Guest VFR JUNKIE Posted December 6, 2006 Share Posted December 6, 2006 Hey everybody! When I tried to start my 4th gen VFR nothing happened, I had power but it just seemed like it was not getting to the starter or something. Anyone have any ideas? Link to comment Share on other sites More sharing options...
Member Contributer Burns Posted December 6, 2006 Member Contributer Share Posted December 6, 2006 go w/ the obvious first - check the starter, and the switch.. Link to comment Share on other sites More sharing options...
Guest Posted December 6, 2006 Share Posted December 6, 2006 Ok will do thanks. Link to comment Share on other sites More sharing options...
Member Contributer Burns Posted December 6, 2006 Member Contributer Share Posted December 6, 2006 as I'm looking through the manual, I'm seeing a few switches (like the side-stand, clutch) and and a relay that could be likely culprits... you can download the manual here, BTW... and not to sound ignorant, but your ignition switch on the handlebar is in the 'ON' position, correct? Link to comment Share on other sites More sharing options...
Guest Posted December 7, 2006 Share Posted December 7, 2006 as I'm looking through the manual, I'm seeing a few switches (like the side-stand, clutch) and and a relay that could be likely culprits... you can download the manual here, BTW... and not to sound ignorant, but your ignition switch on the handlebar is in the 'ON' position, correct? Ok I will heck the manual thanks, and the ignition switch was on :D Link to comment Share on other sites More sharing options...
