CandyRedRC46 Posted February 9, 2014 Share Posted February 9, 2014 I'll give the new series rr a try if/when my fh020aa ever dies. Thanks for the info. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Guest Posted February 9, 2014 Share Posted February 9, 2014 What do you guys thin of this http://www.ebay.co.uk/itm/Regulator-Rectifier-Voltage-For-Kawasaki-ZG1400-CONCOURS-14-ABS-2008-2013-/291075030246?pt=AU_Motorcycle_Parts_Accessories&hash=item43c56c7ce6#shpCntId. Its not FH020 but FH010BA but it is just so damn cheap. Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted February 9, 2014 Share Posted February 9, 2014 Smells like Chinese garbage Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Guest Posted February 9, 2014 Share Posted February 9, 2014 Found a cheap FH020 but this picture rang an alarm bell. Any guesses if it is cosmetic damage or something inside the rectifier might have gotten so hot that it has melted the back cover? Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted February 9, 2014 Member Contributer Share Posted February 9, 2014 It is time to update or replace your voltage regulator with the advanced MOSFET type. This modern, ultra-reliable design can handle up to 50amp peaks and 30amp continuous 3 phase, 30amp single phase. It runs cooler than all OEM diode style regulators. In addition, this rectifier has overheat protection, rather than burn up it will simply turn off for a while and cool off. Direct replacement to your original unit. Plug-and-play, direct fit, easy installation. No assembly required Higher grade of electronic components. Improved heat sink and charging capabilities The Quality exceeds the OEM equipment All products shipped are tested One year limited warranty We have even included the opposite connector (main harness side) as we know these are often melted/corroded/defective and a major cause for repetitive electrical issues. http://www.rmstator.com/en/mosfet-regulators-1/mosfet-regulator-rectifier-rm30504h Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted February 10, 2014 Member Contributer Share Posted February 10, 2014 I'll give the new series rr a try if/when my fh020aa ever dies. Thanks for the info. Sent from my iPhone using Tapatalk I am thinking that when Shindengen has their 50 amp unit fully developed, will be the one to go with. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted February 10, 2014 Member Contributer Share Posted February 10, 2014 I'll give the new series rr a try if/when my fh020aa ever dies. Thanks for the info. Sent from my iPhone using Tapatalk I am thinking that when Shindengen has their 50 amp unit fully developed, will be the one to go with. They have been working on it for a long time , personally I think they have stopped . Link to comment Share on other sites More sharing options...
Tightwad Posted February 10, 2014 Share Posted February 10, 2014 It is time to update or replace your voltage regulator with the advanced MOSFET type. This modern, ultra-reliable design can handle up to 50amp peaks and 30amp continuous 3 phase, 30amp single phase. It runs cooler than all OEM diode style regulators. In addition, this rectifier has overheat protection, rather than burn up it will simply turn off for a while and cool off. Direct replacement to your original unit. Plug-and-play, direct fit, easy installation. No assembly required Higher grade of electronic components. Improved heat sink and charging capabilities The Quality exceeds the OEM equipment All products shipped are tested One year limited warranty We have even included the opposite connector (main harness side) as we know these are often melted/corroded/defective and a major cause for repetitive electrical issues. http://www.rmstator.com/en/mosfet-regulators-1/mosfet-regulator-rectifier-rm30504h As wired this will won't work for a VFR. The stator plug is wrong for the 98+ and the R/R plug would only work with 98-99 (but the stator plug is wrong). You can of course use the included adapters to change the bikes wiring...but I prefer to change the R/R wiring to match the bike. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted February 10, 2014 Member Contributer Share Posted February 10, 2014 They sell them bike specific also that was just a pic I captured , I'm not recommending them but they claim 50A capability . Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted February 11, 2014 Share Posted February 11, 2014 Why go through all this trouble of rr research, if your just going to use the rr/stator connections that always burn up and fail? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted February 11, 2014 Member Contributer Share Posted February 11, 2014 Why go through all this trouble of rr research, if your just going to use the rr/stator connections that always burn up and fail? Sent from my iPhone using Tapatalk Not me I learnt my lesson ... Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted February 11, 2014 Share Posted February 11, 2014 Me too. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Guest Posted February 12, 2014 Share Posted February 12, 2014 Found an used FH020 and will go with that. Hopefully problems solved. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted February 12, 2014 Member Contributer Share Posted February 12, 2014 Yeah good choice ... Link to comment Share on other sites More sharing options...
Tightwad Posted March 5, 2014 Share Posted March 5, 2014 Why go through all this trouble of rr research, if your just going to use the rr/stator connections that always burn up and fail? Sent from my iPhone using Tapatalk Because the connectors are a symptom, not the problem. It's like bypassing a fuse that keeps blowing, sure the fuse doesn't blow but now you have pushed the issue into a more critical part. The connectors are not designed to act as a fuse but if you bypass them you risk the issue showing in other, harder to fix, areas. Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted March 6, 2014 Share Posted March 6, 2014 They still fail even with a healthy charging system. My friend just got a cherry superhawk. The charging system went out. I talked him into getting an FH020AA regulator rectifier and an OEM Stator, but I could not convince him to direct solder the connection between the two. The connection lasted a month and burned up. I had a lot of fun at his expense and then we cut it out and soldered it. It has been fine ever since. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Tightwad Posted March 11, 2014 Share Posted March 11, 2014 They still fail even with a healthy charging system. My friend just got a cherry superhawk. The charging system went out. I talked him into getting an FH020AA regulator rectifier and an OEM Stator, but I could not convince him to direct solder the connection between the two. The connection lasted a month and burned up. I had a lot of fun at his expense and then we cut it out and soldered it. It has been fine ever since. Sent from my iPhone using Tapatalk what did he use for connections? 1 month sounds very suspect....people ride these bikes for decades with less issues. Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted March 13, 2014 Share Posted March 13, 2014 Some people get lucky. My oem connection burned out in 2010. My bike is a 2007. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted March 13, 2014 Member Contributer Share Posted March 13, 2014 my oem flatpack RR lasted 16 years......... Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted March 13, 2014 Share Posted March 13, 2014 That is crazy. Bike must live in a garage. And be ridden with RPMs low and in cold ambient temperatures. That or you're just the luckiest guy alive lol Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted March 13, 2014 Member Contributer Share Posted March 13, 2014 The latter!!!!! Sent from my HTC Desire S using Tapatalk 2 Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted October 8, 2014 Member Contributer Share Posted October 8, 2014 Switchblade! Any update on the SH775? Still running it, and why do you not have any confidence in it as stated in earlier posts? I've got the FH012 in mine, and it seems to be going great for several years. But now that I'm basically 100% LED I'm wondering if I should be going with a series. I put a CompuFIre in my RC51, but Timmy's got that now. Should be better in that application since it's a twin and RPM's stay a bit lower. Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted October 8, 2014 Share Posted October 8, 2014 I installed an SH775 in my friends 2009 zx6r about five months ago. Its still running fine. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted October 8, 2014 Member Contributer Share Posted October 8, 2014 I installed an SH775 in my friends 2009 zx6r about five months ago. Its still running fine. Mine is 17 months old. Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted October 8, 2014 Member Contributer Share Posted October 8, 2014 Why did you feel like it wouldn't hold up? Link to comment Share on other sites More sharing options...
