Member Contributer Skids Posted June 27, 2022 Member Contributer Share Posted June 27, 2022 How? I've removed the speed sensor take-off and still nowhere near enough room to get a socket on the banjo bolt. Is there some secret way of doing this that someone can whisper, or are you all just going to tell me to "person" up and use a spanner? Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted June 27, 2022 Member Contributer Share Posted June 27, 2022 Are you sure a 12mm ring spanner won't do the trick? Wouldn't worry about torquing up afterwards, firm tightness and it shouldn't leak. Link to comment Share on other sites More sharing options...
Member Contributer Skids Posted June 27, 2022 Author Member Contributer Share Posted June 27, 2022 56 minutes ago, Grum said: Are you sure a 12mm ring spanner won't do the trick? Wouldn't worry about torquing up afterwards, firm tightness and it shouldn't leak. Yes, you are correct m8, a ring spanner will fit but I am a pedant for torquing bolts correctly. Having said that, the male/female joints from the delay valve up at the headstock would not allow for a socket so I used 10mm/14mm spanners for that. Just wondered if I was missing something, a special tool or technique. Link to comment Share on other sites More sharing options...
Member Contributer bmart Posted June 27, 2022 Member Contributer Share Posted June 27, 2022 Are you trying with a 3/8 drive? 1/4 should fit just fine with a short/long extension. Link to comment Share on other sites More sharing options...
Member Contributer Bren Posted June 27, 2022 Member Contributer Share Posted June 27, 2022 No, doesn't fit on with the cover in place. You can only torque it with the cover removed and I think it's 34 nM so quite tight - check the manual! Have to wrap it in a cloth in a vise and righty tighty. Link to comment Share on other sites More sharing options...
Member Contributer Skids Posted June 27, 2022 Author Member Contributer Share Posted June 27, 2022 3 hours ago, Bren said: No, doesn't fit on with the cover in place. You can only torque it with the cover removed and I think it's 34 nM so quite tight - check the manual! Have to wrap it in a cloth in a vise and righty tighty. Not going to do that, but thanks. 34 Nm is correct, which, when applied to a shorter 12mm ring spanner is probably as tight as I can make it. Thanks all. Link to comment Share on other sites More sharing options...
