VFR vibration
Bike was recalled to replace the drive shaft ever since the vibration through the seat & handle bars has been very high & gives me pins & needles any idea how to get rid of it bike shop had it back twice their technician also agreed he gets pins & needles when he rode it
If you can feel the vibration with the bike in neutral then it's the engine
if you can only feel it on the move it'll be in the transmission in which case I'd guess at the drive shaft housing alignment not being correct, put it on the centre stand and see if it looks straight on top of the shaft housing, same for the side
Unless it's perfectly straight you need to slacken the housing bolts then do them back up slowly and symmetrically, I'd guess some body did the bolts up by going around them instead of diagonally
