DTfan2 Posted March 23, 2023 Share Posted March 23, 2023 Hey guys, I've got a new factory water pump to install on my '01 VFR. The book shows the cover bolts and the mounting bolts being removed. Since the new factory pump I have has the cover already in place, can I just remove the mounting bolts of the old one and keep the cover attached on the new one when installing? thanks in advance!! 🍺 Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted March 23, 2023 Member Contributer Share Posted March 23, 2023 Yes. But it is nice to absolutely verify everything is cool inside your new pump, no FOD or pinched o-ring. Plus, I like to red rubber grease (or o-ring lube) the cover o-ring while its off. It also allows you to more easily "clock" the pump shaft slot to mate up nicely. Took me a few tries doing my 92 with the cover on recently. Link to comment Share on other sites More sharing options...
