'86 VFR750 engine oddities
squirrelman
posted  this @  http://vfrworld.com/threads/what-do-i-have-here.54567/#post-576927
 i hoped and expected to buy a stock, running 750 engine but instead got this shipped in, not runnable as-is and needing work.
 first, a  major disappointment, as right front cylinder compression means big trouble:
so i pulled the front head and found some surprises !
special (mystery) high compression domed pistons CNC machined vs.oem cast pistons, fancy stuff !
a spot where the top of the piston hits the plug electrode at TDC is visible, the next big disappointment.
stock piston for comparison:
hot reground cam at right, stock is left:
hot reground cam is marked "NFF" or "NFI".  anyone know him ?  .020" more lift than stock.
porting and polishing by "R.E.D."  he has a website and alot of rich-guy, big-boat, fast-lane endorsers :
nice work by a pro
i discovered  2 very leaky intake valves on the  right front cylinder, accounting for the low compression.  my current theory is that new rings aren't seated (cylinders were not honed or cross-hatched) so running  he engine for awhile might boost the compression up..........i hope.
^^^^^^^^^^^^^^  from what little i  think i know about building engines and some experience, my best guess is that this one would be a troublesome beast in a street bike, needing expensive race fuel and prone to bad idle and overheating.  my challenge now is just to get it running, to test it out on the road a bit, then maybe sell it at some profit to a younger he-man multi-tattooed  bloke who needs to go fasta than i dare, or maybe an AMA or ARHMA vintage racer with deep pockets and 70+,  enjoying life in the elite atmosphere of the pits.
if it don't blow apart, that is.
