VFR750F3 Posted January 15, 2023 Share Posted January 15, 2023 I purchased a $22.00 gas cap from Aliexpress ie Arashi for a Kawasaki. Cost me 2 cases of Heineken $60 to machine it down a little bit and about $6.00 in new bolts. Link to comment Share on other sites More sharing options...
VFR750F3 Posted January 15, 2023 Author Share Posted January 15, 2023 Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted January 15, 2023 Member Contributer Share Posted January 15, 2023 Yep, cool. I've made 3 now. Link to comment Share on other sites More sharing options...
VFR750F3 Posted January 16, 2023 Author Share Posted January 16, 2023 Nice Link to comment Share on other sites More sharing options...
Smack Posted January 17, 2023 Share Posted January 17, 2023 Could y'all elaborate on this? Replacement caps, okay. No key? Why did you have to replace caps, Cap? Link to comment Share on other sites More sharing options...
Member Contributer bmart Posted January 17, 2023 Member Contributer Share Posted January 17, 2023 I can tell you that track guys replace them to avoid the hassle of a key. They frequently go keyless to start also with a harness modification. One of my bikes is like that, the other is keyed for both. Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted January 17, 2023 Member Contributer Share Posted January 17, 2023 Yep, I built the RC26 keyless I had a gas cap key on a stud with a wing nut up on the upper cowl stay. That was fine, but I wanted to go full keyless just cuz. Well, the 86 VFR cap has a slightly different bolt pattern than later Hondas. I came across a brief mention on a NSR50 forum about the same problem and they mentioned a Kawasaki ZX cap that matched. So I started doing some research and decided to take a chance on what I thought was the correct one. I bought the cheapest used Vortex cap I could find. Had the OD milled down a couple millimeters so it recessed in the tank properly. I purchased a sheet of Viton rubber in the same thickness as the Vortex gaskets and cut out a new gasket with the correct ID for the cap and the correct OD for the fuel tank. Used some spacers to get the reveal height just right, but still make sure I was compressing the gasket enough. You can see the impression in the gasket showing the offset between the Kaw tank opening and VFR. Link to comment Share on other sites More sharing options...
VFR750F3 Posted January 17, 2023 Author Share Posted January 17, 2023 All my bikes I ride have keyless gas caps.. It is one less thing to do for my track bike and for my RRR with a keyless fob. And they look much better. Link to comment Share on other sites More sharing options...
Member Contributer bmart Posted January 17, 2023 Member Contributer Share Posted January 17, 2023 One keyless ignition option, if you trust humans. https://woodcraft-cfm.com/collections/keyswitch-elimination-harness Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted January 17, 2023 Member Contributer Share Posted January 17, 2023 28 minutes ago, bmart said: One keyless ignition option, if you trust humans. https://woodcraft-cfm.com/collections/keyswitch-elimination-harness Cool. I simply took an extra female connector like the ignition switch has and made the necessary connections with the R / R-BK going to a high quality marine toggle up behind the gauges. But this era of bikes can be simply "hot wired" like that and it enables full functionality. Quick flick with a finger. You can't really see it and nobody hardly notices what I'm doing. But it is a bike that I don't just leave unattended for long periods of time either. I can also slightly unplug the harness connector for a little more piece of mind if I'm concerned. I never have. Link to comment Share on other sites More sharing options...
VFR750F3 Posted January 17, 2023 Author Share Posted January 17, 2023 RFID for 20 bucks a little more work though. Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted January 17, 2023 Member Contributer Share Posted January 17, 2023 So that is just the harness connector to then go to one their custom switches with RFID being an option? Pretty cool. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted January 18, 2023 Member Contributer Share Posted January 18, 2023 21 hours ago, bmart said: One keyless ignition option, if you trust humans. https://woodcraft-cfm.com/collections/keyswitch-elimination-harness Sorry, $65 for some wire and connectors? I must be missing something... Ciao, JZH Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted January 18, 2023 Member Contributer Share Posted January 18, 2023 5 minutes ago, JZH said: Sorry, $65 for some wire and connectors? I must be missing something... Ciao, JZH I kept looking for more in the description too. Then I realized it was just a sub-harness. Link to comment Share on other sites More sharing options...
Member Contributer bmart Posted January 18, 2023 Member Contributer Share Posted January 18, 2023 4 hours ago, JZH said: Sorry, $65 for some wire and connectors? I must be missing something... Ciao, JZH Correct. Most people don't know crap about crap, and the ability to toss the old stuff and plug-n-play with this items is totally worth it. and, it is a one time cost...which I can also say about the $200 I just paid a guy to not fix my KLX carburetor problem. Humans...the worst. Link to comment Share on other sites More sharing options...
