Member Contributer vfr800_red Posted June 26, 2022 Member Contributer Share Posted June 26, 2022 Hi, My 5th gen is having difficulty starting. I’m very confident the battery and charging system are fine. The battery is newish, and holding a charge, and charging system is delivering 14 V at 5000 rpm. Once the bike starts it runs fine. I suspect the starter motor is at fault. It is the original and has never been serviced –> the original brushes. Not only is the bike 24 years of age it has >85k miles. And I’m noticing more starter gear whine, I hear some whine even after the engine has started. Hoping I can get some thoughts and feedback before I start taking things apart. Thanks. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted June 26, 2022 Member Contributer Share Posted June 26, 2022 Removing the starter motor from a VF and VFR750 is quite easy. Especially when combined with an oil filter change. (The filter is in the way). see middle of page 50 🙂 Link to comment Share on other sites More sharing options...
Member Contributer Bren Posted June 26, 2022 Member Contributer Share Posted June 26, 2022 I also have a 98 and starting has always been good, it will start and idle a bit low then slowly creep up to where the fast idle is set but always first button push start. If your battery and charging is good then great, you know to check these things. Maybe the starter isn't releasing once started? I have no idea what could cause this though. I havent heard of anyone servicing or need to service the starter motor.... ever. Someone with more knowledge will come by I'm sure. Good luck with it as I'll be watching, just in case... Link to comment Share on other sites More sharing options...
Member Contributer airwalk Posted June 26, 2022 Member Contributer Share Posted June 26, 2022 My’95 developed a “sticky” start button years ago, being lazy I put a short piece of surgical tubing behind the lever/button, acts like a return spring & still works well. If my digital abilities weren’t so lacking I’d send a pic, hopefully you can visualize. Link to comment Share on other sites More sharing options...
Member Contributer vfr800_red Posted June 27, 2022 Author Member Contributer Share Posted June 27, 2022 Don't have a sticky starter button, but I get it, don't need a picture, and I like it, clever. I will say a few more starts seemed better. But this has but on a brief hold as I've identified an oil leak and am now waiting on parts. Should send an update later in the week. Link to comment Share on other sites More sharing options...
