Radiator Fan Ground
Guest ShyLion1977
Guest ShyLion1977
OK I got have a 1987 VFR 700 cheater. My problem is that when I got it the radiator fan was not grounded. I could not figure out where to ground it, so logically I grounded it to the frame. The only problem is that when I do that it causes a one volt drain on the battery. Can anyone tell me where the proper place to place the ground wire for the radiator fan is?
Nope that tells me where the radiator fan ground is not where to ground it. Can anybody check please?
This is where is goes for the VFR750F, perhaps it will help you
ok...very simple.. green to frame..or another green wire...
if the fan stays on when you turn of the bike, you have hooked up the power befor the switch... redo the power wire...not the ground.
