Stumpy Posted July 23, 2016 Share Posted July 23, 2016 Hi guy's & Girl's, I'm new to biking only passed full licence last year. I have purchased a 93/94 plate VRF 750 great first time bike but experienced it not starting after a 2 hour ride in hot conditions. After trying various basics, battery connections, run switch, fuses and bump start. left it for 30 minutes and it started with no problem it has been service recently and a new battery, any thoughts. Link to comment Share on other sites More sharing options...
Member Contributer Forbes Posted July 24, 2016 Member Contributer Share Posted July 24, 2016 Look to plastic connector plugs, mainly from battery, ie thick wires. Some have had melt downs, look for discoloration of connectors and corroded terminals. Do any lights come on when this occurs? The fact you couldn't bump start could also point to no spark. Use a spare spark plug to check, but only when fault occurs. Others here may have more experience with your particular model. Sent from my HTC_PN071 using Tapatalk Link to comment Share on other sites More sharing options...
Stumpy Posted July 24, 2016 Author Share Posted July 24, 2016 Thanks, good ignition lights just nothing happens when you press the start button, definitely not useful if out and about does not give you much confidence to go far either. checked all you have suggested, nothing untoward found, I just have to test again now. Link to comment Share on other sites More sharing options...
squirrelman Posted July 29, 2016 Share Posted July 29, 2016 When it's running check the charging system output by measuring volts across the battery terminals at 5000 rpm. anything less than about 13.5 is trouble. Link to comment Share on other sites More sharing options...
