Welcome to VFRDiscussion
Sign in to follow this
Followers 0
jhenley17
8th Gen Compatible Throttle Tubes
Does anyone know if any other model throttle tubes are compatible? Looking for something a little quicker than stock.
Share this post
Have you checked part numbers with other vfrs and see if they can be swapped from other bikes in order to get the desired result.
Alternately take a bigger handful.
Share this post
Well, I was hoping to be able to go from closed to WOT comfortably without adjusting my grip so that I could more easily get a bigger handful. I haven't compared part numbers, yet, I figured I'd see if the ground work had been done before I start that.
1 person likes this
Share this post
Given the 8th gen's tendency to be twitchy at low throttle settings, I'd probably set my sites on a progressive unit.
Share this post
Well it appears that the throttle tube comes with the grip. Different part numbers for the US models.  More of a choice on the std bike but sadly no vfr in list can't see many NC or CB owners wanting a qot.
Alternately you could just just buy one and try , I'm sure they are only a few dollars from eBay. Or adjust your grip prior to opening.  If you've never tried one they take a bit of getting used to on the street.
1 person likes this
Share this post
Progressive would be preferred, but I'll take what I can get.
I might try a few and see what happens. I'll probably compare pictures and see if anything even looks possible.
Share this post
Check out the G2 Throttle Tamer.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
