Torque specs
FireWire
The assembly is bolted to the frame with four bolts, two are 8mm hex and two are 4mm hex. I cannot seem to find those specs and I don't happen to have a manual.
I took a spill making a right hand turn going about four or five mph. The results were a chipped and bent brake pedal. I have the replacement pedal but need to remove the foot peg assembly to replace the brake pedal which is mounted on the back side of the foot peg assembly. I called a Honda dealership and they were less than helpful. Since these are aluminum parts I run the risk of over tightening and stripping the bolt head and/or making it nearly impossible to remove the assembly in the future if necessary. I plan on adding a small amount of anti-seize paste on the bolt threads but I'd rather have those specs.
Thanks!
