Guest VFRoj Posted May 10, 2008 Share Posted May 10, 2008 I'm currently in the process of yet another new way to modify the exhaust. This way, while requiring patience, is very easy and does not require removal of the exhaust, loosening of the exhaust, or even removing the end covers off the exhaust. No welding required... It can also be done in stages, so you can check & evaluate the sound level before going further. I do caution that you do Stage 1 and ride the motorcycle through at least a tank full of gas, as the sound gets noticeably deeper and louder after running with even the "Stage 1" mod (it has to be the cat deteriorating due to more flow / less restriction through the modified exhaust). This is a different version of the "new way to 'gut' your exhaust" post, so I suggest that you read that post, then refer back to this one...I will post up the complete process with pics once I've completed the whole job this weekend...if anyone's interested. The difference is that I used a 1" bimetal hole saw (as suggested by VWRXTDR). I was able to drill between the outer tip and the inner tip of the exhaust exits, which releases the inner pipe from the outer exhaust tip. I was then able to reach into the inside pipe with a Dremel (no extension needed) and cut the inner pipe loose, then pull it out. The outer exhaust tip stays in place, which helps in a multitude of ways: 1. No fear of water getting into the cans. 2. No fear of the end caps blueing (important for me, as I'll be putting CF covers and end caps on). 3. The tips look good (if you like stock). 4. Sound is mellow and deep; louder than stock, but not in any way excessive. As someone suggested, the tips seem to take some of the "ping" out of the sound. 5. Close to being a "big hole" type gut, as the exit holes are now a full 1" diameter, instead of the 3/4" diameter of the inner pipes. The beauty of this mod is that you are essentially making the muffler a "straight thru" design, much like a total gut, without all the cutting, beating, welding, removing of the exhaust, etc...It maintains enough baffling to take the edge off, while maintaining a deep tone with a nice volume. "Stage 1" (Upper pipes in each muffler only) sounds very good at idle (deep and mellow). Very controllable noise level when accelerating (nice when you leave for work early in the morning); can hear the exhaust up to about 50 mph with Stage 1 (which is the top pipe in each can modified). I will be doing the bottom two pipes in each can this weekend (Stage 2). If anyone's interested, I'll post pics and try to do a sound clip of "Stage 1" and "Stage 2". There's also some tricks I learned while doing this that are essential to being able to drill between the exhaust tip and the inner pipe...One other note: The lean surging I was experiencing before at steady throttle while cruising at highway speeds is gone. The VTEC transition is also dramatically smoother. Anyone have an explanation for this? Roj Link to comment Share on other sites More sharing options...
vwrxtrd Posted May 10, 2008 Share Posted May 10, 2008 Here are some pics of mine, I did have to remove the end pipes because I don't have a dremel extension so I could not get in far enough with the end pipes on. I will have the end pipes welded back on soon. Link to comment Share on other sites More sharing options...
Member Contributer Ducatti20 Posted May 10, 2008 Member Contributer Share Posted May 10, 2008 I'm currently in the process of yet another new way to modify the exhaust.This way, while requiring patience, is very easy and does not require removal of the exhaust, loosening of the exhaust, or even removing the end covers off the exhaust. No welding required... It can also be done in stages, so you can check & evaluate the sound level before going further. I do caution that you do Stage 1 and ride the motorcycle through at least a tank full of gas, as the sound gets noticeably deeper and louder after running with even the "Stage 1" mod (it has to be the cat deteriorating due to more flow / less restriction through the modified exhaust). This is a different version of the "new way to 'gut' your exhaust" post, so I suggest that you read that post, then refer back to this one...I will post up the complete process with pics once I've completed the whole job this weekend...if anyone's interested. The difference is that I used a 1" bimetal hole saw (as suggested by VWRXTDR). I was able to drill between the outer tip and the inner tip of the exhaust exits, which releases the inner pipe from the outer exhaust tip. I was then able to reach into the inside pipe with a Dremel (no extension needed) and cut the inner pipe loose, then pull it out. The outer exhaust tip stays in place, which helps in a multitude of ways: 1. No fear of water getting into the cans. 2. No fear of the end caps blueing (important for me, as I'll be putting CF covers and end caps on). 3. The tips look good (if you like stock). 4. Sound is mellow and deep; louder than stock, but not in any way excessive. As someone suggested, the tips seem to take some of the "ping" out of the sound. 5. Close to being a "big hole" type gut, as the exit holes are now a full 1" diameter, instead of the 3/4" diameter of the inner pipes. The beauty of this mod is that you are essentially making the muffler a "straight thru" design, much like a total gut, without all the cutting, beating, welding, removing of the exhaust, etc...It maintains enough baffling to take the edge off, while maintaining a deep tone with a nice volume. "Stage 1" (Upper pipes in each muffler only) sounds very good at idle (deep and mellow). Very controllable noise level when accelerating (nice when you leave for work early in the morning); can hear the exhaust up to about 50 mph with Stage 1 (which is the top pipe in each can modified). I will be doing the bottom two pipes in each can this weekend (Stage 2). If anyone's interested, I'll post pics and try to do a sound clip of "Stage 1" and "Stage 2". There's also some tricks I learned while doing this that are essential to being able to drill between the exhaust tip and the inner pipe...One other note: The lean surging I was experiencing before at steady throttle while cruising at highway speeds is gone. The VTEC transition is also dramatically smoother. Anyone have an explanation for this? Roj Pics and sound clips would be great... Link to comment Share on other sites More sharing options...
Guest Posted May 11, 2008 Share Posted May 11, 2008 Here's some pics of what you'll need to do this mod, along with a sequence and details. I'll post a sound clip once I finish up with "Stage 2" tomorrow. Here's what "Stage 1" looks like, with only the top opening of each muffler modified. You can see the exhaust tip still in the opening, with the inner pipe removed to a depth of about 1.25". Close up looking down the exhaust tip...outer exhaust tip still in place. Full rear shot of bike. Looks virtually stock. More mods to come, though! All the tools and items you'll need to do this mod: Be sure and get two 1" bimetal hole saws, as you'll most likely ruin the first when starting the cut between the two pipes. Once started, use the good remaining bit. Close up of the hole saw and the dremel cutting wheels. Shows the 1" bimetal hole saw going over the inside pipe and inside the outer exhaust tip. You'll have to use lots of cutting oil, low rpms on the drill, and be patient. Remove the bit and use a flat screwdriver to wipe out the metal shavings at regular intervals, as the shavings have no where to go, and will destroy the bit if not removed. You will be removing some of the inside pipe, which makes more shavings. Be sure to drill far enough in to cut through the shoulder of the inside pipe that is formed where it's welded to the end of the muffler. Do this before you use the dremel to cut the inside pipe out, or it'll be very hard to do later with the pipe loose (don't ask how I know this). The shoulder needs to be gone to remove the cut off pipe through the outer exhaust tip. Dremel position when cutting around inner circumference of inside pipe. No need for the flexible extension, as it really doesn't get you any further into pipe. You can remove about 1.25" of the inside pipe with the dremel alone. Victory! Just do this 3 more times and ride. Enjoy! Link to comment Share on other sites More sharing options...
?art West-VL. Posted May 11, 2008 Share Posted May 11, 2008 Thanks a lot‼ :biggrin: Link to comment Share on other sites More sharing options...
Guest Posted May 11, 2008 Share Posted May 11, 2008 Sorry the pics are so small (anyone know how to make them bigger?). If you need more detail on the pics, you can see them in my photo gallery (they're much bigger in the gallery). Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted May 11, 2008 Share Posted May 11, 2008 Sorry the pics are so small (anyone know how to make them bigger?).If you need more detail on the pics, you can see them in my photo gallery (they're much bigger in the gallery). Fxd. Link to comment Share on other sites More sharing options...
Member Contributer Ducatti20 Posted May 11, 2008 Member Contributer Share Posted May 11, 2008 Interesting... can't wait to hear a sound clip Link to comment Share on other sites More sharing options...
Member Contributer windwalker Posted May 11, 2008 Member Contributer Share Posted May 11, 2008 Nice write up R, Looks like something even I may be able to do. Hey, are you sicking your dog on me? I changed my pic, as I have found one that compliments the one we both liked. I guess great minds think alike, wecome aboard. Link to comment Share on other sites More sharing options...
Guest Posted May 11, 2008 Share Posted May 11, 2008 Hey Windwalker, Didn't want to confuse too many people with the same avatar...didn't mean to take yours, so I thought I'd change mine. One other note on the mod, if you're thinking about trying it. Be sure to use the "old" hole saw to start each cut on each pipe, as it's pretty hard on the bit to get the cut started. Once you get it started, use the good bit. Thanks for reply...and I like the new avatar! Roj Link to comment Share on other sites More sharing options...
Guest Posted June 9, 2008 Share Posted June 9, 2008 I thought this was a great idea so I tried it yesterday... what could go wrong? Thought I'd post something to look out for though... I basicly followed the steps as set forth by this thread and the other. I did buy 2 hole saws as well, same brand in fact. Actually my cutting blades were the same as well... I think. One of the hole saws I had, after I opened the package, I noticed that some of the teeth were a little out of alignment which didn't allow it to fit in the hole... no comment... so I just hammered them back into place... no problem. I got to drilling and it seemed to cut just fine. Apparently when I was finished some of those teeth had grabbed the inside pipe and twisted it beyond recognition. I thought, "no big deal, I need to cut it out anyways, so I did the other top one on the other side... same thing. Then I go to cut it out. Couldn't get my cutting blade in there due to the diameter of the hole... After grinding the blade a little... PIA by the way... I had to grind the blade so small that by the time I got it in there i'd cut for about 3 seconds before the blade needed to be changed. Well I decided to wait and do the last two holes with the other hole saw... Those worked perfectly... meaning it left the inner pipe intact. So I tried to cut those out... I have to say that ya'll have much more patience then me. By the time I got the blade filed down enough, I went though about 6 or 7 blades... sitll couldn't see I made any impact on the inner pipes... Any ways, it does sound much better but I haven't gottne the inner pipes out yet, none of them. Thought I'd just post to make sure the next person is aware of the hole saw... MAKE SURE THE TEETH ARE PERFECTLY ALIGNED! I'm down, so to speak, but I'm not out yet. I'll give it another crack at it later. I'm going to Austin this weekend to the ROT Ralley so I'll probalby waite until I'm back from that to finish up. Chad Link to comment Share on other sites More sharing options...
Guest Posted July 22, 2008 Share Posted July 22, 2008 I did the "stage 1" mod last night on my '02 and it went fairly smoothly. I used oil on the 1" blade and it seemed to work well and keep things moving smoothly. I had to bend in several of the teeth to get it to inside the tip, but it worked out fine. On the first one I cut, I did not saw past the shoulder, so once I had finished the dremel section, I couldn't get the piece out! I ended up having to use a combination of pliers and clamps to get it out and it was definitely a pain. The second one I cut went perfectly. I cranked it up this morning and it sounds good. I'll have to take it out for a spin tonight to really assess the sound. I guess I just want to reinforce what VFRaj said in his original writeup about making sure you cut past the shoulder. The shoulder weld is about 1/8" of an inch thick, so once you've cut through the inner tip and you can wiggle the inside pipe around, then cut another 1/8" until it's pretty obvious that you can just pull the sucker out once you've sliced it from the inside. I'll post a vid on youtube for sound when I get a chance. -Ryan Link to comment Share on other sites More sharing options...
Auspanglish Posted July 28, 2008 Share Posted July 28, 2008 Any follow up on this? Any comments on the difficulties these last few posters have had?? Sound clips?? Link to comment Share on other sites More sharing options...
Member Contributer FotoMoto Posted July 28, 2008 Member Contributer Share Posted July 28, 2008 Any follow up on this? Any comments on the difficulties these last few posters have had?? Sound clips?? Just now seeing this thread. I hate to rain on VFRoj's parade but IIRC this method is the original one from the 2002-03 era. I did my first vtec this way. It sounded great and is one of the best "free" mods around but I eventually got greedy and sawed off the end caps, removed the remaining baffles, and had a welder reattached the end caps for about $40. Big, deep noises that rivaled any exhaust; however, I grew tired of the stock look, weight, and especially the heat of the stainless cans and went with a carbon fiber solution and have used ever since: Custom D&D pipes termi's Ducati Termignoni exhaust on an 02 VTEC. Custom Termignoni's Leo Vince Link to comment Share on other sites More sharing options...
Member Contributer FotoMoto Posted July 28, 2008 Member Contributer Share Posted July 28, 2008 Sound clips?? First sounds like a full bafflectomy while second sound like a lite version: Link to comment Share on other sites More sharing options...
Auspanglish Posted July 29, 2008 Share Posted July 29, 2008 Sound clips?? First sounds like a full bafflectomy while second sound like a lite version: Hmmm, the first one is quite impressive. Would be good in these vids if they had an untouched one going by as well to compare the two... but it certainly seems throatier and more resonant... do I detect a slightly tinny aspect?? Still for the price, sounds good... wondering if those pipes that are cut free are just dangling around in there and with time will droop and vibrate against the outer shell?? Link to comment Share on other sites More sharing options...
Guest Posted July 31, 2008 Share Posted July 31, 2008 video clip: I finished my exhaust mod using this method and I really like it. I've ridden about 300 miles since the mod and it's exactly what the VFR was missing when I first bought it. I'm psyched. -Ryan Link to comment Share on other sites More sharing options...
Auspanglish Posted January 4, 2009 Share Posted January 4, 2009 Well, I bought all the hardware to do this job... even a Dremel which sort of blew the budget but I hope it will come in handy for many a future job... Thing is, the hole cutters I bought (25mm) do NOT fit over the inner pipe. They butt up against the end of this pipe. The teeth are, as mentioned by others, offset, one inward, one outward and so on... but even if I could straighten them out (they just snap off), I don't think it would fit over the inner pipe anyway... maybe it's a question of slight variations in the sizing from one brand to another as I couldn't find the brand as seen in the photos above. Frustrating as I've already invested in the Dremel... and them hole cutters ain't cheap either... Link to comment Share on other sites More sharing options...
Guest Posted February 18, 2009 Share Posted February 18, 2009 I'm currently in the process of yet another new way to modify the exhaust.This way, while requiring patience, is very easy and does not require removal of the exhaust, loosening of the exhaust, or even removing the end covers off the exhaust. No welding required... It can also be done in stages, so you can check & evaluate the sound level before going further. I do caution that you do Stage 1 and ride the motorcycle through at least a tank full of gas, as the sound gets noticeably deeper and louder after running with even the "Stage 1" mod (it has to be the cat deteriorating due to more flow / less restriction through the modified exhaust). This is a different version of the "new way to 'gut' your exhaust" post, so I suggest that you read that post, then refer back to this one...I will post up the complete process with pics once I've completed the whole job this weekend...if anyone's interested. The difference is that I used a 1" bimetal hole saw (as suggested by VWRXTDR). I was able to drill between the outer tip and the inner tip of the exhaust exits, which releases the inner pipe from the outer exhaust tip. I was then able to reach into the inside pipe with a Dremel (no extension needed) and cut the inner pipe loose, then pull it out. The outer exhaust tip stays in place, which helps in a multitude of ways: 1. No fear of water getting into the cans. 2. No fear of the end caps blueing (important for me, as I'll be putting CF covers and end caps on). 3. The tips look good (if you like stock). 4. Sound is mellow and deep; louder than stock, but not in any way excessive. As someone suggested, the tips seem to take some of the "ping" out of the sound. 5. Close to being a "big hole" type gut, as the exit holes are now a full 1" diameter, instead of the 3/4" diameter of the inner pipes. The beauty of this mod is that you are essentially making the muffler a "straight thru" design, much like a total gut, without all the cutting, beating, welding, removing of the exhaust, etc...It maintains enough baffling to take the edge off, while maintaining a deep tone with a nice volume. "Stage 1" (Upper pipes in each muffler only) sounds very good at idle (deep and mellow). Very controllable noise level when accelerating (nice when you leave for work early in the morning); can hear the exhaust up to about 50 mph with Stage 1 (which is the top pipe in each can modified). I will be doing the bottom two pipes in each can this weekend (Stage 2). If anyone's interested, I'll post pics and try to do a sound clip of "Stage 1" and "Stage 2". There's also some tricks I learned while doing this that are essential to being able to drill between the exhaust tip and the inner pipe...One other note: The lean surging I was experiencing before at steady throttle while cruising at highway speeds is gone. The VTEC transition is also dramatically smoother. Anyone have an explanation for this? Roj hey i was needing help with this mod. for some reason i cant copy these instructions. was wondering if u could email this to me? if u can would appreciate. bctaft@yahoo.com Link to comment Share on other sites More sharing options...
Guest Posted March 17, 2009 Share Posted March 17, 2009 Took the plunge. Did a 'stage 2' exhaust mod. (this is the four pipe cut, not the full gut/stage 3) I left the pipes mounted, and about 4 hours of work (i have a long learning curve apparently), sweet sweet music! I learned a lot and now, could probably do it in about 2 hrs.... Thought i'd share some wisdom, perhaps it will save others some money and some time: This is essentially the same method posted above, except the pipes stayed on the bike and the chrome end pieces remained in place. I also did not remove the endcaps, only cut the internal mufflers approx. 1.5-2 inches inside the can. Tools I used: 1. Patience. First and formost. perhaps you will doubt yourself as you begin the first cuts, but take your time, the hard work and patience is worth it. Also if you prep your hole saw bits (see below) this helps. 2. Safety glasses. There's going to tons of metel bits everywhere... 3. Bike Cover. See #2. 4. powerful drill. you need one with some balls, a plug in Dewalt or similar works great. 5. 25 mm or 1 inch hole saws. I used two Rigid brand, (Home Depot). (Sears brand has straighter teeth, but the ID (inside diameter) is too tight) One of the most important things i learned regarding hole saws. As mentioned by other posters, the teeth are offset and alternating In/Out. This will chew the Shite out of your endcaps and cause a significant amount of seizing/grabbing. I used a Dremel tool 1/2 in. Sanding drum #407 to take the offset off the tips/realign on both the inside and the outside of the hole saw...just enough to reduce the seizing effect. I did this prep grind after the first cut and noted significant improvement in the smoothness of the cut and decreased seizing. I also used slow steady off/on pressure and the second i got smoke, i pulled out and went to the next hole, allowing the hot one to cool (no need to further harden that weld). I also used plenty of cutting oil. Before i went 'around' again, i hit each hole with the shop vac and compressed air to clear the metel shaving. Overall, this worked very well and went very smoothly. Another thing is to be sure to push all the way through the weld, essentially cleaning off the outside diameter of the exhaust pipe so it can be easily removed. this is very important. Ideally, one would use a 1 inch hole saw with Carbide grind tips, not teeth, but i was unable to find a carbide tipped one smaller than 2 inches. 6. Dremel Tool. I have the flex extension. love it but it's not critical. After a lot of experimentation with mutiple cutting discs (spendy) i have finallized on this. Don't waste your money on the Dremel EZ lock. They cut fine but once you get them down to the 3/4 inches you need to get into the exhaust pipe, you have only a few seconds before you are burned down to the locking mechanism. I used the Reinforeced Cutoff Wheels #456 or #423. One could go through about 30-40 of the heavy duty ceramic wheels and it's a PIA. Or you can grind down the reinforced wheels to the correct diameter. HERE's the TRICK: It take a hell of a lot of grinding to get them down to 3/4 even on a tool steel file or stone ( burned through a hardened 10 inch file just getting two down to size. don't waste your time. Grab your Shears (I used the Wiss straight cutting metal shears) and start snipping off the edges of the wheel. This is surprisingly easy and does not compromise the integrity of the wheel. Work your way around it until you are close (very close) to 3/4in. Spin it on a file or stone to prep and round the edge, then get to cutting. I started the cuts at the 12 oclock and gradually worked my way around. I burned through about 2 wheels per tube (8 total). The exhaust tip dropped loose and i was able to pull it out with needle nose. During the wheel cutting, i again hit the can's with the shop vac and compressed air, trying to keep as much material from building up and interfering with the cutting and i also want a clean can when its over. While vacuuming i would alternate blocking the airflow through the opposite can or the secondary whole to shift airflow in the can and grab more shavings. I then ran a magnet in there to pick up any stray pieces. I then took a fresh cutoff wheel and inserted back into the cans to clean up the cuts on the ends of the pipes. polished out nice. I used the Dremel 1/2 in Sanding Drum to clean up any errent cutting marks in the outlet pipes. This gave a very nice cleaned up appearance on the interior diameter of the outlet pipes. Finally, I used the 511E EZ Lock Finishing Abrasive Buffs - 180 & 280 grit (2 Pack) to polish out the outlet pipes. These are a perfect fit into the pipe and leave a nice brilliant shine on the ID of this pipes. Overall, i'm very happy. haven't road tested yet, but looking forward to a warm day off work... At low and high idle, sound amazing. Give it a shot, i'll try to post pics when i'm not at work (which is almost never) and PM me if you have any questions. Good luck!!!!!!!! Link to comment Share on other sites More sharing options...
Guest Posted December 12, 2009 Share Posted December 12, 2009 Took the plunge. Did a 'stage 2' exhaust mod. (this is the four pipe cut, not the full gut/stage 3) I left the pipes mounted, and about 4 hours of work (i have a long learning curve apparently), sweet sweet music! I learned a lot and now, could probably do it in about 2 hrs.... Thought i'd share some wisdom, perhaps it will save others some money and some time: This is essentially the same method posted above, except the pipes stayed on the bike and the chrome end pieces remained in place. I also did not remove the endcaps, only cut the internal mufflers approx. 1.5-2 inches inside the can. Tools I used: 1. Patience. First and formost. perhaps you will doubt yourself as you begin the first cuts, but take your time, the hard work and patience is worth it. Also if you prep your hole saw bits (see below) this helps. 2. Safety glasses. There's going to tons of metel bits everywhere... 3. Bike Cover. See #2. 4. powerful drill. you need one with some balls, a plug in Dewalt or similar works great. 5. 25 mm or 1 inch hole saws. I used two Rigid brand, (Home Depot). (Sears brand has straighter teeth, but the ID (inside diameter) is too tight) One of the most important things i learned regarding hole saws. As mentioned by other posters, the teeth are offset and alternating In/Out. This will chew the Shite out of your endcaps and cause a significant amount of seizing/grabbing. I used a Dremel tool 1/2 in. Sanding drum #407 to take the offset off the tips/realign on both the inside and the outside of the hole saw...just enough to reduce the seizing effect. I did this prep grind after the first cut and noted significant improvement in the smoothness of the cut and decreased seizing. I also used slow steady off/on pressure and the second i got smoke, i pulled out and went to the next hole, allowing the hot one to cool (no need to further harden that weld). I also used plenty of cutting oil. Before i went 'around' again, i hit each hole with the shop vac and compressed air to clear the metel shaving. Overall, this worked very well and went very smoothly. Another thing is to be sure to push all the way through the weld, essentially cleaning off the outside diameter of the exhaust pipe so it can be easily removed. this is very important. Ideally, one would use a 1 inch hole saw with Carbide grind tips, not teeth, but i was unable to find a carbide tipped one smaller than 2 inches. 6. Dremel Tool. I have the flex extension. love it but it's not critical. After a lot of experimentation with mutiple cutting discs (spendy) i have finallized on this. Don't waste your money on the Dremel EZ lock. They cut fine but once you get them down to the 3/4 inches you need to get into the exhaust pipe, you have only a few seconds before you are burned down to the locking mechanism. I used the Reinforeced Cutoff Wheels #456 or #423. One could go through about 30-40 of the heavy duty ceramic wheels and it's a PIA. Or you can grind down the reinforced wheels to the correct diameter. HERE's the TRICK: It take a hell of a lot of grinding to get them down to 3/4 even on a tool steel file or stone ( burned through a hardened 10 inch file just getting two down to size. don't waste your time. Grab your Shears (I used the Wiss straight cutting metal shears) and start snipping off the edges of the wheel. This is surprisingly easy and does not compromise the integrity of the wheel. Work your way around it until you are close (very close) to 3/4in. Spin it on a file or stone to prep and round the edge, then get to cutting. I started the cuts at the 12 oclock and gradually worked my way around. I burned through about 2 wheels per tube (8 total). The exhaust tip dropped loose and i was able to pull it out with needle nose. During the wheel cutting, i again hit the can's with the shop vac and compressed air, trying to keep as much material from building up and interfering with the cutting and i also want a clean can when its over. While vacuuming i would alternate blocking the airflow through the opposite can or the secondary whole to shift airflow in the can and grab more shavings. I then ran a magnet in there to pick up any stray pieces. I then took a fresh cutoff wheel and inserted back into the cans to clean up the cuts on the ends of the pipes. polished out nice. I used the Dremel 1/2 in Sanding Drum to clean up any errent cutting marks in the outlet pipes. This gave a very nice cleaned up appearance on the interior diameter of the outlet pipes. Finally, I used the 511E EZ Lock Finishing Abrasive Buffs - 180 & 280 grit (2 Pack) to polish out the outlet pipes. These are a perfect fit into the pipe and leave a nice brilliant shine on the ID of this pipes. Overall, i'm very happy. haven't road tested yet, but looking forward to a warm day off work... At low and high idle, sound amazing. Give it a shot, i'll try to post pics when i'm not at work (which is almost never) and PM me if you have any questions. Good luck!!!!!!!! Thanks for the extra details! Link to comment Share on other sites More sharing options...
Member Contributer pres589 Posted December 12, 2009 Member Contributer Share Posted December 12, 2009 Not to poo-poo someone's well documented hard work, and I can totally understand wanting to get a little more sound out of these bikes, but I've started to wonder just what effect this sort of mod has on backpressure through increased outlet turbulence. Easy test would be dyno runs before and after. Maybe nothing of any consequence. Or maybe not. Something to think about at least. Link to comment Share on other sites More sharing options...
Member Contributer 2FAST4U Posted December 12, 2009 Member Contributer Share Posted December 12, 2009 Any follow up on this? Any comments on the difficulties these last few posters have had?? Sound clips?? Just now seeing this thread. I hate to rain on VFRoj's parade but IIRC this method is the original one from the 2002-03 era. I did my first vtec this way. It sounded great and is one of the best "free" mods around but I eventually got greedy and sawed off the end caps, removed the remaining baffles, and had a welder reattached the end caps for about $40. Big, deep noises that rivaled any exhaust; however, I grew tired of the stock look, weight, and especially the heat of the stainless cans and went with a carbon fiber solution and have used ever since: Custom D&D pipes termi's Ducati Termignoni exhaust on an 02 VTEC. Custom Termignoni's Leo Vince I sure wish I had your talent. Link to comment Share on other sites More sharing options...
Member Contributer FotoMoto Posted December 12, 2009 Member Contributer Share Posted December 12, 2009 Not to poo-poo someone's well documented hard work Seat of the pants dynos show no difference. Link to comment Share on other sites More sharing options...
Member Contributer FotoMoto Posted December 12, 2009 Member Contributer Share Posted December 12, 2009 I sure wish I had your talent. Thanks Steve! :ph34r: But if I can do it, anyone can. :biggrin: Link to comment Share on other sites More sharing options...
