Guest ScottyD Posted June 20, 2012 Share Posted June 20, 2012 (edited) Modified Coyze's Orginal PCIII USB Map for PCIII Serial Version.Problem was that on the PCIII USB Version Maps - (.djm) The Increments in RPM are every 250 where as (.map) for the PCIII Serial are every 500 RPM. Excel fixed this issue.Many thanks to Coyze for this AWSM Map! Download link below:Download Edited June 20, 2012 by ScottyD Quote Link to comment Share on other sites More sharing options...
Guest LB800 Posted May 18, 2013 Share Posted May 18, 2013 http://www.vfrdiscussion.com/forum/index.php?app=downloads&module=display§ion=screenshot&id=18 File Name: OFFICIAL COZY MAP - (cozye_ver5.djm) - Famous vtec pc3 USB map.File Submitter: cozye File Submitted: 28 May 2007 File Updated: 02 Feb 2011 File Category: Power Commander Maps Thanks a million to HS for setting up this downloads section. Well, here is my map for everyone to download. This is the same map that is featured in Motorcyclist Magazine (May,07 pg 159). This map should work perfectly on any 2002-2005 VFR with aftermarket slip on and o2 eliminators. It will work well on any vtec really, regardless of exhaust. If running stock exhaust you may want to go in and lean it up just a touch. Try it first though and see before tweaking. If anyone feels like they can make some improvements, go for it. Many minds are greater than one. I believe Tinyminds has dyno'd this map and got around 101 hp or so. This map wont work well on 2006-2007 models with the lower vtec engagement. You could probably take the map and modify it accordingly for the lower vtec range. If someone attempts this, please post it up for other newer vtec guys to use. I've had quite a few 06-07 owners ask for it. My thoughts are that you could copy mine below 6000, and above 8000. Then just mimick what I did with the fuel curve on the dynojet supplied version from 6000-8000. Just smooth out the fuel curve. enough rambling. One request however. If you use the map, and you really like it. Why not make a small donation to VFRD ? I would guess there are probably 150 people who have or are using this map (just going by the fact that I have had about 300 request for it). If all those people chipped in 5 bucks, it would be quite a bit of dough to go for our wonderful community. Just a thought. :thumbsup: Click here to download this file Just downloaded and installed the map on my 02 VFR. Pouring rain so I can't take it for as spin. I was running one of the stock dyno jet maps, but not completely satisfied. I'll let you know how she runs. Quote Link to comment Share on other sites More sharing options...
Baileyrock Posted May 19, 2013 Share Posted May 19, 2013 Just downloaded and installed the map on my 02 VFR. Pouring rain so I can't take it for as spin. I was running one of the stock dyno jet maps, but not completely satisfied. I'll let you know how she runs. Welcome to VFRD and do post up on your results! BR Quote Link to comment Share on other sites More sharing options...
Guest hollenbeck Posted July 9, 2013 Share Posted July 9, 2013 hey guys newbie to this site, anyways I loaded cozys map on my 01 5th gen vfr800 cause cozy said it'll work on pretty much any v-tech model, I have k&n air filter(not by choice), yoshimura rs-3 slpon and of course pc3usb, I didn't do the o2 eliminator cause a guy I talk to at dynojet said if the fi light isn't coming on then no need, but from reading this forum I wanna get the resistor from radio shack so can anyone let me know exactly what I need and how to install, and I was woundering does anyone know how to tweak the map that would make it more suitable for my 01 vfr800? I wanna do an air box mod but every forum I read there's 20 different opinions, so as far as that mod goes what's the best thing to do as far as performance? I'd really appreciate any advice, thanks guys Quote Link to comment Share on other sites More sharing options...
Member Contributer spotthedogg Posted January 29, 2014 Member Contributer Share Posted January 29, 2014 '01 VFR800 doesn't have VTEC Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted January 29, 2014 Member Contributer Share Posted January 29, 2014 hey guys newbie to this site, anyways I loaded cozys map on my 01 5th gen vfr800 cause cozy said it'll work on pretty much any v-tech model, I have k&n air filter(not by choice), yoshimura rs-3 slpon and of course pc3usb, I didn't do the o2 eliminator cause a guy I talk to at dynojet said if the fi light isn't coming on then no need, but from reading this forum I wanna get the resistor from radio shack so can anyone let me know exactly what I need and how to install, and I was woundering does anyone know how to tweak the map that would make it more suitable for my 01 vfr800? I wanna do an air box mod but every forum I read there's 20 different opinions, so as far as that mod goes what's the best thing to do as far as performance? I'd really appreciate any advice, thanks guys '01 VFR800 doesn't have VTEC Oh yeah miss that ... Quote Link to comment Share on other sites More sharing options...
Shmerick Posted September 5, 2017 Share Posted September 5, 2017 I realize this is a super old thread. The old link for Cozye's map is dead. I know I had it once upon a time but cannot locate it. Does anyone still have it, or have anything improved, for a PC3 USB for a gen 6 aftermarket exhaust and 2 Brother's or similar? Quote Link to comment Share on other sites More sharing options...
Jeff Posted September 9, 2017 Share Posted September 9, 2017 On 9/5/2017 at 5:45 AM, Shmerick said: I realize this is a super old thread. The old link for Cozye's map is dead. I know I had it once upon a time but cannot locate it. Does anyone still have it, or have anything improved, for a PC3 USB for a gen 6 aftermarket exhaust and 2 Brother's or similar?  BUMP..  Same here, I just picked up a 6th Gen with PC3 USB and Staintunes. Quote Link to comment Share on other sites More sharing options...
mvvette97 Posted March 22, 2018 Share Posted March 22, 2018 I would be interested in trying it as well. Quote Link to comment Share on other sites More sharing options...
Darinmac6 Posted May 19, 2019 Share Posted May 19, 2019 On 6/20/2012 at 3:59 AM, ScottyD said: Could someone please let me know where I could find a copy of Scotty D's Coyze PCIII map that he converted to work with a serial port PCIII power commander thanks. Darin  Quote Link to comment Share on other sites More sharing options...
