Welcome to VFRDiscussion
Sign in to follow this
Followers 0
Burns
Power Commander 2
so, who knows about the Power Commander 2's?   seems to be very limited information on Dynojet's site.  Anyone have the software download and are the maps the same between the PC2 and the PC3's?
Share this post
Your bikes are carbureted 😬
Share this post
just picked up a 2000.. so yes, it's FI, and it has a PC2 on it already.
Share this post
Are you making any changes to it? Should already be mapped by previous owner right? Otherwise I think you could pick up the PC3.  Or get it tuned but not sure if dyno centers use the 2 or if they are compatible with all software.
Art
Share this post
PM Wera803. He's got a bunch of PCII maps. He's got a PCIII on his '01 now, but had a PCII before.
Sounds like they take different mapping.
1 person likes this
Share this post
I uploaded a bunch of old powercommander maps and the software to edit PC2 and PC3 maps to the downloads section:
There is another I just saw by knight that is more recent:
There might be useful files in either of those.  Good luck!
1 person likes this
Share this post
thanks for the replies..  I'll start with the downloads and see what works.  The plan is to switch over to the pre-2000 headers (to lose the cat and some weight) and then go w/ a '99 map.   I'm to understand that the PCii's also have ignition advance feature in them, so that's something else to explore.
Share this post
Be careful with the ignition advance feature. I used one of Hispanic Slammers maps from his 98 that had the ignition advanced and my bike ran well right up until about 9k or 10k rpm where it abruptly stopped gaining rpm. I did that 2 or 3 times to verify things and quickly changed the map. Not sure what would be different about the '00 & '01 bikes to cause that, but ignition advancement did not work for my 2001.
Share this post
looks like the manual I found agrees...  :beer:
Quote
Honda VFR800
Table 1 AAP (barometric pressure sensor)
This table can be used to add or remove fuel from 10% through 100% throttle. The maximum value for
adding fuel is "9". The maximum value for removing fuel is "-35".
Table 2 TP (throttle position)
This table can be used to add fuel at throttle settings between 5% and 80% if Table 1 does not allow the
desired fuel ratio. Small changes in this table equal large changes in fuel delivery.
Table 3 MP (manifold pressure/vacuum)
This table is used to adjust fuel delivery at small throttle openings, 0% through 5%. Large values are
required to make a noticeable change in fuel delivery (steps of "5" or so). Maximum value is "125", but if
a value over "35" is used it might be necessary to use Table 2 in this area.
Table 4 Ignition
Adjustment for ignition timing is +4/-11 degrees. Timing is adjustable from 2,000 rpm to redline at all
throttle positions. On street bikes with normal fuel, advancing the timing does little to improve power. It is
possible on some models to achieve small gains as long as the highest octane fuel available is used.
Share this post
Get it professionally dyne tuned and you have your own custom map for you setup.  Worth it.
My mods are piper cross filter, micron slip on, and pc3.  DMR suspension and brake delink.
Art
Art VFR800 Dyno.pdf
Share this post
eventually I hope to do that.. and my final setup should be similar to yours....   this is mostly research on my part currently. since I really have no information on what's loaded in the bike or such...
Share this post
Well from what I understand, you just acquired the bike from the PO right?  Everything set up on it as you received it?  Unless he did a hack job, it should have the correct map, or fairly close one for it.  How does it run?  I understand wanting to know what is actually on the unit and moving on from there.  Have you tried emailing dynojet to see what your options are for legacy product?
Share this post
You didn't say if you had a cable or not.  The PC2 uses an RS-232 serial connection and some (most? many? all?) usb to serial adapter cables will not connect correctly.  I bought 2 different ones since I was aware of the issue, and neither worked.  I ended up using a really old laptop that still had a serial port.
Share this post
Burns I can sell you a really old laptop with a serial port for $20.  You would need to find your own copy of windows for it though.
Share this post
LOL... probably have have 2 or 3 old laptops sitting in the den.. and a USB/serial cable or two laying around.  The PO swapped pipes from an aftermarket back to a stock pipe (working on fixing that).   My plan is to swap to '99 headers (to loose the cat) and some sort of high-mount.. haven't cracked the airbox yet, so no idea what filter is in there, if the flapper been done, etc.   Haven't really even gotten to properly ride the bike yet, due to wx and work - what little I have done, I've noticed an odd stumble/delay right off idle - very brief.   I don't recall this on the other 5th gens I've ridden.
Dynojet did send me a couple links - basically what I already found on their site.  install for the hardware, and the control software.   I had to scour the inet for a user manual of the software.
1 person likes this
Share this post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
