Lukas Posted May 17, 2017 Share Posted May 17, 2017 HI, urgent need of advice please. 2002 Honda VFR 800 VTEC. Buzzing continues behind dash, all 4 indicators glow and bike starts and cuts out straight away. This happened a month ago and then it stopped. Stator and rectifier was replaced since, due to not charging. Yest it did the above again and it still does. Switch on, buzzing continues behind dash (not the bzzzt that goes off for PGM-FI), headlights dont come on, all 4 indicators glow (if I switch the indicator on, all 4 flash, including the dash lighting). Start, and it cuts out. Please advise if anyone had similar problem. Thanks, Lukas Link to comment Share on other sites More sharing options...
Member Contributer Woodie Posted May 18, 2017 Member Contributer Share Posted May 18, 2017 Aren't the relays mounted behind the dash. Could the buzzing be a stuck relay ? Link to comment Share on other sites More sharing options...
Lukas Posted May 19, 2017 Author Share Posted May 19, 2017 Thanks, will have a look n see this weekend, ta. Link to comment Share on other sites More sharing options...
