Amoreira88 Posted August 1, 2017 Share Posted August 1, 2017 Just wondering if the rear break can be adjusted to be lower. I changed the shifter no problem but the break seems a little more involved. Does anyone know how to do it if it can be done? Here's a pic of my bike in the garage with my home made lazy susan Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Forbes Posted August 1, 2017 Member Contributer Share Posted August 1, 2017 Don't know about this model, but normally pedal is on a spline, you may have to dismantle and move it one tooth. Or it could be a locking nut behind rearsets linked to master cylinder.Sent from my HTC_PN071 using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer fink Posted August 1, 2017 Member Contributer Share Posted August 1, 2017 Instructions should be in owners manual. It's just a question of unpinning it and screwing it down or up the thread. Link to comment Share on other sites More sharing options...
Amoreira88 Posted August 4, 2017 Author Share Posted August 4, 2017 So yea it was as simple as loosing the lock bolt and lowering the threads with the other bolt. I was able to lower it 3/4 on an inch. As low as it goes. Had to adjust the brake light switch too. On the lowest setting it's is very touchy n sometimes sticks in the on position. Think I might have to stretch out the spring. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
