? Part number/s for 6th Gen Front Fork Oil Seals. Please help.
Mait
Hay Guys,
Please help me order the right parts, my neighbourhood dealer is stup., doesn't know a thing. Oil seal on one of the forks is leaking; I want to get both forks done. Please have a look at the attached images and let me know which part numbers should I order.
Wondering if #21 51490-MCW-D01 is all that I need ? OR I also need # 10, #17 and #28 ?
It is for 6th gen 08 VFR800A - Interceptor ABS.
Thank you.
Max.thumb.png.8a7b41741ad057b412c47fa6d85ff39b.png1596499499_Screenshot2022-01-19142531.JPG.23624a9bda1eafd09c30bebe5f22d988.JPG2012685742_2-Screenshot2022-01-19143938.JPG.994f13c5f83b4a61c499627bcc1ab6f5.JPG
21 is the combination of the outer dust seal and the oil seal.
I'd also get 26 which is the copper sealing washer at the base of the fork; you can re-use these but old ones can weep sometimes.
If the bike has done a few miles you might also consider replacing the sliding bushes 11 and 12; these are teflon-coated on their sliding faces (outside of 12, inside of 11) and that can wear down over time.
You will need a least one litre of your favourite fork oil.
If the forks have a lot of miles, you may as well get the bushings. If not, just oil and dust seals!
I should have mentioned in the original post.
Only 9600 Kms (6000 miles).
Now tell me.
Thank you.
