Hossackviffer Mkii
redmarque
Just thought i'd let you guys know what's happening...
I've had a couple of email communications with Norman Hossack which has been quite usful.
Norman stated in one of his emails that he wouldn't build one of his designs with less than 24 degrees rake.. i'm still waiting for a reply as to why he thinks that - will have to wait and see.. seams to have the opposite opinion to others.
Based on this and my own thoughts I've decided to relax the rake angle on the design from 17 to 20 Degrees, mainly this will allow the handlebars to be nearer the rider and give the bike a more conventional look overall. (standard fairings should fit better) i'm still on the look out for a used cbr600rr top and middle panels but tempted to buy a race fairing because the're cheap and available.
As to frame material 4130 now seams the best choice. my welding grasstrack friend tells me that he's found that it doesn't distort as much as T45 or CDS5 tube.
Currently i'm calulating how much tube/steel i'll need to buy.. crunch time's here. Hand over the money!
Red
Red
4130, fantastic! it should come up to be a fine, strong and light frame for the bike. A "Reynolds TI" sticker on it might look good too, if that's what you will be using.
Are you planning to powdercoat or polish/nickel chrome the frame..ala Harris??
I vote for powdercoat...red would be nice, but I've seen some black powdercoated frames on late model KTMs that also look great.
Beck
95 VFR
Cheers Guys!
Powercoat satin black for the frame - or red not quite sure yet. mixture of Gloss and Matt Black bodywork...
Like a KTM RC8R (big fan of these)
I've picked up a 2005 Ducati 999 top fairing which could be good if I re-locate the stacked projector holes to side by side. now looking for the mid fairing sections.
Cheers Guys!
Check out the chinese kits, they're cheap!
I am just a spectator for this but - Very cool! - -- I am amazed by all the technical talent we have on this web site.......
MD
Edited by mello dude
  • 4 weeks later...
Cheers Baketech - will have a look at that issue of BIKE.
Hugo's Morlaco was a great infulence on my MK1 original design, which you've probably noticed! :fing02:
Have you seen his Moto2 bike: www.bottpower.com
As always I've had some non-bike projects/work have been in the way recently.
Updates on the bike:
Revised the latest design. Main tubes are 1.125 inch and joining tubes 1 inch. rear of fork legs are now 1.125 dia.
Ordered the 4130 steel tubing yesterday - so hopefully will have something real/progress to show in the next couple of weeks.
Now that's a very cool looking machine.. frontend is a girder with headshock though. (like a confederate wraith)
Edited by redmarque
  • 1 month later...
I know It’s been awhile… but I’ve had some time to spend on Mk2!
Frame fixture/jig is almost complete, some shimming and repositioning will be required once the tubes are cut and in place.
Tubing profiles are all unwrapped from the CAD model. Some scratching of head will be involved to make a template for the bent connecting top tube. Also the order in which the tubes must be fitted and welded has to be worked out so they all go in without problems.
In preparation for reworking the rear sub-frame design, I’ve purchased a pattern rs125 seat unit. It will require some “modification” to blend from the tank cover… but I’m please with the general look.
You can always count on SEB for encouragement! Cheers! :cheerleader:
Liking the LED stip tail-light idea too... how about a cylon/night rider effect on switch on? :cheerleader:
http://www.youtube.com/watch?v=FLk0Ye2Vo7Y
This has been very handy over the last few weeks.. making sure that the horizontal/verital tubes are perfectly alined to each other. It can be zeroed at any angle for reference and acurate to .1 Degrees.
I've been looking locally for one of those angle finders, but haven't found one. I'm going to have to order one online, I'm sure I have a few uses for one!
And yes, you can buy a module that will run your led's like that... :cheerleader: lol
Got the angle gauge from 'ebay' for about £23 UK pounds.
Here you go Seb. It's a cut and shut job of the standard 5th Gen mounting and a trimed down 600RR caliper mount with 8mm 6082 T6 plate shaped and welded in between (it's not my welding btw)
I had to grind down the caliper's back to get the wheel spoke clearance. whether this setup will work well has yet to be proved as the caliper is back to front on the disc...
Cut the front upright tubes using the paper profile and careful use of angle grider!
Sure enough they fit perfectly!
I've been following this for quite a while, and I'm glad to see you getting it together. Take your time and get it right. The suspense is worth it.
A VFRD Member asked me about my rear caliper mod and how I delt with the torque arm.
So hopefully this will help explain with pictures..
I trimed off the orginal mounting from the existing torque arm plate.
Backside of the caliper needed to be trimed down to miss the wheelspokes - there is still plenty of metal left
Removed the CBR600RR axle mounting and mated between the two by welding in profiled 8mm thick 6082 plates
If i was making this again I think I would have positioned the caliper upright or slightly forward of the axle.
Replaced the stock mounting bolts with stainless items and machined the bolt heads to make the wheel sit flush.
There's curtainly some weight loss over stock; plus mounting the caliper above the arm will cut down on the amount of dirt, brake dust and corrosion.
Rear wavy disc is from "BRAKING" http://www.braking.com/bk/sito.asp?pag=4
Edited by redmarque
I like your idea of moving the caliper forwards, it would have the benefit of positioning the bleeder nipple upright, so you could bleed the rear caliper without removing and repositioning it, which is one of my beefs with the stock 5th gen setup.
Nice work Red, and I can't wait to see HossackViffer MK II on the road.
You should powdercoat the frame Red like a Ducati! :blink:
CBR600F4i caliper has the same mounting pattern, but the banjo bolt and bleeder are swapped. Little known fact. wink.gif :beer:
