eNiMaLx Posted September 9, 2022 Share Posted September 9, 2022 I replaced both the CCTs 3000 mi ago. I just synchronized the starter valves. With the idle rpm set at anything below 2,000 rpm, 1st gear with no throttle (crawling) results in the bike hesitating until I pull in the clutch. In higher gears low rpms also result in the same hesitation. The noise is worse the nearer to 1,000 rpm I set the idle to. Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted September 9, 2022 Member Contributer Share Posted September 9, 2022 What you describe maybe normal clutch knock at idle... you see over time slop develops allowing the gear teeth to knock about and thus the noise... grab the clutch lever and the inner basket helps align the outer basket and the noise deadens... the only cure is to eliminate the slop with new clutch parts... namely replace the clutch guide p/n 22116-MCW-000 and clutch bearing p/n 91024-MB0-003... Link to comment Share on other sites More sharing options...
eNiMaLx Posted September 9, 2022 Author Share Posted September 9, 2022 58 minutes ago, BusyLittleShop said: What you describe maybe normal clutch knock at idle... you see over time slop develops allowing the gear teeth to knock about and thus the noise... grab the clutch lever and the inner basket helps align the outer basket and the noise deadens... the only cure is to eliminate the slop with new clutch parts... namely replace the clutch guide p/n 22116-MCW-000 and clutch bearing p/n 91024-MB0-003... I'll give that a try, thanks! Link to comment Share on other sites More sharing options...
