. I notice that he says not to use LEDs for the FI light and the turn signal indicators. Did this ever get sorted out?? Also does using a non-load sensitive flasher solve the problem. Quote Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted September 27, 2011 Member Contributer Share Posted September 27, 2011 Why LEDs? Other than 'coz you can of course. I've done it on my Silverado - Blue. Don't ask. Seemed like a good idea at the time. Ton of work and now I wish I didn't. Still have a bunch of blue LEDs and resistors laying around. Quote Link to comment Share on other sites More sharing options...
JES_VFR Posted September 27, 2011 Author Share Posted September 27, 2011 Well, I've got one dead 194 bulb behind both the speedo and tach, so they both have been sort of dim at night. I'm lazy enough that I was in no rush to dig in and replace it, but since I have the instrument panel out in the middle of repairs from the crash, I should take care of it. I just figured that I've had better luck with led's in two of my cars and they use less wattage compared to the regular lights. I'm not going blue, but I'll probably go bright white. Quote Link to comment Share on other sites More sharing options...
AB-Oz Posted September 27, 2011 Share Posted September 27, 2011 yeah i went blue led's in my 5th gen dash, after the LDC backlight kept blowing (well twice in 10 years!), left the FI and indicators as they were as they were not a problem to me. Cost me about $10 from fleabay. Quote Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted September 27, 2011 Member Contributer Share Posted September 27, 2011 Well, if you gona do it, make sure that you pick the ones with diffuser at the top. If you don't you will have some very bright spots shining through. Those things are BRIIIIGHT! And if you try to use dremel to create said diffuser after you've soldered them in, they will come out along with the track of the PCB. Ask me how I know... P.S. I'm not sure about lower wattage. Same voltage, same resistance (achieved by using extra resistor) = same wattage. No? Quote Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted September 28, 2011 Member Contributer Share Posted September 28, 2011 While I have the Meters out of the bike, I'm going to change the bulbs for LED's I found the printed copy of KPerham's led list, which seems to have been lost. I notice that he says not to use LEDs for the FI light and the turn signal indicators. Did this ever get sorted out?? Also does using a non-load sensitive flasher solve the problem. You doing a Fifth Gen? On mine, the signal indicators and the FI indicator all stayed on at less than full brightness. I guess enough power goes through to light the led, but not enough to illuminate an incandescent bulb under normal conditions? I have a relay to allow normal flash rate, but if course it is separate from the FI. So I'd say the relay is not at all a factor. The "inverted cone" led bulbs I use don't have any hot spots in my display. Quote Link to comment Share on other sites More sharing options...
AB-Oz Posted September 28, 2011 Share Posted September 28, 2011 Here's a piccy of mine I found in my gallery! I got the LED's that diffuse as well. From memory I got 8 for about $10, only need 5 for this job. They've been in for 20,000km with no probs. That bright blue at the bottom is a gear indicator, since replaced with an Acumen. Quote Link to comment Share on other sites More sharing options...
Member Contributer swfarrar Posted September 28, 2011 Member Contributer Share Posted September 28, 2011 I don't have any experience with installing LED's on bikes but can offer one suggestion that might come in handy if they're too bright, which happens often when I'm dealing with audio equipment, especially with the blue LED's. Fingernail polish works great to manage the intensity of LED's and even to change the color slightly. A little deep-red polish applied to an over-bright blue LED dims it and makes it a much more pleasant bluish-purple color. There's also gray polish to dim the light without changing the color, useful for red and green ones. Just dab on a coat, let it dry thoroughly and test it. If it's not enough, put on another coat but ONLY after the first coat is completely dry. If it's too much it comes off easily with, what else, fingernail polish remover, or acetone. Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted September 28, 2011 Share Posted September 28, 2011 I used the inverted cone single LEDs in blue for my dash. Not too bright at nighttime at all, and zero spotlighting of the gauge face. The tack and speedo needles turn a purplish colour and are a tiny bit harder to see than before, when they were orange, but really its no big deal to me, you're shifting by ear anyhow, and usually one can judge their speed pretty well, and it only takes about 10% more thought process to see the purplish needles at night and interpret them anyhow. The gauges are brighter than the cheap camera makes them look (link): http://www.vfrdiscussion.com/forum/index.php/topic/20337-5th-gen-blue-gauges/ I used the Wled-x version which has only 1 LED in it, and the inverted cone for spreading the light around. the Wled-x4 has 4 leds, Wled-x5 has 5, etc. I elected not to use these as I feared they might be too bright. I'm happy with the results. Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted September 28, 2011 Share Posted September 28, 2011 I'm thinking if a fella wanted to use white LEDs, maybe the "cool white" ones might be easier on the eyes at night?? Quote Link to comment Share on other sites More sharing options...
JES_VFR Posted September 28, 2011 Author Share Posted September 28, 2011 Well, if you gona do it, make sure that you pick the ones with diffuser at the top. If you don't you will have some very bright spots shining through. Those things are BRIIIIGHT! And if you try to use dremel to create said diffuser after you've soldered them in, they will come out along with the track of the PCB. Ask me how I know... P.S. I'm not sure about lower wattage. Same voltage, same resistance (achieved by using extra resistor) = same wattage. No? Well I've used some 4 led, side firing ones in my cars and they worked well, very bright, but even lighting. I'm trying to find them again, but so far no luck. As for lower wattage, I don't use load resistors or the LEDS that have them. Mostly because as KPerham said, it just defeats the purpose. Now for the FI light and/or the turnsignals, I'm surprised there is that much voltage in what should be a switched circuit. I wonder if it is some sort of back current, given the crappy grounds of the 5th gen. Anyway thanks for the input everyone Quote Link to comment Share on other sites More sharing options...
JES_VFR Posted September 28, 2011 Author Share Posted September 28, 2011 I'm thinking if a fella wanted to use white LEDs, maybe the "cool white" ones might be easier on the eyes at night?? yeah, I'm looking for cool white or at least natural white leds. Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted September 28, 2011 Share Posted September 28, 2011 yeah, I'm looking for cool white or at least natural white leds. Here: http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fmini-wedge.html Quote Link to comment Share on other sites More sharing options...
GMTURBO Posted September 28, 2011 Share Posted September 28, 2011 The only reason you need a resistor is for turn signals because of the flasher relay circuit. Because an LED uses such low power it is similar to a blown bulb - which gives you the fast flash. Quote Link to comment Share on other sites More sharing options...
V4 Rosso Posted September 28, 2011 Share Posted September 28, 2011 I'm thinking if a fella wanted to use white LEDs, maybe the "cool white" ones might be easier on the eyes at night?? When you often ride at night you better stay away from high kelvin white or anything blueish as your eyes are most sensitive to those colours. As a result your pupils will have a smaller aperture and that results in less night vision. 1 Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted September 29, 2011 Share Posted September 29, 2011 I'm thinking if a fella wanted to use white LEDs, maybe the "cool white" ones might be easier on the eyes at night?? When you often ride at night you better stay away from high kelvin white or anything blueish as your eyes are most sensitive to those colours. As a result your pupils will have a smaller aperture and that results in less night vision. Except those LEDS will be shining through the stock gauge faces and changing colour anyhow due to the natural tint of the gauge faces, numbers, etc. Quote Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted September 29, 2011 Member Contributer Share Posted September 29, 2011 Stock gauge face is green numbers. LCD would show whatever color bulb you use. I went with blue. It's crisp, but not too bright as to ruin night vision. I guess you could try red if you're concerned. Quote Link to comment Share on other sites More sharing options...
GMTURBO Posted September 29, 2011 Share Posted September 29, 2011 (edited) Red matches my bike better Edited September 29, 2011 by GMTURBO Quote Link to comment Share on other sites More sharing options...
V4 Rosso Posted September 29, 2011 Share Posted September 29, 2011 Except those LEDS will be shining through the stock gauge faces and changing colour anyhow due to the natural tint of the gauge faces, numbers, etc. That's what I expected when I installed white LEDs (there was only one temp of white available at that time) and now the dash is somehat blueish Here is shot of the dash with a stock bulb illuminating the speedometer and white LEDs behind the rpm & fuel gauge. Maybe I'll swap 'em for some yellow LEDs Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted September 29, 2011 Share Posted September 29, 2011 Wow, I really dig the color change as compared to the stock bulb on the left. I'd leave it alone if you were me! Quote Link to comment Share on other sites More sharing options...
JES_VFR Posted October 7, 2011 Author Share Posted October 7, 2011 Well I swapped out the back ground panel bulbs for these http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2FWLED-xHP5.htm And 3 of the idiot lights with these http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2F74-xHP.html And for the turnsignal idicators on I used these. http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2FWLED-x4.htm My flashers were already cycling fast because I have LED's in the back, and I'm adding flush mounted led lights upfront, so I also grabbed one of these. http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2FLFS-1-FLAT.html This module plugged right into the '01 harness and the flashing is slowed back down to a normal rate. The only bulb I did not replace was the FI light. As others have said it glows all time when you try to use a LED. I still have a couple of extra 74 base LED's so I may try adding some resistance to the FI circuit to make it work with the LED. but for now everything in the panel works so I'd rather just get it back together. Quote Link to comment Share on other sites More sharing options...
Member Contributer Daniel Paul Posted January 31, 2014 Member Contributer Share Posted January 31, 2014 Sorry for the thread resurrection, but did you ever have any success with the LED bulb for the FI indicator? Quote Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted January 31, 2014 Member Contributer Share Posted January 31, 2014 I never did. Someone said to wire in a resistor or something. Not worth it to me since it's hardly on. Quote Link to comment Share on other sites More sharing options...
Tews19 Posted August 16, 2015 Share Posted August 16, 2015 I would like to change out the LEDS as well. The link you provided has two different bulbs per link. Which one did you use? Quote Link to comment Share on other sites More sharing options...
Tews19 Posted August 17, 2015 Share Posted August 17, 2015 Placed my order today. I should have them by Thursday which works for me Quote Link to comment Share on other sites More sharing options...
