rear wheel weights on my digital scale
Jus weighed my spare bare 5th and 8 spoker.
5th gen rear is 6.050kg
8 spoke is 5.870kg
Not a lot lighter, but a saving never the less.
Mike:
Theres about 2 feet of snow on the ground and the 4th gen in buried in the garage behind the a bunch of bikes so I found this pic which gives a better angle on the Frame sliders.
The sliders are an e-bay item, $14, The HT bolts that I cut down and threaded and the Lower rod are from McMaster Carr, I think $15 total, The tubes are Steel cut to size $5. The straps I made from stock I had lying around.
If you want detailed lengths, I'll take them off and measure at some point, just shoot me a PM.
very nice, a question:  it appears there is an extension fairing on the belly pan that covers the kickstands and almost goes back to the rear wheel..is that a stock item?
It really gives the bike a great appearance
Sadly, only the '90-'93 3rd Gen VFRs had these extra panels. Perhaps a small amount of weight was saved but they did add a touch of class.
Btw, John's bike lacks a small trim panel on the kickstand itself. But indeed, his is a beautiful VFR.
FWIW, my recently powdercoated 8-spoke wheel weighs 5.75kg (without stem).  Factory painted I would expect to be slightly lighter.  Sadly, I don't have a spare 5-spoker to compare it to at the moment.
Ciao,
I do have it, the pesky screw lug plastic bits have broken, though - so I need to fix them up. I also have the original headlight protector!
