Welcome to VFRDiscussion
Sign in to follow this
Followers 0
Leeworthy
Low Speed Wobble
So this morning on my way to work, my sleeve on my jacket started coming up. So i let go of the bars and tried to zip it back up. When I looked back down, I noticed my bars wobbling back and forth. Excessivly. I was only doing about 60km/h when it was happening so not bad, but still. What causes this? I was heading down a hill, and letting the bike brake itself with the engine. Any ideas? As soon as I grabbed the bars again it stopped.
Share this post
Is your front tire the factory size or have you changed it? Have you raised the rear ride height or lowered the front height? How high is the preload on your rear shock? Has the bike been down before?
Share this post
Everything is stock. Rear Preload is around 7Psi, Front is stock. Wheels are both stock sizes.
It has never happened before,. Maybe just chalk it up to road conditions?
Share this post
All previous questions were related to possible excessive loading of the front and shortened rake/trail. Make sure the forks are straight. Simple answer is, if it becomes recurring you can put a steering damper on it.
Share this post
Possible front tire cupping also................ :mellow:
Share this post
what he said...check your tire pressure
Share this post
Okay cool.
i didnt know you could get steering dampers for my model and year. 83 VF750
Share this post
Okay cool.
Not specifically, afaik, but you could fit one with relatively minimal effort.
Share this post
If you're on stock tires with around 5k miles, it's the tire cupping.
Share this post
Stock sized tires. not stock tires.. Bike has 63000km on it... Im running BT45's
Share this post
Definetly check tire pressure. When mine got down to blow 30 psi it felt like a brake dragging and developed the wobble you described. I'm also running BT45's with about 1,000 miles on them.
Edited by L8asusul
Share this post
My first guess would be steering head bearings... either loose or the balls have recessed themselves in the races. Hold the front off the ground somehow and move the handlebars slowly just across center, see if the front "settles" right in the center. If it does replace the head bearings. With the front off the ground, pull the front wheel perpendicular to the forks and see if there is movement, if so you can tighten the top head race a little. If you have a center stand, make sure it isn't the stand moving where it attaches to the bike if you feel movement. Replaced head ball bearings with roller bearings, problem gone.
Share this post
My 1990 3rd Gen has done this for a few seasons...a fellow rider who is more "seasoned" than me (read - old, as in ancient) named Dude (not the one in The Big Lebowski) told me that I have some cupping in my front tire, which is a stock BT020. If I take my hands off the bars between 80-60 kph, the wobble is there. You don't feel it with hands on the bars, and it's not there with hands off at higher speeds. It seems to be there all the time; I'm pretty diligent with tire pressure.
I haven't gotten to bent about it; I reckon it will go away with new rubber which I plan for next season. :mellow:
Share this post
You're experiencing front end trail wobble and it's normal... some bikes may
wobble decelerating through the 45 mph range... keeping your hands on the bars
cures the front end wobble... some bikes wobble more than others and it's no
big deal with your hands on the bars in the critical speed range... your bike
should be immune at speeds above 45 mph...
The wobble is essentially a steering oscillation of the front forks that
doesn't involve the rear frame is any significant way... Typical 4 Hz for heavy
bikes and 9 Hz for lighter bikes... The frequency increases as the trail
increases and as front weight decreases... it depends essentially on the side
grip of the front tire... Manufactures work hand in hand with tire designers to
produce a bike and tire combination that quills the nature frequency of the
front to wobble... Haven't you noticed on some new model bikes they call for a
specific tire??? As that tire wears down and needs replacing the owner can go
with the known stock tire or venture into the unknown choosing a different
manufactures tire... he may get lucky and find a tire with the ability to quill
the natural frequency of the front wobble... or get unlucky a find a tire that
aggravates the front wobble... some tires dampened the wobble better than
others...
So if a wobble is chiefly the product of non OEM or a worn tires... then it ain't the product of tire cupping...
but low pressure or loose steering head bearings defeat the tire's corrective efforts... because every bike
has this instability... it is held in check by damping forces created mainly by the tire's self-correcting
tendencies... read on...
Motorcycles are only stable when they are moving. We all know that.
If you walk away from one without putting some sort of stand under
it, it'll fall over. The problem is that a moving motorcycle isn't
necessarily all that stable either. There are forces that constantly
work to make a bike crash; it is the designer's job to make sure
these upset-ting forces are completely damped. The fact that
motorcycles continue to weave, wobble and tip over after nearly a
century of continuous development is proof of the difficulties
involved.
WEAVE AND WOBBLE
Most of us have experienced a wobble or a weave or have been told
about them. Few of us have a clear understanding of what a wobble
or weave actually is. Motorcycle instabilities are usually lumped
into a catch-all description wobble. Before one can do anything about
a problem, one must first understand its nature. There are three
destabilizing forces acting on a motorcycle as it moves down the
road: weave, wobble and upset. When a bike weaves enough to notice,
the front fork assembly remains straight and the rest of the motorcycle
moves from side to side several times each second. A bike that is
seriously wobbling shakes its head while the rest of the machine remains
mostly straight and stable; the shaking (wobble) is very rapid and
difficult to control. Upset simply describes the same tendency to fall
over as the machine has when it is stopped.
When interpreting the dynamics of motorcycle stability, it is useful
to view a motorcycle as having two major dynamic assemblies: the chassis
aft of the steering head and the front fork assembly. Like the wheels
of a shopping cart, these assemblies can sometimes embarrass us.
Any motorcycle chassis constantly tries to oscillate (weave) back and forth
about the steering head at between two and five times per second. Every
bike has this instability; it is held in check by damping forces created
mainly by the rear tire's self-correcting tendencies. If the tire's
natural oscillation frequency happens to coincide with the chassis,
the bike will weave. This seldom happens,though, as tires have much higher
frequencies than the typical chassis. For the tire to do its work, it must be
properly inflated and rigidly connected to the chassis. Worn swingarm
bushings, or poorly damped suspension springs can defeat the best tire's
stabilizing influence. Weight attached rigidly to the rear of a motorcycle
can slow the weave frequency and bring it into a range close to the
tire's, and serious weave instability can result.
Wobble describes the natural oscillation of the front fork assembly in the
steering head bearings. Proper front end geometry combines with self
correcting torque from the tire to damp this wobble force. Like the rear
tire, the front tire must have an effective connection to the fork
assembly to do its job. Underinflation,dented steering bearings, loose
fork sliders or limber fork tubes can defeat the tire's corrective efforts.
Chassis upset instability is simply the motorcycle trying to fall over,
as it does when at rest. Rake and trail act to harness the self corrective
forces of the moving front tire's contact patch. The net effect is to
keep the bike headed straight and the machine's center of gravity over
the tires' contact patches.
Upset instability is never, by itself, a serious threat. It can contribute
to a crash when a weave becomes so serious that the motorcycle's lean
angle during each weave cycle becomes large.
WHAT YOU CAN DO TO PREVENT WEAVE AND WOBBLE
A few of the factors that act to damp wobble and weave are, largely,
out of your control. Most, however, are in your hands. In fact, each
time you install a different tire or change the dampers, springs or
fork oil, you affect the stability of your motorcycle. Fork rake angle,
trail and distribution of the majority of the weight are fixed by a
motorcycle's design.
The tires and their operating pressure, weight distribution and the general
condition of the hinges (swingarm bushings, steering bearings, wheel bearings
are the most important factors of stability, and you control them. All of
us buy tires; few replace the originals with more of the same. Even the
best premium tires can fail to stabilize a particular motorcycle. That's
the reason your owner's manual specifies certain tires for your bike;
the factory has tested those tires on that model for stability. Germany
and Japan require that only tires which have been tested and approved
for use on a specific motorcycle be used on that motorcycle; in those
countries, you will get a ticket if you have unauthorized tires mounted
on your bike, even if only the speed rating is wrong. But you won't
necessarily have instability caused by non-standard tires.
While instability seldom arises when any premium tire is mounted on any
motorcycle, it can and has happened. A wide and sticky rear sport tire
can make many motorcycles weave. The excellent traction, which is why
a buyer chooses such a tire, can cause many a chassis to flex enough
to become unsettled and initiate a weave. There is nothing wrong
with the tire; there is nothing wrong with the various chassis. They
simply don't work together. Before you install an unknown tire on
your bike, ask around. See if anyone has had any problems when that
tire was mounted on the same bike model as you have. See what the bike
manufacturer says. If you can't get such feedback and mount the tire
anyway, be cautious about running at high speed. Slowly approach the
maximum speeds at which you intend to ride. And check the pressures often;
that is the most common maintenance failure, even among experienced riders.
Hopefully, the fear of wobble or weave will instill in you renewed
dedication to take care of the "hinges" on your motorcycle.
Worn rear tires are the most common cause of weave instability on a bike
that, until it suddenly started to squirm, was as stable as marble. Even
minor wear in the middle of the tire can create the slight alteration of
profile that creates instability. Many stability problems are the result
of deterioration of the swingarm bushings or steering head bearings. If
you keep them adjusted and lubricated, they will last many miles; the
act of inspecting and lubricating them keeps you aware of their condition
so you can replace them, if and when they do wear out. Most of us ignore
our bike's wheel bearings don't. Periodically check them for roughness
and play. Replace them if there is any of either. Lubricate them according
to the maintenance table in your shop manual.
Where you place weight on your bike has a tremendous effect on its high-speed
stability. Weight should be as far forward and as low as possible. Put your
tools in the tank bag rather than in the rear of the trunk. The worst thing
you can do is bolt weight to a rear rack. The late Kawasaki police motorcycles
have their heavy (47 pounds) radios mounted on hydraulically damped pivoting
mounts. They are also mounted where a passenger would normally sit. Speaking
of passengers, they actually help stability. The damping effect of a person
assists a tire in its efforts to keep you pointed in the right direction.
Aerodynamic effects can initiate weave or wobble. Saddlebags tend to spill air
around one side of the bike and then the other, just like a flag pole does. If
your motorcycle is fitted with saddlebags, you may have noticed that when you
place your feet on the passenger pegs the bike begins to slowly weave. If your
bike does that, either install a fairing of some sort, remove the bags or
don't go so fast. A fairing added to a bike with bags usually eases the weave
problem. It seems a fairing routes air around the saddlebags and eliminates
them as a source of aerodynamic upset. A poorly designed fairing or a poor
bike fairing combination can create wobble. If your bike does this, at
least you know the cause... you may decide to take the fairing off and get
one with a successful history on bikes like yours. Fairings can unload the
front wheel at high speed which encourages an undamped wobble.
WHAT TO DO IF YOU GET INTO ONE
The faster a motorcycle goes, the less stable it becomes. Think about that the
next time you casually decide to "see what she'll do."
The deceleration shimmy is a wobble many riders experience between 50 and 35 mph
when they take their hands off the bars during deceleration
is unimportant and can sometimes
be tuned out by adjusting the fork for
smooth operation and, if necessary,
changing the front tire.
A real wobble, one that can force the bars out of your hands, bang the fork
against its travel stops six to ten times per second and cause the front
tire to leave crescent-shaped marks on the roadway gives you very little time
to do anything about it. Most experts recommend slowing down and easing your
grip on the handlebar. When you grip the handlebar tightly and set the muscles
in your arms and back (fear does that), you alter the frequency of the fork's
natural oscillation. Unfortunately, that alteration makes the tendency to
wobble worse. You can, under the right conditions, initiate a wobble by simply
gripping the handlebar and setting the muscles in your upper torso. If
you get into one, slow down and relax your grip on the handlebar. I realize this
action will take the resolution of a saint, but it is probably the best solution.
Weave instability seldom results in a fall. While the onset of a wobble can be
very sudden and energetic, a weave tends to gradually build in intensity with
additional speed and can be controlled by merely slowing down. If a weave is
caused by a flopping flat rear tire or if it happens in the middle of
a high speed corner, things are a little more dicey. Still, you can get out of
it if you keep your head. Should you suddenly find your bike weaving under
you, do two things: lie down (bend forward) and move your weight as far forward
as you can. That's it. Unless there is some mechanical condition sustaining it,
the weave will stop within three seconds and usually less than two. This action
reduces the polar moment of the chassis assembly, increases its oscillation
frequency and gives the tire a better shot at damping the weave.
It's not advised to power through a weave or wobble. Although a bike will
sometimes regain marginal stability with an increase in speed, don't take the
chance. Remember that if you power out of a weave or wobble, you still have to go
through the same speed range on the way to a stop.
I hope this primer gives you a basic understanding of the problems involved in
making a motorcycle stable. You now know the difference between weave and
wobble. You also know what some of the forces are that cause them, and you
know what major components most affect your bike's stability. I hope you think
about these things when you inspect your bike for wear and tear, when you buy
tires and before you decide to go real fast. A motorcycle in good condition and
fitted with compatible tires is much safer at any speed. A rider who knows what to
do if things go wrong, will, in the final analysis, have more fun, which is why we
ride these things in the first place.
Share this post
I haven't gotten to bent about it; I reckon it will go away with new rubber which I plan for next season. :unsure:
Havent you replaced that cupped front tire yet Cbar? :mellow: :mellow: I prefer seasoned to ancient though :fing02:
Share this post
Followers 0
