Member Contributer taglicious Posted February 10, 2011 Member Contributer Share Posted February 10, 2011 http://cgi.ebay.com/ebaymotors/GALINDO-SUPER-BIKE-GRIPS-LONG-7-8-130MM-BLACK-SPORT-_W0QQcmdZViewItemQQhashZitem564273f05fQQitemZ370482081887QQptZMotorcyclesQ5fPartsQ5fAccessories love these... an entire year on them before I had to change them... outsides were worn off... very comfy take any and all road vibrations... soft but not squishy hard but not too hard... medium mix for comfort and longevity.. used them for quite some time on several bikes. Link to comment Share on other sites More sharing options...
Member Contributer doubled Posted February 10, 2011 Member Contributer Share Posted February 10, 2011 Open end. You have bar ends right? Yes, thank you. I noticed on the Pro Grip 719 that it looked like there was an opening for a screw on the closed end version, so I wanted to double check with you guys. Link to comment Share on other sites More sharing options...
Guest Posted February 10, 2011 Share Posted February 10, 2011 Oury road grips are the best... have them on all but the Gixxer and spares ready incase any wear out. +1 on the Oury!! Link to comment Share on other sites More sharing options...
Guest Posted March 23, 2011 Share Posted March 23, 2011 ProGrip 714 - Yes, the "Rally Grips" that are probably intended for dual sports. I got hooked on them back when I had El Grande Bandito - the B-12 Bomber Vibration Machine. Large diameter & a bit of squish without loss of road feel & feedback. They're going on with the new LSL bar kit... along with an NEP cruise that will work, unlike my Throttlemeister! Link to comment Share on other sites More sharing options...
MRChickhabit Posted July 6, 2011 Share Posted July 6, 2011 Pro Grip 714 Dual Sport Grips http://www.motorcycle-superstore.com/2/9/192/19546/ITEM/Pro-Grip-714-Dual-Sport-Grips.aspx?WT.ac=Recently_Viewed I had these on my 1982 honda cm450 for almost 5 years (she blew up on the freeway) the 714s give me NO fatigue, no pain, and feel great. they aren't open ended, but a knife fixes that. with a little glue they fit nice and snug on my fifth gen. Link to comment Share on other sites More sharing options...
Metallican525 Posted July 9, 2011 Share Posted July 9, 2011 Pro Grip 714 Dual Sport Grips http://www.motorcycle-superstore.com/2/9/192/19546/ITEM/Pro-Grip-714-Dual-Sport-Grips.aspx?WT.ac=Recently_Viewed I had these on my 1982 honda cm450 for almost 5 years (she blew up on the freeway) the 714s give me NO fatigue, no pain, and feel great. they aren't open ended, but a knife fixes that. with a little glue they fit nice and snug on my fifth gen. Hey, yeah, them's the same ones I'm runnin on my 6th gen too. Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted July 9, 2011 Member Contributer Share Posted July 9, 2011 The BLS method of removing grips without destroying them... 1)slip a rat tail comb under the grip... 2)trickle alcohol down the length of the gap created by the comb... 3)remove comb and twist the grip to work the alcohol in between grip and throttle barrel... Best grip I found is Spider Grips... Spider Grips feature durable variable density elastomers, patent pending shaped boundary layers with isolated secondary layers, energy dispersing flanges, and a multi-faceted geometric surface area. Spider Grips are manufactured in Taiwan and distributed by Pit Bull. Ride with Spider Grips and you'll feel less vibration, which in turn means less fatigue. You can give up the death grip hold, so you won't get arm pump and you'll be able to ride longer. Special grip material works great, even when wet. Sold at Pit Bull... http://www.pit-bull....ode=spidergrips Link to comment Share on other sites More sharing options...
Member Contributer speedball73 Posted August 29, 2017 Member Contributer Share Posted August 29, 2017 On 1/21/2011 at 10:30 AM, Knife said: The stock grips feel as thin as a pencil to me. I just installed Koso heated grips and they are just the right diameter. I'll slip Grip Puppies over them for long rides (for comfort). Knife - how are the Koso grips holding up? -speedball Link to comment Share on other sites More sharing options...
