Member Contributer Ducatti20 Posted August 15, 2007 Member Contributer Share Posted August 15, 2007 Poll for tracking, what year did you have electrical issues and did you have added accessories. Please only vote if you have had problems to keep the data clean. I added the multiple choice option for those of you with multiple 6th gen bikes of differant years, same with the accessories poll. Please post below only if you have had issues with a 6th gen, your fix, and approximately how much it cost you to repair. Many have mentioned pushing Honda to cover repair costs on this issue, perhaps we can build a database right here for evidence. Link to comment Share on other sites More sharing options...
Tightwad Posted August 15, 2007 Share Posted August 15, 2007 I had the classic 30 amp fuse wire turning brown. This caused me to investigate further, and check my sensor wire output. It was at 11.8 volts or so, battery while running was at 15.8 or so. Cost to repair: New wire for 30 amp fuse holder - $2 + 1/2 hour labor Wire harness(custom built by me) for fixing the sensor wire, and adding addition ground/power runs. $25 + 3 hours labor (installing was 30 minutes, building took the time) Link to comment Share on other sites More sharing options...
Baileyrock Posted August 15, 2007 Share Posted August 15, 2007 Smoked the 30amp fuse wire with no failure or issue, replaced it with h/m Radio Shack set-up. Aprox. at 25k on 02. $8.00 Blue connector ground failed somewhere in the high 30k miles and because of the "Vtec Elec. problems"post knew exactly what it was and had it repaired(new ground) in 20 min. and still made my ride. :thumbsup: No cost! As far as tracking, there was a large post prior to the one I started that had most of the problems and the owners who had problems, but that post was lost in one of the crashes. Lots of the same info in the new post "vtec elec. problems". We tried to keep a data base of all the harness issues and for the most part it seemed that Honda covered all the parts and labor for most of the members no matter if they were under warranty or not, but some got shafted ! <_< Some members reported that some Honda Regional Service Reps admitting a problem and others deny it. Link to comment Share on other sites More sharing options...
Member Contributer Das Bone Posted August 15, 2007 Member Contributer Share Posted August 15, 2007 30 amp and added ground wire to blue connector(connector was OK at that point) Also had a very bizarre occurence(documented on the elec prob sticky) where the front edge of the tank, right side, wore through the insulation covering the metal brake line tube and caused some "wierdness" :P Link to comment Share on other sites More sharing options...
Member Contributer VIPERon Posted August 15, 2007 Member Contributer Share Posted August 15, 2007 Overcharging R/R fried the battery...04 VFR with 8k miles with only GPS accessory. Replacement Yuasa @ $113; 30 amp fuse, blue connector and monitor wire mods under $10. Will replace my fix with Tightwad's $47 mod for a more professional install. Total parts $170. Link to comment Share on other sites More sharing options...
Member Contributer Ducatti20 Posted August 15, 2007 Author Member Contributer Share Posted August 15, 2007 Keep it coming guys, I'm going to build an access database for this for tracking. All the other threads are too hard to sort through quickly! Link to comment Share on other sites More sharing options...
Guest Posted August 15, 2007 Share Posted August 15, 2007 my 04 had the 30a wire and fuse holder failure,both were toasty. i have no electrical accessories. i did the 30a fuse fix and sensor wire fix,along with the blue connector ground fix. $17 total cost and about 3 hours labor. i had no issues with how mine ran and the original battery is still working well at 18k miles. but mine was just a ticking timebomb of troubles. Link to comment Share on other sites More sharing options...
tinyminds Posted August 15, 2007 Share Posted August 15, 2007 Black monitor while from R/R to ignition had resistance issues, bike was charging at 17vdc. I have a lot of gadgets, hooked up. See below mods for list. Link to comment Share on other sites More sharing options...
Member Contributer Spike Posted August 15, 2007 Member Contributer Share Posted August 15, 2007 My battery was "whistling" after a 500 mile ride. Wouldn't hold a good charge after that. Nothing melted. I was running GPS and an mp3 amp, but I don't think those contributed to the problem. I checked the charging system and it was definitely overcharging. Replaced the battery and did the monitor wire fix. The charging system output is in the right range and haven't had a problem since. Link to comment Share on other sites More sharing options...
turtlecreek Posted August 15, 2007 Share Posted August 15, 2007 30 amp fuse was looking crispy, so i replaced it. no other issues or fixes to date Link to comment Share on other sites More sharing options...
Guest Posted August 15, 2007 Share Posted August 15, 2007 Last night I finally dared to open it up and look I found a huge wad of electrical tape holding it all together. My fuse was a little melted but the wires are Crisp to the point that they wont bend. I located the part number for the factory replacement 32401-MCW-D00 and my dealer wants $73.00 for it. I am sure the dealer would just replace the wiring not fix the problem. I am the second owner of the bike the origina owner had put 3500 miles on it and I have added another 1000 miles, so it is not an issue of mileage. I am looking at tightwads fix or maybe building my own. I have not had any luck opening up the existing connections so I can just replace the wire with larger wire. Here is the photo of what the wires look like. DSC02467.jpg Link to comment Share on other sites More sharing options...
Baileyrock Posted August 15, 2007 Share Posted August 15, 2007 Last night I finally dared to open it up and look I found a huge wad of electrical tape holding it all together. My fuse was a little melted but the wires are Crisp to the point that they wont bend. I located the part number for the factory replacement 32401-MCW-D00 and my dealer wants $73.00 for it. I am sure the dealer would just replace the wiring not fix the problem. I am the second owner of the bike the origina owner had put 3500 miles on it and I have added another 1000 miles, so it is not an issue of mileage. I am looking at tightwads fix or maybe building my own. I have not had any luck opening up the existing connections so I can just replace the wire with larger wire.Here is the photo of what the wires look like. DSC02467.jpg See "Vtec elec. problem" post to find 30amp fuse fix, Radio Shack. Link to comment Share on other sites More sharing options...
Baileyrock Posted August 15, 2007 Share Posted August 15, 2007 Keep it coming guys, I'm going to build an access database for this for tracking.All the other threads are too hard to sort through quickly! I don't really the need for this post as you are gathering the same info that's already in the "Vtec Elec. Problems" post. I just purged a bunch of unneeded post in it and you can get every bite of info your asking for right there w/o running a duplicate thread asking for the same info. Am I missing something? :goofy: The poll is OK. Link to comment Share on other sites More sharing options...
Guest gr3664 Posted August 15, 2007 Share Posted August 15, 2007 my problems have been posted otherwise, but bike quit on the freeway going speedlimit + 1 mph or so... battery was checked okay, stator was tested no voltage coming out, replaced stator and flywheel (in kit together), stator was 'outside' the vin# for the recall in 2002's, everything working now with only new stator/flywheel, have the R/R but have not installed new one as yet, so cost would be i think around $180 or so plus 1 and a half days off work to fix myself, if the R/R is replaced add another $140 to that Link to comment Share on other sites More sharing options...
Member Contributer Ducatti20 Posted August 15, 2007 Author Member Contributer Share Posted August 15, 2007 Keep it coming guys, I'm going to build an access database for this for tracking.All the other threads are too hard to sort through quickly! I don't really the need for this post as you are gathering the same info that's already in the "Vtec Elec. Problems" post. I just purged a bunch of unneeded post in it and you can get every bite of info your asking for right there w/o running a duplicate thread asking for the same info. Am I missing something? :goofy: The poll is OK. Mainly looking for the years of affected cycles and accessories if they were installed. Didn't mean to create a duplicate thread. Link to comment Share on other sites More sharing options...
Poncho Posted August 15, 2007 Share Posted August 15, 2007 I think it is only a matter of time before the newer bikes have problems. Link to comment Share on other sites More sharing options...
Dead Stiff Posted August 16, 2007 Share Posted August 16, 2007 I had my 30 amp wire fry on me at 10k miles, under warranty they replaced the main, sub and RR harnesses. 15k miles later everything is still fine. Link to comment Share on other sites More sharing options...
dcstewart77 Posted August 16, 2007 Share Posted August 16, 2007 my 04 had the 30a wire and fuse holder failure,both were toasty.i have no electrical accessories. i did the 30a fuse fix and sensor wire fix,along with the blue connector ground fix. $17 total cost and about 3 hours labor. i had no issues with how mine ran and the original battery is still working well at 18k miles. but mine was just a ticking timebomb of troubles. I just picked up a stock 2003 VFR and want do these fixes as preventative measures...I had a 97 VFR that left me stranded once and don't want that to happen again. I found the link to the 30a fuse fix: http://www.vfrdiscussion.com/forum/index.php?showtopic=29737 And the link to the blue connector fix: http://www.vfrdiscussion.com/forum/index.p...sensor+wire+fix But could not find a link to the "sensor wire fix" you noted. Where is that description? Thanks, Doug Link to comment Share on other sites More sharing options...
Guest Posted August 16, 2007 Share Posted August 16, 2007 my 04 had the 30a wire and fuse holder failure,both were toasty.i have no electrical accessories. i did the 30a fuse fix and sensor wire fix,along with the blue connector ground fix. $17 total cost and about 3 hours labor. i had no issues with how mine ran and the original battery is still working well at 18k miles. but mine was just a ticking timebomb of troubles. I just picked up a stock 2003 VFR and want do these fixes as preventative measures...I had a 97 VFR that left me stranded once and don't want that to happen again. I found the link to the 30a fuse fix: http://www.vfrdiscussion.com/forum/index.php?showtopic=29737 And the link to the blue connector fix: http://www.vfrdiscussion.com/forum/index.p...sensor+wire+fix But could not find a link to the "sensor wire fix" you noted. Where is that description? Thanks, Doug http://www.vfrdiscussion.com/forum/index.php?showtopic=34762 i found it a very simple fixand its been stated to me after i used a seperate fused line you can just run a line off the new 30A fused line that your doing. Link to comment Share on other sites More sharing options...
spud786 Posted August 16, 2007 Share Posted August 16, 2007 I havent had any issue with the beefed up wiring harness on my 06, I just hit all connections with WD back when it was new Including the stator connections and the Blue connector ground harness. I just checked my 30 amp area the other day (still like New). Bike is 1 1/2 year old and 24,000 miles Link to comment Share on other sites More sharing options...
Neboor Posted August 16, 2007 Share Posted August 16, 2007 My 05 ABS had the black battery monitor incorrectly reading the battery too low so the R/R overcharged my battery. Did the bypass and fixed it like a charm. Link to comment Share on other sites More sharing options...
Guest Posted August 18, 2007 Share Posted August 18, 2007 I'm slightly bothered by the second question pertaining to accessories. My accessories consist of heated grips and heated vest, both are only used for a few months in Minnesota (so are mainly off.) The current draw for both are nothing close to the second set of stock lights and the cooling fan, which can run alot in the summers. So if I answered YES to running accessories, I feel like I am indicting myself as THE PROBLEM when that can't be the cause. I do have a voltmeter installed and can tell you the voltage drop is substantial when the high beams are on, the cooling fan is running and sitting at a light with the rear brake light engaged and a blinker on. In this particular situation, the voltage is registering 12.3 volts and suggests that not only is the regulator not keeping up but also a slight discharge is occurring. This will heat that subharness like nothing else. In my opinion, the root of the problem is not riders running accessories, rather Honda's failure to beef up the wiring system to handle the extra load when they had the neat idea of adding a second set of lights. Maybe the poll question could ask if riders use the high beams alot and ride in conditions that result in extended cooling fan cycling. Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted August 18, 2007 Member Contributer Share Posted August 18, 2007 I'm slightly bothered by the second question pertaining to accessories. My accessories consist of heated grips and heated vest, both are only used for a few months in Minnesota (so are mainly off.) The current draw for both are nothing close to the second set of stock lights and the cooling fan, which can run alot in the summers. So if I answered YES to running accessories, I feel like I am indicting myself as THE PROBLEM when that can't be the cause.I do have a voltmeter installed and can tell you the voltage drop is substantial when the high beams are on, the cooling fan is running and sitting at a light with the rear brake light engaged and a blinker on. In this particular situation, the voltage is registering 12.3 volts and suggests that not only is the regulator not keeping up but also a slight discharge is occurring. This will heat that subharness like nothing else. In my opinion, the root of the problem is not riders running accessories, rather Honda's failure to beef up the wiring system to handle the extra load when they had the neat idea of adding a second set of lights. Maybe the poll question could ask if riders use the high beams alot and ride in conditions that result in extended cooling fan cycling. Have you done the monitor wire fix? Since I did mine, no matter what draw there is the voltage stays at 14.3 at all times. Link to comment Share on other sites More sharing options...
Guest Posted August 18, 2007 Share Posted August 18, 2007 Have you done the monitor wire fix? Since I did mine, no matter what draw there is the voltage stays at 14.3 at all times. No I haven't. I did perform the harness mod three years ago but was not aware of the monitor wire fix until today. Are you certain you are able to maintain 14.3 at ALL RPMs with the high beams, cooling fan and brake light engaged? I have always believed the alternator output just wouldn't allow that sort of draw at lower RPM, no matter how good the wiring is. Link to comment Share on other sites More sharing options...
Guest Posted August 18, 2007 Share Posted August 18, 2007 I'm slightly bothered by the second question pertaining to accessories. My accessories consist of heated grips and heated vest, both are only used for a few months in Minnesota (so are mainly off.) The current draw for both are nothing close to the second set of stock lights and the cooling fan, which can run alot in the summers. So if I answered YES to running accessories, I feel like I am indicting myself as THE PROBLEM when that can't be the cause.I do have a voltmeter installed and can tell you the voltage drop is substantial when the high beams are on, the cooling fan is running and sitting at a light with the rear brake light engaged and a blinker on. In this particular situation, the voltage is registering 12.3 volts and suggests that not only is the regulator not keeping up but also a slight discharge is occurring. This will heat that subharness like nothing else. In my opinion, the root of the problem is not riders running accessories, rather Honda's failure to beef up the wiring system to handle the extra load when they had the neat idea of adding a second set of lights. Maybe the poll question could ask if riders use the high beams alot and ride in conditions that result in extended cooling fan cycling. What type of Voltage Meter are you using? Where have you tied your voltage meter wires to? I am looking at voltage meters and wondering what people are using and where they tie into to get accurate voltage. Thanks, Jay Link to comment Share on other sites More sharing options...
