Handlebar Risers
Guest Aardvark892
Hi everyone, I have 1-inch or 3/4-inch risers with the stock clipons. It appears the clipon is pinned into the riser and the riser is pinned to the triple tree. (Confirm this?)
I would LOVE to rotate my clipons forward slightly to reduce the bend in my wrist. I'm waaay more broad-shouldered than the test person who sat on the bike when they determined the bar angle. smile.gif I have to bow my arms in funny for it to be comfortable...
Other than helibars...can I do anything with the risers and stock clipons I have??
Thanks so much,
~Adam
Hi Adam,
You have tried slackening the bars off and pushing them forward to take up the movement in the assembly ? There isn't much there but it may help. Otherwise your options are simple : File off some of the front edge of the engagement tab on the bars, or the risers,or both. Obviously this reduces the strength..
The risers replicate the tab engagement , so some people will simply lift the stock bars up the fork leg and retighten them there without a riser - this gives the same effect but the bar WILL rotate around the fork leg under heavy pressure so that would be your call safety wise. It could turn a simple parking lot tip-over into a new tank purchase..
In any event, you won't be able to move the bars FAR forward without finding the levers/switches hitting the fairing on full lock.
Rod
Rod,
Are you still selling Bar Risers? How does one go about seeing/ordering them?
  • 11 years later...
