Member Contributer YoshiHNS Posted January 17, 2014 Member Contributer Share Posted January 17, 2014 Wow. Someone really wanted those forks on that bike. And I'm a little bit confused on what's going on with the top stem nut, er..bolt? Quote Link to comment Share on other sites More sharing options...
wera803 Posted January 17, 2014 Share Posted January 17, 2014 Not sure about that nut. I thought the same thing. Same guy did this upper. Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted January 17, 2014 Member Contributer Share Posted January 17, 2014 Boy, those have got a lot of meat on them... I guess they are going for the industrial look Quote Link to comment Share on other sites More sharing options...
SEBSPEED Posted January 17, 2014 Share Posted January 17, 2014 Boy, those have got a lot of meat on them... I guess they are going for the industrial look It's not that they have a lot of meat... well, it is,... but that's because they've skipped a lot of the dress-up features which drive up the labor and therefore the cost. I do the same with my custom sets. I made these for a guy who wanted to adapt Hayabusa forks to a GS1000- This is one of the more fancy parts I've made. Still basic, but has a nice shape. Counterboring the stem pinch bolt was slightly challenging. 2 Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted January 17, 2014 Member Contributer Share Posted January 17, 2014 Boy, those have got a lot of meat on them... I guess they are going for the industrial look It's not that they have a lot of meat... well, it is,... but that's because they've skipped a lot of the dress-up features which drive up the labor and therefore the cost. I do the same with my custom sets....This is one of the more fancy parts I've made. Still basic, but has a nice shape. Counterboring the stem pinch bolt was slightly challenging. I guess that is more accurate... the other shape was blocky, less work put into the aesthetics. Your work looks outstanding with nice shape, form, and function. Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted January 18, 2014 Member Contributer Share Posted January 18, 2014 Does anyone have a CAD drawing or similar format for 54/50 triples with VFR geometry to loan or sell that will allow me to provide to a machine shop for a quote? Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted January 22, 2014 Member Contributer Share Posted January 22, 2014 Does this mean I get my $250 deposit back ? Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 Does this mean I get my $250 deposit back ? ??? Was there a custom triple group buy that I'm unaware of? Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 I'm mess around with CC ... Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 Anybody have VFR800, RC51, 929/954 steering stem available for measuring? What is the length of the steering stem? Someone posted earlier a link to a fork conversion table for All Balls Racing and I'm trying to see if there are other options... the unknown is the steering stem length. Quote Link to comment Share on other sites More sharing options...
SEBSPEED Posted January 23, 2014 Share Posted January 23, 2014 Just go buy a used Honda triple for as little $$ as possible, and take the stem out. In an accident, 9 times out of 10 the stem is fine and the triple gets tweaked. So finding a cheap tweaked triple with a good stem should be easy. Then you can press that into your new custom lower triple. Quote Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 The all balls site has the fork conversion. You look up your bike and it gives the steering head bearing ID, OD, and heights, and those of other bikes that are or are close to the same. It's up to you to figure out which bearings you need to use and decide if it is really going to work. Quote Link to comment Share on other sites More sharing options...
SEBSPEED Posted January 23, 2014 Share Posted January 23, 2014 The all balls site has the fork conversion. You look up your bike and it gives the steering head bearing ID, OD, and heights, and those of other bikes that are or are close to the same. It's up to you to figure out which bearings you need to use and decide if it is really going to work. It gives you bearing stack heights, not stem lengths. Quote Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 The all balls site has the fork conversion. You look up your bike and it gives the steering head bearing ID, OD, and heights, and those of other bikes that are or are close to the same. It's up to you to figure out which bearings you need to use and decide if it is really going to work. It gives you bearing stack heights, not stem lengths. Right, just bearing dimensions. So it will give you an idea if a different stem even has a chance to fit. Still need to get the stem lengths and compare. Quote Link to comment Share on other sites More sharing options...
V4 Rosso Posted January 23, 2014 Share Posted January 23, 2014 CBR929/954: from base of the lower triple to the top 8"7/8. Bearing surfaces on the steering stem are spaced 7" apart (outer dimension). Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 CBR929/954: from base of the lower triple to the top 8"7/8. Bearing surfaces on the steering stem are spaced 7" apart (outer dimension). Thanks Man! Anybody know if the RC51 is the same? Just go buy a used Honda triple for as little $$ as possible, and take the stem out. In an accident, 9 times out of 10 the stem is fine and the triple gets tweaked. So finding a cheap tweaked triple with a good stem should be easy. Then you can press that into your new custom lower triple. Will the VFR (or RC51 or 929/954) stem be long enough if the custom triples are... let's say, an 1" thick aluminum alloy? Quote Link to comment Share on other sites More sharing options...
SEBSPEED Posted January 23, 2014 Share Posted January 23, 2014 It doesn't matter how thick the triple is really. You'll just size the hole and then press the stem to the depth required to achieve the height above the top surface of the triple. Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 In this day of customizing everything it is hard to believe nobody what produce a generic blank (Honda or Kawasaki or whatever) triple that can be bored to the bottom that you wanted to use .... Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted January 24, 2014 Member Contributer Share Posted January 24, 2014 CBR929/954: from base of the lower triple to the top 8"7/8. Bearing surfaces on the steering stem are spaced 7" apart (outer dimension). When using the CBR929/954 for a fork swap are there any threads exposed above the top nut? If yes, how far does it extend past the nut? If it doesn't extend beyond the nut is there complete engagement of all the nut threads with the steering stem? Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted January 25, 2014 Member Contributer Share Posted January 25, 2014 Would a complete '01 CBR954 front end (forks, triples, wheel, rotors) be a pretty much straight bolt on for a 4th Gen? Quote Link to comment Share on other sites More sharing options...
SEBSPEED Posted January 25, 2014 Share Posted January 25, 2014 Yes. Quote Link to comment Share on other sites More sharing options...
Member Contributer JamieDaugherty Posted January 26, 2014 Member Contributer Share Posted January 26, 2014 In this day of customizing everything it is hard to believe nobody what produce a generic blank (Honda or Kawasaki or whatever) triple that can be bored to the bottom that you wanted to use .... I wish it was that easy! In the end I've found that I can make custom triples to the precise dimensions I want for about the same price. It pays to have suppliers that you've developed a good relationship with! 1 Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted January 26, 2014 Member Contributer Share Posted January 26, 2014 In this day of customizing everything it is hard to believe nobody what produce a generic blank (Honda or Kawasaki or whatever) triple that can be bored to the bottom that you wanted to use .... I wish it was that easy! In the end I've found that I can make custom triples to the precise dimensions I want for about the same price. It pays to have suppliers that you've developed a good relationship with! Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted January 26, 2014 Member Contributer Share Posted January 26, 2014 I've spent hours researching offsets and trail numbers and reading Race Tech's Motorcycle Suspension Bible. The data shows most of the best handling bikes have around a 30mm offset with high 90s to low 100s trail values (CBRs, GSXRs, R1s... early R1s and RC51s are exceptions) and rakes of 23* to 24*; this was also confirmed by a reliable suspension expert. The stock 5th gen VFR chassis geometry doesn't cut it for this application... and it wasn't designed too. No fault, no grandiose claims that I can engineer better than Honda. Just me attacking a challenge to take something I love and adapt it to a new, more specific application. Based on this, and some more expert input, I'm going to shoot for an initial set-up of 30mm offset, around 102mm trail, and ~24* rake on my 5th gen track bike. My '09 ZX14 50/54 USD forks are scheduled for delivery tomorrow... so I can start the measuring and wrenching and stop the jabbering!!! Build thread to follow... Quote Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted January 26, 2014 Member Contributer Share Posted January 26, 2014 My unscientific and nearly accidental settings are CBR/RC51 offset, combined with the front as low as the clutch master cylinder allows (due to hitting the fork) and the rear end shimmed 5mm on the shock mount bolt. It's stock length, and that's where I ran out of threads. Turns out it works. At least for me. Quote Link to comment Share on other sites More sharing options...
