Sign in to follow this
BusyLittleShop
Unchain My Bike... Or So I Thought...
2 different set ups.. one with the belt on top of roller.. no teeth needed...
the other with the belt under the roller teeth may be wanted.....
Only a goober would miss the part in my thread about rollers...
Share this post
VFRD................ where u learn something new every day..............
Goober may refer to:
The peanut
Goobers, a brand name of chocolate-coated peanut
Goober (brand), a food product combining peanut butter and fruit preserves
Goober, a fictional dog in the 1970s animated series Goober and the Ghost Chasers
Share this post
You're not using your magnesium swingarm for this are you? I probably wouldn't want to do any drilling to that system.
Share this post
The peanut
here is a little piece of "americana" for you too....
http://www.youtube.com/watch?v=yZeacmVyxrA
Share this post
i didn't miss it.
you said no room... this thing out of TI, would be small and would fit there with out hitting anything..
then you can use a long belt made for the sportster.
Share this post
i didn't miss it.
No room means that Gates engineering recommends that the smallest
idler pulley is 4in because belt life would be considerably shorten if
it defected by any smaller of a pulley... that especially means the
skate broad wheel spring loaded John Deer combine part you dreamed up...
Share this post
i didn't miss it.
well, i know my set up works, as it was tested on a fixed axle bike... i have no clue how long the belt lasted though.. sorry
Share this post
No problem... merely working and engineered correctly to last are
entirely two different objectives...
Share this post
your right..
your bike doesnt have a belt.. but my little gizmo is on a street legal 185hp nitro-methane drag bike.. the "roller" is just a set of bearing and a TI sleeve.
just because Gates says something, doesnt make it gospel :fing02:
Share this post
you spent all that time making the parts but never tried a tiny roller.. what the worst that can happen? you put a few thousand miles on a belt that should get 20? inspect your belt every ride then make a decision for yourself .
Share this post
True. As long as the belt lasts 5k to 10k miles I don't see a problem. Well, other than it looks hideous on an RC45, but that's just my personal opinion.
Share this post
its late.. i am buzzed.. but have a simple idea..
if you want to follow gates arc of a 4inch pulley do so.. with a bunch of smaller rollers.. this was drawn with a 5 inch pulley.. and exaggerated belt angle
so yeah.. add a piece of tractor to your bike..
or you could buy the 28 or 29 tooth front pulley and make a SMALLER rear pulley and get the right leangth you need. :fing02:
Share this post
It's gospel... the Gates belt is too short...
Share this post
Thanks for the tractor part... but I already considered rollers... but the belt is still too long...
Share this post
My experience is that a belt will last 3 times longer than chain...
but then again I believe a chain needs replacements at 10K...
You're not the only one who thinks its hideous... in fact the majority
of owners in the RC45 Club have threaten to break into the Busy Little
Shop and rescue Mr.RC45 so he won't suffer the indignation of an belt
mod...
Share this post
mod...
Horse nuts, it looks waaaaaaay better than a bunch of chain lube slung all over creation that has to be cleaned once a week!!
Share this post
But then again I believe a chain needs replacements at 10K...
:laugh:
Only the jockey wheel. I think a jockey wheel ruins the look of the SSSA. The setup with roller looks much better.
Share this post
I may be a bit late to the show on this thread .... But have you tried looking into the belt drives used by Yamaha (Star motorcycles)? I believe they use a belt drive on the Raider and the Warrior. It might open some options for you on belt and/or sprocket selection, and a tension system.
Share this post
I know I'm coming LOOOOONG time after the battle (after the war?) but I am myself highly interested about converting my RC46D to belt drive.
I didn't see in this discussion a word about using a 31T or 32T front pulley? I know it would probably not fit but with some drilling it could ...
For my personal project I am more looking at 8mm pitch 36mm wide belts. the 32T front and 90T rear with 220T belt _should_ fit if I'm right in my measurement and it look likes RCD Engineering is selling everything that I need.
My question is will it be strong enough? The maximum power (let say 110hp) is achieved in first gear at 10500rpm. The primary reduction is 1.939 and the first gear reduction is 2.846 so the 110hp are achieved at 1896rpm. Considering Gates tables I should go for a 53T front pulley or a 62mm wide belt ....
What do you think? Am I wrong somewhere, is there no clue to unchain any VFR? Maybe the 62mm wide belt could fit?
Share this post
Wow. Nice first post. This should be interesting to watch. Good luck (maybe PM BLS to get his attention?).
Share this post
Thank you, I'm browsing this forum for 2 years now, lot of information here :) I saw that the VF500 belt-o-ceptor is 70hp with a 8mm pitch belt but I don't know the width but I believe 36mm, maybe less, I'd like to have more informations about this conversion. I may have a little bit of chance also with 14mm pitch 25t front 65t rear but it would be really really tight. I need to take serious measures to be sure that it could fit. Also 25t is small for a 14mm pitch belt, it would probably reduce the lifetime but I can deal with it.
Edit : Ok 65 tooth is too big for the rear ... There exists a 61 tooth that can fit but 61/25 is a too long reduction to be reasonably usable except if I can go for shorter front pulley (22t) but I have some doubt and it will be custom manufactured . So my last chance is the 8mm pitch, it exists in 50mm wide, a little bit weak regarding Gates tables but should be ok.
Edited by nunux59
Share this post
If you just cracked the mystical VFR belt driven code I'm about to get reeeeeeeeeeeeaaaalyyy excited!!!!!!!!!!!
Keep us in the loop there Nunux59, and welcome!!
Share this post
+1 I thought everyone had given up.
Share this post
