Bryanzx6r Posted April 28, 2023 Share Posted April 28, 2023 Please 🙏 help Link to comment Share on other sites More sharing options...
Member Contributer DannoXYZ Posted April 28, 2023 Member Contributer Share Posted April 28, 2023 One or more safety-interloc switches are broken or wiring in between is broken. Measure clutch, sidestand and neutral switches and verify they work properly. Then measure line to ECU and verify signal actually nakes it there. Could be corroded terminals in connectors or broken wire along way. Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted April 28, 2023 Member Contributer Share Posted April 28, 2023 1 hour ago, Bryanzx6r said: Please 🙏 help Why post this twice???? Just makes for a messy confusing situation. As per your other post! Check your Sidestand Switch. Link to comment Share on other sites More sharing options...
Bryanzx6r Posted April 28, 2023 Author Share Posted April 28, 2023 13 hours ago, Grum said: Why post this twice???? Just makes for a messy confusing situation. As per your other post! Check your Sidestand Switch. So It looks like the switch has been removed because it's not there and if Im correct on the placement it would be on the kickstand correct Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted April 28, 2023 Member Contributer Share Posted April 28, 2023 It is mounted to the backside of the side stand pivot bolt. Is the side stand warning light lit on the dash? Link to comment Share on other sites More sharing options...
Bryanzx6r Posted April 29, 2023 Author Share Posted April 29, 2023 6 hours ago, Captain 80s said: It is mounted to the backside of the side stand pivot bolt. Is the side stand warning light lit on the dash? No it's not lit Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted April 29, 2023 Member Contributer Share Posted April 29, 2023 2 hours ago, Bryanzx6r said: No it's not lit Use this diagram to do some measurements Locate the switch wiring connector and check that the Ground is good. Check that the switch transfers the Ground to the Green/White wire in the Up position, and to the Yellow/Black in the Down position. The Sidestand warning light will either be a blown globe, bad Sidestand ground, faulty switch or wiring. The ICM Must see a Ground from the Sidestand Switch on the Green/White wire when Up - if Not = Dead engine when placed in gear. Link to comment Share on other sites More sharing options...
Member Contributer DannoXYZ Posted April 29, 2023 Member Contributer Share Posted April 29, 2023 9 hours ago, Bryanzx6r said: It looks like the switch has been removed because it's not there and if Im correct on the placement it would be on the kickstand correct Important safety-feature as well as for operations. https://www.ebay.com/itm/204155108287 Link to comment Share on other sites More sharing options...
