Member Contributer tbzep Posted March 25, 2006 Member Contributer Share Posted March 25, 2006 Does anybody know of a cheap source for the wiring connector on the license plate bracket? It's not like anything available at the local hardware store. I want to make up a few license plate lights that will plug directly into the OEM harness without having to cut and splice. Service Honda wants the whole base assembly for $17 plus a minimum of $9 shipping. It's #4 on this diagram. All I need is the connector. Microfiche of part. Edit: I forgot to mention this is for the 6th gen bikes, just in case other generations use different connectors. Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted March 25, 2006 Member Contributer Share Posted March 25, 2006 Does anybody know of a cheap source for the wiring connector on the license plate bracket? It's not like anything available at the local hardware store. I want to make up a few license plate lights that will plug directly into the OEM harness without having to cut and splice. Service Honda wants the whole base assembly for $17 plus a minimum of $9 shipping. It's #4 on this diagram. All I need is the connector. Microfiche of part. Edit: I forgot to mention this is for the 6th gen bikes, just in case other generations use different connectors. <{POST_SNAPBACK}> Check out californiasporttouring, they offer some connectors that may work, they have pictures of them on their site you can compare. Link to comment Share on other sites More sharing options...
Member Contributer johne Posted March 25, 2006 Member Contributer Share Posted March 25, 2006 Sure looks like a 4th gen one,....if it is you can have mine :pissed: Link to comment Share on other sites More sharing options...
Member Contributer rjstaaf Posted March 25, 2006 Member Contributer Share Posted March 25, 2006 Not sure if they have the exact connector but, loos like you might possible find a match here... http://www.electricalconnection.com/electr...nts/hitachi.htm Link to comment Share on other sites More sharing options...
