Sign in to follow this
Rivcyko
Public Service Announcement
Thanks for the info on the Force Silver. The local PPG distributor sold me a quart of stock base from their Global line, saying said it was a match. It was close, but definitely not a match.
I used the more economical OMNI line for clear coat this time one my tank and was shocked how easily and flawlessly it sprayed.
I used PPG Omni, , but they recently can out with ProLine to semi replace Omni even though you can still get Omni. Done a few bikes and have been pretty happy with the results! :rolleyes:
Share this post
PPG will be switching the booth and paint bank at the shop I do work at over to a brand-new water based system soon, can't wait to try it out, should be interesting!
Share this post
I used PPG Omni, , but they recently can out with ProLine to semi replace Omni even though you can still get Omni. Done a few bikes and have been pretty happy with the results! :fing02:
Both have been kind to me. The top $$$ PPG, is the ticket for me, (as my skills need some work). All formulas posted, will work with all PPG paints.
Buf,
Application makes a LOT of difference.
Glad I can help, even if it is saving a few bucks, on hundreds of dollars worth of paint.
As for GM yellow, they should have it on file,........................ or pay for your own scan. LOL. J/K.
Share this post
Bump for a good thread - especially with all the bodywork going on!
Can we please have this topic pinned or stickied at the top of this forum listing?
This is really useful info that should be easy for everyone to find!
Share this post
----'02-'04 ---- Force Silver
DBC5464F BRIGHT SILVER
DMD1687 Med. Alu 454.4
DMD1686 Fine Alu 9.4
DX685 Flatting 9.4
DMD641 Yellow 4.7
PRL93 Gold pea 3.2
DBX1689 Clear 23.5
Here's some real world proof of formula... took this formula that was spit out by a PPG Prophet machine in Michigan(Thanks again Trav!), and mixed it up using PPG DBU system paint out of a bank at a shop in NY.
I shot it on Poncho's track plastic, results are a perfect match to his tank which pulls double duty street & track:
Share this post
That is badazz :fing02: :fing02: :fing02: :fing02: :fing02:
Now how about a few more pix of it
Share this post
Glad to contribute to the team! Happy to help develop the pic, in Poncho's head. When Poncho called, my response was, "My help?" LOL. Seb is on the road to being legendary in paint and fab. Elated to see the culmination, of the vision.
Share this post
the r157 red is actually a 1965 gm colour
GM:
Would you happen to have the PPG code for that? PPG is what my GM body shop man uses.
Pete
Share this post
Here are 2 PPG paint codes, via there prophet system. In spite what I was told, by one fool, THEY DO NOT have a national data base, conglomerated with there prophet system. I had them mixed at 2 different distributers, and there lables are different. I don't know why. From the following info, I haven't had a problem getting more mixed, regardless of distributer. So, here they are for Deltron 2000.
**ALL ARE FOR 1 PINT**
----R-157----'02-'04 red
VOC: 5.8/% Lead: 0.00/ MSDS: DBC1
Tinting Guide: DBC75057 T
DMD1677 332.4
DMD1609 42.9
DMD1692 19.3
DMD1684 4.3
DMD642 3.9
DMD648 2.1
DBX1689 40.8
So are you saying all of these codes are the same color or does it take 7 numbers to constitute a PPG code? Stupid minds want to know. :fing02:
Share this post
DMD1677 332.4
DMD1609 42.9
DMD1692 19.3
DMD1684 4.3
DMD642 3.9
DMD648 2.1
DBX1689 40.8
So are you saying all of these codes are the same color or does it take 7 numbers to constitute a PPG code? Stupid minds want to know. :goofy:
The quote, you have, is the total break-down, of R-157,.....yes. they all contribute.
Share this post
DMD1677 332.4
DMD1609 42.9
DMD1692 19.3
DMD1684 4.3
DMD642 3.9
DMD648 2.1
DBX1689 40.8
Pete, a color CODE is the name or code for a color FORMULA. The list of components above is the autobody technician's "recipe" - the FORMULA for mixing up one pint of color CODE R157 red.
Remember yellow + blue = green from elementary school? This is a more advanced version. The numbers following each line item is the weight or "part" of the product added to the mix.
To mix the pint of R157 for you, the tech will take a pint container, put it on a scale, zero the scale, and add the amounts listed above.
Share this post
DMD1677 332.4
DMD1609 42.9
DMD1692 19.3
DMD1684 4.3
DMD642 3.9
DMD648 2.1
DBX1689 40.8
Gotcha :goofy:
Share this post
I used PPG Omni, , but they recently can out with ProLine to semi replace Omni even though you can still get Omni. Done a few bikes and have been pretty happy with the results! :goofy:
Kevin:
Do spray your paint on or do you still use a 1" brush?
Pete
Share this post
Paint formula for 2005 Winning Red: *****Makes 1 U.S. fluid ounce*****
Riv, please add this to your list above for easier reference, at your convenience... :fing02:
Manufacturer: Subaru
Brand Code: 77605 Main Layer 77605
OEM Code: O1W
Description: PREMIUM RED
Mixing Scheme: DELTRON 2000 (DBC SOL)
Price Code W
Variant: PRIME
MSDS: DBC1
SKU----------Desc.----------Increment:----------Cumulative:
DMD1677------RED------------30.3----------------30.3
DMD1605------MAGENTA--------1.4-----------------31.7
DMD1684------WHITE----------0.4-----------------32.1
So if you need to match this color, just print this post and bring it to an autobody shop that uses PPG products. They will know what to do with it. If they don't, run away! Run far, far, away!! :beer:
Share this post
-----5th and 6th gen. side case cover touch-up------
Dupli-color auto spray
EDSFM 286
or upc: 026916122865
Couldn't source this in Canada (for my 04 VFR Clutch Cover ). The identical match here is Dupli-Color Perfect Match CBHA0928 Graphite Grey Met (NH91M), which I found at Canadian Tire in the Honda car/truck paint section. It's a 227g spray can (about 2/3 the size of a regular aerosol paint can).
Share this post
Yes I'm guilty of bringing back a relic but it has great info. Also new to the forum!
Here is my question, since the formula for the R-157 is for a pint, will 1 pint cover all fairings and tank? Or do you typically need more to cover all the bodywork?
Also since Deltron 2000 has been phased out for more friendly versions does this effect the tinting guide or is that the same as the rest of the formula?
Thanks!
Share this post
Timmy, are you going to post the formula for flat black? Undiscriminating minds may want to know.
Share this post
----NHA30M----('05 SILVER)
Brand Code: 301274 DBC (Deltron 2000)
DMD649 65.3
DMD1682 315.2
DMD1683 41.9
DMD624 9.1
DMD1607 5.2
DBX1689 65.3
Nice! NHA30M (Digital Silver Metallic) is the trim color on the VFR1200. I really don't like paying ColorRite's ransom money. I will get a pint of this at my local PPG shop. I've got panniers, top cases and a hugger I'd like to color match. The main color, Candy Prominence Red, is a 3-stage paint and too much hassle. Plus it's a bit too loud to put on the accessories. Besides, silver is nice and generic, in case I need to re-use the luggage on another bike.
Thanks for posting this.
Share this post
Is there any info on the color for the silver wheels that the 6th Gen VFR's have.
Share this post
