What is this?
gunn799
That's the time lapse knob. Turning it counter clockwise will make your engine appear to run at a low RPM, turning it clockwise with make it appear to run at a higher RPM. It works just like an idle adjustment screw...
If it's support bracket is broken, and they break too easily... Or if it's come loose from said bracket, it will just spin freely without actually activating the mechanism. Poorly designed. You may need to remove the fairing bolt to get better access to stay the cable sheath while turning the knob.
Thanks I'll keep that in mind.
Sent from my SM-G930W8 using Tapatalk
