removing rear axle
V4 Rosso
  • Replies 58
It's times like this I get angry with mechanical things. And it's times like this I look at the thing as my enemy, smiling and laughing at me.
This is when I'd put the axle in a big hydraulic press and enjoy the sound it makes as it pops out. Like tying my enemy up and shooting him in the kneecaps. After all, it's become personal.
P.S Please keep posting on this problem - I'm really super keen to find out what the problem was!
Sorry for the late entry into tonights show, but I have was delayed by our sponsors...Anyway, just as the previous posters have suggested, apply some penetrating oil, let it sit for a little while, try to rotate the axle from the right side, as you whack it from the left. I used a 4 x 4 piece of wood placed against the axle, and gave it a good whack or three, and she popped out. Is there any side-to-side movement at all when the c-clip is removed, or is it really bound up? Installing the nut prior to using the wood is also good, as it give a bigger surface area for whacking...My bike is still waiting for the forks to be finished, the dang ducati Shop at the Nurburgring is taking their time, time I'm not happy giving!!!
It's out! :cheerleader:
With some bits and pieces I had laying around I modified the puller. While holding the axle nut with a spanner I spun the axle using a steel bar wedged between the wheel studs (with the wheel nuts installed not to damage the thread) and with a lttle effort the axle slid out of the bearing holder. After the axle had moved 1/2" it gave up most of it's resitance and I cold spin the axle by hand.
DIY axle puller
As I expected it was old gummed up grease that prevented the axle from sliding out of the bearings. This would have never come out whacking it with a hammer.
Old grease sticks like glue
The bearing holder came out fine.
The bearings are still in great shape, no play in them whatsoever. They'll get some fresh grease and new dust seals will be installed.
Thanks everyone for your mental support and ideas :fing02:
Congrats!
That's not just grease, there's rust in there too. Clean it with solvent and then wire wheel the rust off. Get it nice and shiny clean again, then add your new grease(and maybe some anit-seize!).
Thanks for confirming the bearings are still in great shape, it means I will leave mine well alone.... :laughing6-hehe:
Zo, nu eerst een Bavaria.......... :beer:
Success!!!... I like your pusher... lets see a pic of the axle bearing surface...
I offer my method to clean both the axle and bearing...
Once you have the bearing removed you employ a two jewelers screw
drivers and carefully lift each roller from the cage...
Give the rollers and cage a bath in gasoline... you be surprised at
all the dirty deposits hidden in the old grease and every nook and
cranny... you're looking at the deposits after only 10K miles of
normal operation...
Once the bearing are really clean lay them out and inspect each roller
for scoring...
Dirt mixed with the old grease will leave a trail of deposits on the
axle at point B...
Spun in a Lathe... it's easy to remove the deposits employing a gray
micro fine 3M pad... it's soft enough that it does *not* remove any
precious metal...
What you'll end up with is an axle with the deposits remove plus
giving the metal a nice luster...
precious metal...
I wish I had the tools in my shed to clean the axle your way Larry. I did however once clean the caliper pistons using a small woodworking lathe :biggrin:
I had to resort to using a nylon brush and some solvent. Still, it cleaned up nice:
Fortunately I didn't need to use a wire wheel/brush. The clay like substance came off fairly easy :fing02:
sweet! let's schedule a ride.
saturday's weather looks perfect.
I allready have plans for saturday, sunday maybe ?
Er gaat (bijna) niets boven een lentebock na het gedane werk. :beer:
With Sunday being Mothersday.................... :laughing6-hehe:
that doesn't concern me... but there is a forecast for some rain on sunday. maybe that'll change.
  • 1 year later...
Well....looks like I'm going to need that bearing puller from work tonight..
The other one came apart easy. Must be something with these 4th gen rear axles.
DIY axle puller
Good grief that is the most Rube Goldberg contraption I think I have ever seen!
I like it! :laugh:
and that is why I'm leaving my rear axle WELL alone........ :tongue:
Just crushed in some thick aluminum tubing trying to pull the spocket carrier off. Liquid wrench not penetrating. Torching not helping. Going to take it to work and use the press to try and get it off that way.
C'mon. Why don't we just take it on faith? I'm a trustworthy guy, right?
Nice and rusty. Oddly enough the spindle nearly fell out when I loosened the pinch bolt.
