Forum CEO HispanicSlammer Posted February 21, 2003 Forum CEO Share Posted February 21, 2003 Change Your CHAIN and Sprockets I bought an RK gold x ring CHAIN and sprocket kit from AZ motor-sports for $140, the sprockets are OEM size and steel. I decided that I was going to clean out all the gunk that has built up for the last 30k miles on my swing arm, CHAIN guides and whatever else needs cleaning. I took off my wheel and moved the exhaust out of the way. Loosen the 17mm pinch bolt I decided to take off the CHAIN guard so I can clean that too unscrew the 2 plastic fasteners and pull them out. Remove the Hose stays, they bone shaped backers will fall out so be careful not to loose them 4 screws 2 places Here is a tip - after you clean up your CHAIN guide use some tape to stick the bone shaped backers in place makes reinstalling much easier. Remove the 2 hex bolts and take off the CHAIN guide. I loosened the rear sprocket nuts Remove the 6 bolts that hold on the clutch slave and speed sensor to get to the front sprocket, make note of the which bolts go where, they are odd sizes. So thats what the speed sensor looks like, it just couples over the bolt on the sprocket. OH my God look at all that gunk! don't loose the dowel pins inside 2 of them. With the bike in 6th loosen the bolt, I forgot the size 14mm it think, its a normal bolt not reverse thread. WAY easier than those stupid Suzuki Hex bolt and nut combos. I removed the metal CHAIN guide the crescent shaped plate with the holes in it and cleaned it up, and cleared all that gunk out of there, I just unbolted the swing-arm pivot axle and removed the sprocket and CHAIN intact. I also have a CHAIN breaker that pushes out the pins but I did not use it since the kit CHAIN is the right length, its a pain to use. Here is the new stuff Remove the rear sprocket now Sprocket comparison, definitely had signs of wear, its hard to spot but these sprockets would have killed my new CHAIN if I had not changed them out too. The front does not look worn at first glance look again I made a huge mess cleaned up all the gunk inside the sprocket well, the metal CHAIN guide, the CHAIN guard, the rubber CHAIN guide I used my CHAIN press tool to press on the master link. Pressed on now it need to be peened out. don't forget to put the O-rings on first. Fit in a rivet peen on the CHAIN too and went at it I measured the staked area 5.82mm (5.55-5.85 limit) Replace everything and your good to go, the front bolt 38ft/lbs the rear nuts 25ft/lbs 1 Quote Link to comment Share on other sites More sharing options...
Member Contributer texasvfr Posted December 29, 2011 Member Contributer Share Posted December 29, 2011 Thanks so much for the right up ! I am in an area where I have access to a shop but do not have my shop manuals and I know that a chain is just a chain but seeing your pics are invaluable to me !!! Thanks again, David Quote Link to comment Share on other sites More sharing options...
PeterConnor Posted February 6, 2014 Share Posted February 6, 2014 Thanks , il be replacing mine soon :) Quote Link to comment Share on other sites More sharing options...
nearfreezing Posted April 29, 2014 Share Posted April 29, 2014 Great write-up... shows there are a couple ways to remove the chain. Will be using this to help me replace the chain on my '02. Quote Link to comment Share on other sites More sharing options...
DfnsMn69 Posted April 29, 2014 Share Posted April 29, 2014 I don't see any evidence of a gasket on the slave cylinder cover am I just missing it or is there not a gasket there. Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted April 29, 2014 Member Contributer Share Posted April 29, 2014 No gasket ... This a old thread .. Quote Link to comment Share on other sites More sharing options...
