Welcome to VFRDiscussion
vfr750gaz
My modified VFR
79 posts in this topic
post-22571-0-03747200-1304262276_thumb.j
I have visited this forum on lots of occasions, but never got around to registering.
After looking at quite a few of the Frankenviffer threads i thought i would show my bike.
Its quite a collection of honda parts you will see.
Due to my work, its taken me alot longer than i would have liked to get it to its current build level.
Anyway its basically a VFR750 frame and engine of 1996 era with CBR1000RR forks, cbr900rrx swinging arm, VTR1000 wheels and cbr600rr seat unit plus loads of one off parts.
post-22571-0-76528100-1304262334_thumb.j
3 people like this
Share this post
Sorry about the pic sizes.
Heres some slightly smaller ones.
post-22571-0-01386000-1304262508_thumb.j
post-22571-0-93540500-1304262533_thumb.j
3 people like this
Share this post
LOOKS GREAT !!!!!!!!!!!!!!!!!!!!! Your almost there .
Share this post
Welcone to VFRD from across the Norht Sea
A super looking Über-Frankenviffer :fing02:
Share this post
Thanks for sharing, looking Good! :fing02:
Twin rear is a cool add! :beer:
BR
Share this post
Looks really great. :fing02: I like the USD fork setup along with the rearsets.
Share this post
information on how you got that swingarm on that bike would be VERY VERY VERY appreciated. please share it with us!
Share this post
and where did that set of gauges come from? did u get them off of ebay from china? because it does NOT look like a koso setup, no shift light
Share this post
OK, I can get behind the swingarm, etc, but I have a concern about those oil lines. They stick out very far. Maybe a 90 fitting and run them near the radiator or something?
And maybe some mirrors and turn signals? Or combined?
I'm not really into the naked look, but nice clean job anyway.
Larry
VFRrider
Edited by vfrrider
Share this post
1st off mate, Welcome.
Bloody-L that's a sweet ride, love what you did to it.
Share this post
The swinging arm fits straight into the frame once 12mm has been trimmed from the righthand inside of the frame. I used cbr900rrx linkage plates and dogbones and they all bolted on with no mods.
Really quite a straightforward convertion. the hard part is getting the exhaust routed through the swinging arm beside the shocker.
Share this post
Larry
VFRrider
Hi Larry, thanks for the concern about the oil cooler lines. i have got a bracket to fit to the righthand oil line, but it wasnt fitted in the photos as i'm still finishing bits and pieces off.
Share this post
The clocks are from Dan moto in china, but are on the to get changed list as they wont work with the VFR loom. i have another set of clocks on the way that are koso ones but not the same style.......hopefully these will resolve the issues i have at the minute.
Share this post
welcome ,nice machine :fing02:
Share this post
Thank you kind sir
Share this post
do u have any pictures of this modification? i am concerned about the strength of the frame where the adjuster goes into it.
does this offset the swingarm enough that u have to change around the rear wheel spacers?
Share this post
Hi,
Sorry i dont have any pics of the modification. Theres no way the strength of the frame is compromised as the threaded adjuster has more than enough meat on it to tolerate having the 12mm removed from it. I have an early fireblade and its adjuster is much narrower as standard.
The wheel fits straight in using the standard wheel spacers etc and runs central in the frame without mods.
Share this post
Very nice, and ditto on the oil lines. Need to tuck those away somehow. Other than that, great show!
Share this post
Hi,
did u use the 900rr swingarm pivot bolt and frame adjuster? how did you remove the 12mm from the frame and keep it perpendicular to the pivot shaft?
can you take some closer pictures of the exhaust and shock area please?
Share this post
Hi,
You can use the standard pivot bolt, but the adjuster will need shortened to suit the mod. i hacksawed 10mm from the inside of the frame and used a facing tool a madrel that was a snug fit in the pivot bolt holes to clean the last 2mm off.
As for pics of the exhaust and shock area.....i will try and take some, but it wont help you carry out the work to be honest as the rear cylinders headers are entirely dependant on the exhaust your using.
Share this post
Hi,
U didnt have to move the shock pivot on the swingarm at all?
Share this post
Hi,
The shock pivot point on the swinging arm matches up perfectly. Thats why the vfr swinging arm into a fireblade is so easy (all offsets and distances are the same).
Share this post
Nice work gaz, looks great! I like it a lot, except the headlights... they're a bit high.
What brand of front rotors are you running?
& is there any chance you can post a nice sound clip for us? :musik20:
Share this post
Im personally, absolutely in love with this bike! Couldnt think of a better way to make a custom 4th gen! (Aside from a vfr800 engine:)
Share this post
I guess the headlight height is down to personal preference and i like them where they are.
The front rotors are PFM supersport discs that were originally intended to go on a CBR900RRX (310mm diameter).............I had alot of work to do in order to get these to fit both the wheel and the forks.
The PCD for mounts were correct, but the centre hole was slightly too big and then i had to space them out by 4mm per side to bring them into the centre of the radial calipers.......all sorted now though.
I could do a video of the bike running, but unless i can borrow an expensive mic then it wont do the bike justice..............but i will say it sounds like no VFR i have ever heard before!
Share this post
Create an account
Register a new account
Sign in
Sign In Now
