H4 Headlight In My 5th Gen. Have You Had Issues With The H4?
Guest da9b20
The H4 buld does not fit the US model headlight bases. Instead Honda US sell their own bulbs (H4 with Honda tab pattern).
The problem is the tabs as just slightly off-set, and will not just pop into place. This is not a problem with Eurpoean set-ups. Howver, all you need to do is bend the offending tab out of the way and two of the three tabs will lock the bulb in place and the brass clip will prevent the buld from spinning.
The adapter just allows you to install the standard H4 without bending a tab.
