MadMike05 Posted March 23, 2017 Share Posted March 23, 2017 Hey guys, I have a question about cleaning the carburetors on my 83. On the manual wish you would see in a picture below, manual shows the front two cylinders are #2 and 4 which i agree with on the walkthrough posted on anther topic. When you reference the picture posted in the walk through it does not match the manual as far as which cylinders are number two and four respectively. This may be confusing, only because I am confused at the moment, but please see the pictures below and notice I engraved the caps with the cylinder number and advise if I have the correct order. Thank you Ps the first picture of of my service manual. The second is my cleaned carbs The third is the designated locations for each carb as per the walkthrough Link to comment Share on other sites More sharing options...
MadMike05 Posted March 23, 2017 Author Share Posted March 23, 2017 Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted March 23, 2017 Member Contributer Share Posted March 23, 2017 The image below is from the Honda service manual. Just the same as the Clymer manual. Link to comment Share on other sites More sharing options...
MadMike05 Posted March 23, 2017 Author Share Posted March 23, 2017 Ok. So is it safe to assume the write-up for v45 in another thread has the wrong carbs labeled. I mean worst case is I have to flip the springs around but still Link to comment Share on other sites More sharing options...
Member Contributer RC1237V Posted March 23, 2017 Member Contributer Share Posted March 23, 2017 Someone correct me if I'm wrong......The CYLINDER number has to do with firing order and engine repairs. The CARB number is a reference for which carb is the base carb for synching, and if there is a specific order in which to synchronize them. Link to comment Share on other sites More sharing options...
MadMike05 Posted March 23, 2017 Author Share Posted March 23, 2017 Oh, those are the cylinder locations... Not the front/back locations for the carbs themselves? I'm back to being confused :/ Link to comment Share on other sites More sharing options...
Member Contributer RC1237V Posted March 23, 2017 Member Contributer Share Posted March 23, 2017 Looking at your pictures it looks like yours are numbered correctly. The bottom picture does look incorrect, if it is the same set of carbs facing the same direction. Link to comment Share on other sites More sharing options...
TheDutchy Posted March 23, 2017 Share Posted March 23, 2017 On the VF series, from a seated position: Front left is #2 Front right is #4 Rear left is #1 Rear right is #3 On the carbrail #4 is the one carb where the throttle cables attaches to. That #4 is the carb where all the other carbs have to be synched to... Link to comment Share on other sites More sharing options...
MadMike05 Posted March 24, 2017 Author Share Posted March 24, 2017 Thank you gentleman. Maybe I'll write up a year specific carb clean for the next guy.. If i set the wrong float height or something and need to redo it Link to comment Share on other sites More sharing options...
