Member Contributer VFRiderGal Posted April 7, 2007 Member Contributer Share Posted April 7, 2007 Hey guys, We're out in the garage adding a bunch of goodies today, just curious where you chose to mount your aux fuse box?? Link to comment Share on other sites More sharing options...
Baileyrock Posted April 7, 2007 Share Posted April 7, 2007 Hey guys, We're out in the garage adding a bunch of goodies today, just curious where you chose to mount your aux fuse box?? Depends on the type of fuse box, I installed it here on Butch's bike. Link to comment Share on other sites More sharing options...
Member Contributer vanion2 Posted April 7, 2007 Member Contributer Share Posted April 7, 2007 I've seen pictures of more than a few of the larger fuse boxes being mounted near the front of the radiators (which side depending on ABS or not model). Link to comment Share on other sites More sharing options...
tinyminds Posted April 7, 2007 Share Posted April 7, 2007 This was my old setup, but had to remove it so I would have somewhere to put my PC3. Ended up just putting inline fuses going to the devices themselves. Link to comment Share on other sites More sharing options...
Member Contributer VFRiderGal Posted April 8, 2007 Author Member Contributer Share Posted April 8, 2007 Thanks VFRD! :D Well, looks like it's going under the seat. :thumbsup: I thought that would be best, but wanted to hear what most everyone else did and any thoughts they had on the subject. The only thing that concerned me with mounting it up front would be if ever I needed to change a fuse on the fly. It would be a pain in the arse to take off the fairing just to change a fuse. Not to mention, I think it would have better protection from the elements under the seat. As for today, here's what all I've got installed (just need to finish up some wiring) : Heated Grips Throttlemeister Back Off Brake Light Module Adjusted wiring for sockets to the rear clear tail lens Push button garage door opener Garmin Quest powered cradle with RAM mount Now I'm pretty much waiting on some parts to arrive to finish all the mods. Will post up all when I'm done! :beer: Link to comment Share on other sites More sharing options...
Member Contributer dutchinterceptor Posted April 8, 2007 Member Contributer Share Posted April 8, 2007 This spot will just barely work if you are using the Centech. Click for a larger image. Link to comment Share on other sites More sharing options...
Member Contributer cooper Posted April 8, 2007 Member Contributer Share Posted April 8, 2007 voltmeter (4).JPG voltmeter (3).JPG Under the seat is the location I used too. One picture show the power from the battery, with in-line fuse. The other shows the relay for the fuse box circut run off of the tail light, and the fuse box location. Link to comment Share on other sites More sharing options...
tinyminds Posted April 8, 2007 Share Posted April 8, 2007 Found a good spot to mount a relay on 6th gens... just to the right of the 30amp fuse. Theres a bolt there that you can unscrew and mount the relay to the bolt. :beer: I honestly found it was easier just to put an inline fuse in like 'coopers' top picture and let it go. Link to comment Share on other sites More sharing options...
Darth Bling Posted April 9, 2007 Share Posted April 9, 2007 Since I don't have the ABS model, it fits nicely under the left fairing. Link to comment Share on other sites More sharing options...
