Vfr 750 - 92
  • Replies 149
I had a misfire under load on my ST1100, traced it back to low voltage reaching the coils and poor sparks as a result. The cause was corrosion in a connector that supplied power to the ECU. You could also check the coils for appropriate resistance on the primary and secondary sides.
Tnx! So, electrical perhaps... Damn. I was hoping for carburetor issues, something I can handle. But electrical. Hate it.
So, which one is the one to forth cylinder? Secondary and primary side is where?
Thanks again for quick response
Hei hei!
Should one or more coils be gone, I have a bunch in my shed doing nothing.
If I can help a Jock out, I will pal!  Och aye da noo!
:goofy:
27 minutes ago, Dutchy said:
Hei hei!
:goofy:
Haha! That's great!! Good to have you guys here! ? ?
Jocke is glad ?
How can I measure it?
So, just realised that I haven't described my problems accordingly for me to ask for your help.
Rough acceleration over 5000 rpm, feels like misfire. Does backfire or poff poff when released throttle after acceleration. The last one can be due to the exhaust (slip on) being replaced. But I'm not sure.
24 minutes ago, Jock3 said:
Is it compatible with - 92 also?
Euh....  it reads "90-96" :unsure:
Lay off the Mackmyra at 10am in the morning will ya? :goofy:
Haha didn't see it ??
Hehe, only Laphroaig here in that case. ?
Yeah, Laphroaig rules!!
  • 4 weeks later...
Been ridiculous summer so far. First 3 weeks of work after the holidays and it's been many overtime hours.
But, this lunch, my buddy asked me to get to the tire shop... Apparently this isn't the way to ride, no matter how fun it is ??_20170818_172817.thumb.JPG.ab108cc172b5fc326a42f5cd4c314d48.JPG_20170818_172817.thumb.JPG.181a9251674d475cc2cde6771544a0fe.JPG
And yesterday offered warmth in the air again
"In the olden days", bikeshops would give you a discount if you burned up your (already worn) tyre in front of the shop.
Lucky numbah eight!!
byebyethanksforthemiles.MP4
Them days are gone.... PC, green, noise pollution and all that...
I would still give a discount, just don't do it in my drive way.... hrmm need to add concrete burn out pad to parking lot
  • 1 month later...
I know why those critters went extinct. Although their teeth were fine for taking care of hooved forest rats, their arm were too short for riding motorcycles!
1 hour ago, MaxSwell said:
I know why those critters went extinct. Although there teeth were fine for taking care of hooved forest rats, their arm were too short for riding motorcycles!
That must have been the case! ?
  • 2 months later...
New clutch! Hopeful on better speed out of those corners now. DP-clutches with harder coating and better springs.
The old springs, right in the picture, was waiting for replacement. It was a 6mm difference in height (!)
In a case of "been there, done that",  not that IF this pin was pulled forward, a flat wasjer BEHIND the sprocket may have fallen out....
:goofy:
and while open, inspect the starter clutch for crack.s...
