nicoAK Posted April 18, 2023 Share Posted April 18, 2023 Hi all, New to the VFR scene so take it easy on me please 😅 Recently bought a 96 VFR750, after the previous owner passed away, for £600 and a promise to his wife/widow I’d get it back on the road again…but I’m starting to think I might have to break that promise 😫 Last MOT’d 2012 so I kinda knew they’d be some work to do but mechanically the bike is actually sound…brakes, clutch, carbs, steering column bearings, exhausts etc are all in good condition which surprised me. Now this is where I get lost 😂 there was no spark on cylinder #4 (front right as you’re sat on the bike) and I couldn’t smell fuel. Swapped coil4 for coil3 and it worked but coil3 still wasn’t firing in cylinder #4. So all coils work fine but not when they’re in #4. Found the previous owner had chopped some bits and wired in his own relay near the CDI unit, and I’m sure it involved the red/yellow wire for coil4 but can’t remember exactly. Instead of spending hours/days/weeks chasing wires I bought a 2nd hand loom from eBay so everything would go back to standard…or so I thought…everything all plugged together but still no spark on #4 🤬 So my plan now is to purchase a 2nd hand CDI unit and hope that will fix it, maybe? Can somebody/anybody help with suggestions as to whether I’m on the right track…or a wild goose chase 🤣 Any help will be very much appreciated 💙 Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted April 18, 2023 Member Contributer Share Posted April 18, 2023 Used CDIs for those bikes (with return policies) are relatively cheap. If that is a better route for your then proper electrical testing, that could very well be the culprit. At least you will know, and the chance of another CDI having the exact same issue is VERY low, as they are not known (to me) to be fragile.  Good luck. Link to comment Share on other sites More sharing options...
Member Contributer tsmitty Posted April 18, 2023 Member Contributer Share Posted April 18, 2023 make sure that spark plug hasn't taken a dump.  Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted April 18, 2023 Member Contributer Share Posted April 18, 2023 1 minute ago, tsmitty said: make sure that spark plug hasn't taken a dump.   Exactly. Suggestions are often made assuming the basics have been covered and some body is genuinely lost. Link to comment Share on other sites More sharing options...
nicoAK Posted April 18, 2023 Author Share Posted April 18, 2023 Thanks for the help guys. I’ll be honest Captain, they may be simple on an old bike like this but electrics have never been my strong point. I wouldn’t have a clue what any volt meter readings mean or if I’m even testing the correct wire 😢 that’s why I put all my hope on a used loom fixing the problem. There’s a breakers local to me in Leicester that have one for £50 but they do a no returns on electrical items. Looks like I might just have to bite the bullet and hope for the best. And tsmitty the plugs are all brand new NGK Iridium and they all have a healthy spark when they’re plugged to coil 1-3 just nothing from #4. Thanks again Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted April 18, 2023 Member Contributer Share Posted April 18, 2023 11 minutes ago, nicoAK said: Thanks for the help guys. I’ll be honest Captain, they may be simple on an old bike like this but electrics have never been my strong point. I wouldn’t have a clue what any volt meter readings mean or if I’m even testing the correct wire 😢 that’s why I put all my hope on a used loom fixing the problem. There’s a breakers local to me in Leicester that have one for £50 but they do a no returns on electrical items. Looks like I might just have to bite the bullet and hope for the best. And tsmitty the plugs are all brand new NGK Iridium and they all have a healthy spark when they’re plugged to coil 1-3 just nothing from #4. Thanks again  With return policy in UK  eBay VFR CDI Link to comment Share on other sites More sharing options...
nicoAK Posted April 18, 2023 Author Share Posted April 18, 2023 Thanks for that Captain. I’ve been looking for the last couple of days and found there’s quite a few 94-97 units on there, most between £50-£80. The code is very similar to mine but the last 4 digits are different, mine is 6227. So my next question is…do all CDI’s have different codes so I can use any or do I need to find an exact match? Many thanks Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted April 18, 2023 Member Contributer Share Posted April 18, 2023 Any 94 - 97 CDI is applicable. No differences. Link to comment Share on other sites More sharing options...
nicoAK Posted April 21, 2023 Author Share Posted April 21, 2023 CDI unit arrived in the post this morning…fitted to the bike this evening. SHE LIVES TO FIGHT ANOTHER DAY! I’m so happy right now! It was really starting to fry my brain so I genuinely cannot thank you all enough for helping a random stranger 😅 Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted April 21, 2023 Member Contributer Share Posted April 21, 2023 Hell YES!!  Very cool. Link to comment Share on other sites More sharing options...
willybum Posted April 26, 2023 Share Posted April 26, 2023 My problem is my front 2 cylinders have no spark but the rear 2 do.....coils are good changed CDI box...any suggestions Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted April 26, 2023 Member Contributer Share Posted April 26, 2023 3 hours ago, willybum said: My problem is my front 2 cylinders have no spark but the rear 2 do.....coils are good changed CDI box...any suggestions Refer to your other posting!! Link to comment Share on other sites More sharing options...
nicoAK Posted May 1, 2023 Author Share Posted May 1, 2023 On 4/26/2023 at 2:43 AM, willybum said: My problem is my front 2 cylinders have no spark but the rear 2 do.....coils are good changed CDI box...any suggestions Sorry but I can’t help you there. Looks like you’ve had a reply on your original post about checking the pulse generator. It would probably be wise to check the said item as that sounds like a good place to start. Even if it ain’t that, it will give you peace of mind that you’ve had it off and checked/cleaned it. Link to comment Share on other sites More sharing options...
