4corsa Posted December 9, 2017 Share Posted December 9, 2017 Easy answer to that one = Stuff all, seriously though, it's probably not too much more weight than an oil filter at a guess! OK maybe an oil filter full of oil then. Was hoping it weighed a bit more, but better than nothing. By the way, at first I couldn't find where to download the manual (because I was on the mobile site). Switched to my laptop and found it. Supposed to snow here tomorrow, so that will provide some entertainment.Sent from my SCH-I545 using Tapatalk Link to comment Share on other sites More sharing options...
4corsa Posted December 9, 2017 Share Posted December 9, 2017 Not as heavy as you'd think. Maybe 2 pounds, definitely less than 3. I did it mainly because it was annoying me and because now I can actually change my damn oil filter Good point, I'll be changing my oil soon, so I'll use the opportunity to yank out the canister.Sent from my SCH-I545 using Tapatalk Link to comment Share on other sites More sharing options...
NZCam Posted December 20, 2017 Share Posted December 20, 2017 Had my bike out in the hot sun the other day (32-35 degC), and it started leaking petrol. The tank was about 20-25% full (so lots of air volume), and the bike was in full direct sunlight at about 11:30am, and had been since sun-up at 6am (southern hemisphere high summer). Thinking that it was a pressure-related issue with fuel leaking out the overflow pipe, I opened the petrol cap, and got a huge swoosh of positive pressure. The engine had been off since the evening before, so no residual running heat. Anyone got any ideas about the cause (other than hot sun, of course). I would have thought the bike could handle hotter conditions without problems. Kinked breather pipe maybe? The leak stopped as soon as I moved the bike into the shade, and had released the pressure from the tank via the filler-cap. Link to comment Share on other sites More sharing options...
Member Contributer Marooncobra Posted December 20, 2017 Member Contributer Share Posted December 20, 2017 Sounds like your breather pipe is either blocked or kinked Link to comment Share on other sites More sharing options...
Member Contributer Mohawk Posted December 20, 2017 Member Contributer Share Posted December 20, 2017 Even if the breather was blocked a 1/4 full tank should NOT leak fuel as its below the level of the breather. Taht then begs the question of where was it leaking fuel from ? If the breather is blocked which is the normal escape route, then ut had to be coming from somewhere else, like the Fi lines, tank pump seal or worse from a tank seam ! I'd check the source of the leak IIWY. Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted December 20, 2017 Member Contributer Share Posted December 20, 2017 17 hours ago, NZCam said: Had my bike out in the hot sun the other day (32-35 degC), and it started leaking petrol. The tank was about 20-25% full (so lots of air volume), and the bike was in full direct sunlight at about 11:30am, and had been since sun-up at 6am (southern hemisphere high summer). Thinking that it was a pressure-related issue with fuel leaking out the overflow pipe, I opened the petrol cap, and got a huge swoosh of positive pressure. The engine had been off since the evening before, so no residual running heat. Anyone got any ideas about the cause (other than hot sun, of course). I would have thought the bike could handle hotter conditions without problems. Kinked breather pipe maybe? The leak stopped as soon as I moved the bike into the shade, and had released the pressure from the tank via the filler-cap. Hi Cam. Agree with Mohawk here, not possible for a 25% full tank to exit fuel from the breather hose. Both tank Vaccum and Pressure are relieved through the Breather hose. Has your bike been recently serviced requiring work around the air box? If so it is vital that when the tank is lowered the breather slack is pulled through so it's not pinched. A pinched breather is going to allow high pressures when sun soaking and nasty vacuum whilst riding possibly in cooler conditions. The lower three drain hoses are in an order of Breather front hose, Coolant Overflow middle hose and Fuel Filling Overflow the rear hose. Never heard of raw fuel exiting the Breather hose and I generally fill the bike to the max. Perhaps you've had a major service done with a coolant replaced and a new air filter. So maybe it was some excess coolant overflow you saw and they have pinched your breather causing your pressure situation - Just a thought. Cheers. Grum. Link to comment Share on other sites More sharing options...
Kwee69 Posted January 6, 2018 Share Posted January 6, 2018 Removed the EVAP+ hoses on my 2017, weight 800 gr(1,8 pounds). No more tank vacuum problems. Link to comment Share on other sites More sharing options...
